System Stability Test: CPU load failing (Gigabyte X99-SOC Champion + i7-5930K)
system stability test: cpu load failing.
I can see it at the AC wall power meter, CPU loading is not really working.
GUI is un-responsive.
When I test with OCCT this is working fine.
could be related to windows 10 64 bits CU provisioning update.
On ‎2017‎. ‎07‎. ‎23‎. at 9:04 AM, xixou said:
I received the 5.92.4321 beta and the test is now running fine.
Thanks for the fix.
Thank you for your feedback.  Truth is: we haven't fixed anything actually :)  It seems to have healed itself for some reason.
On ‎2017‎. ‎07‎. ‎28‎. at 5:17 PM, xixou said:
Maybe a recent windows 10 update or maybe because i enabled hyperthreading in the bios?
It could be the uncommon setting of disabled HyperThreading.  Just in case, we'll check that scenario with our i7-5820K CPU.
We've checked, and we couldn't reproduce the issue on our 5820K based test system (with HTT disabled).  The next time it occurs on your system, please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
