byw7 Posted June 12, 2011 Report Share Posted June 12, 2011 AIDA64 Business 1.70 1400 Compare Gigabyte GA-EP45-UD3P and ASRock Fatal1ty P67 Professional I have a GIGABYTE GA-EP45-UD3P Board. When I to connect a Scythe S-Flex SFF21D with 7Volt on the Board AIDA indicates correctly ca.600 rpm! When I to connect the Scythe S-Flex on the Motherboard from ASRock Fatal1ty P67 Pro AIDA indicates nothing at all unter 7 Volt Fan (by 12 Volt indicates correctly rpm). What is here the Problem? Can help me? Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 12, 2011 Report Share Posted June 12, 2011 Can the BIOS Setup of the ASRock P67 Pro motherboard measure the 7V fan RPM properly? Quote Link to comment Share on other sites More sharing options...
byw7 Posted June 13, 2011 Author Report Share Posted June 13, 2011 Can the BIOS Setup of the ASRock P67 Pro motherboard measure the 7V fan RPM properly? Yes! When i start the UEFI (BIOS) is in the UEFI (BIOS 1.80) from Asrock Fatal1ty P67 Pro the RPM correctly: FAN 2 Speed 617 RPM Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 13, 2011 Report Share Posted June 13, 2011 Thank you. When you have the 7V fan connected to your ASRock P67 Pro motherboard, please start AIDA64, right-click on the bottom status bar of its main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
byw7 Posted June 13, 2011 Author Report Share Posted June 13, 2011 Thank you. When you have the 7V fan connected to your ASRock P67 Pro motherboard, please start AIDA64, right-click on the bottom status bar of its main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Thanks, Fiery I hope that is this. __________________________________________________________________ [AIDA64 Business Edition] Version=AIDA64 v1.70.1400/de Benchmark Modul=2.7.345-x64 Homepage=http://www.aida64.com/ Berichtsart=Kurzbericht Computer=Asrock Fatal1ty P67 Pro Ersteller=tuner Betriebssystem=Microsoft Windows 7 Ultimate 6.1.7601 (Win7 RTM) Datum=2011-06-13 Zeit=11:20 [sensoren] Sensor Eigenschaften|Sensortyp=Nuvoton NCT6776F (ISA 290h) Sensor Eigenschaften|GPU Sensortyp=Diode (NV-Diode) Sensor Eigenschaften|Gehäusezutritt gefunden=Ja Temperaturen|Motherboard=41 °C (106 °F) Temperaturen|CPU=38 °C (100 °F) Temperaturen|CPU Package=45 °C (113 °F) Temperaturen|CPU IA Cores=45 °C (113 °F) Temperaturen|CPU GT Cores=39 °C (102 °F) Temperaturen|1. CPU / 1. Kern=45 °C (113 °F) Temperaturen|1. CPU / 2. Kern=42 °C (108 °F) Temperaturen|1. CPU / 3. Kern=40 °C (104 °F) Temperaturen|1. CPU / 4. Kern=41 °C (106 °F) Temperaturen|Aux=29 °C (84 °F) Temperaturen|GPU Diode=48 °C (118 °F) Temperaturen|Corsair CSSD-F120GB2=34 °C (93 °F) Temperaturen|SAMSUNG HD250HJ=33 °C (91 °F) Kühllüfter|CPU=912 RPM Kühllüfter|Stromversorgung=852 RPM Spannungswerte|CPU Kern=0.992 V Spannungswerte|Aux=3.696 V Spannungswerte|+3.3 V=3.248 V Spannungswerte|+5 V=5.457 V Spannungswerte|-5 V=-1.529 V Spannungswerte|+5 V Bereitschaftsmodus=5.164 V Spannungswerte|GPU Kern=1.100 V Leistungswerte|CPU Package=12.53 W Leistungswerte|CPU IA Cores=8.08 W Leistungswerte|Debug Info F=912 164 852 164 164 Leistungswerte|Debug Info T=41 38 29 / 255 44 Leistungswerte|Debug Info V=7C E7 CB CB FF D0 7B (03) Leistungswerte|Debug Info I=C1 C333 Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 13, 2011 Report Share Posted June 13, 2011 I'm afraid it's not it Please right-click on the bottom status bar of AIDA64 main window, where it reads "Copyright © 1995-2011 FinalWire Ltd", then in the popup menu that appears select the second menu item called "Sensor Debug", then in the submenu that appears select the third menu item called "ISA Sensor Dump". Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
byw7 Posted June 13, 2011 Author Report Share Posted June 13, 2011 ------[ AIDA64 v1.70.1400 ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-102510-Chipset$0AAAA000_BIOS DATE: 03/18/11 18:03:39 VER: 04.06.04 Motherboard Model : ASRock P67 Professional Motherboard Chipset : Intel Cougar Point P67, Intel Sandy Bridge DMI MB Manufacturer : ASRock DMI MB Product : P67 Professional DMI MB Version : DMI MB Serial : DMI SYS Manufacturer: To Be Filled By O.E.M. DMI SYS Product : To Be Filled By O.E.M. DMI SYS Version : To Be Filled By O.E.M. DMI SYS Serial : To Be Filled By O.E.M. DMI BIOS Version : P1.80 ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 2Eh Winbond SuperIO HWMonitor Port = 0290h Winbond SuperIO Device ID = C333h Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1 Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ Nuvoton ISA Sensor Device at 0290 / Bank #0]------ 0000 04 FF 04 FF 00 FF FF FF FF FF FF FF FF FF FF FF 0010 04 FF 00 00 00 00 FF FF 40 00 00 00 00 83 00 00 0020 9A E8 CC CC 46 D0 76 22 FF FF FF DA 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF 0040 03 00 50 FF FF 00 3F FF 2D FF FF FF 18 05 07 A3 0050 FF FF FF FF FF FF FF FF C1 FF FF FF FF 00 00 FF 0060 A2 FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF 0070 00 0A 00 22 80 2A 00 1E 80 FF FF FF FF FF FF FF 0080 FF 03 1F 0F FF 3C 3C 3C 00 00 00 00 00 00 00 00 0090 0A 00 00 00 00 0A 0A 0A 0A AA EF 80 FF 40 46 C4 00A0 0E 01 00 00 FF 00 00 FF 00 00 80 66 66 06 01 01 00B0 00 00 00 00 00 00 33 00 1C 00 00 34 28 80 C4 FF 00C0 01 00 00 00 00 00 00 00 00 08 07 FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Reg$20 CPU Core: r = 154, r*0.016 = 2.46 Reg$21 CPU Aux: r = 232, r*0.016 = 3.71 Reg$22 +3.3 V: r = 204, r*0.016 = 3.26 Reg$23 +5 V: r = 204, r*0.016 = 3.26 Reg$24 +12 V: r = 70, r*0.016 = 1.12 Reg$25 -12 V: r = 208, r*0.016 = 3.33 Reg$26 -5 V: r = 118, r*0.016 = 1.89 ------[ Nuvoton ISA Sensor Device at 0290 / Bank #1]------ 0000 01 00 00 0A 0A 01 01 3C FF FF FF FF 00 FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 00 19 23 2D 37 FF FF 8C AA C8 E6 FF FF FF FF FF 0030 FF 00 FF FF 00 7F FF FF 00 01 00 00 00 00 00 00 0040 FF FF FF FF FF A2 03 FF FF FF FF FF FF FF 07 FF 0050 1F 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #2]------ 0000 8C 32 02 0A 0A 01 01 3C FF FF FF FF 00 FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 00 28 32 3C 46 FF FF 8C AA C8 E6 FF FF FF FF FF 0030 FF 00 FF FF 00 7F FF FF 00 01 00 00 00 00 00 00 0040 FF FF FF FF FF A4 00 FF FF FF FF FF FF FF 07 FF 0050 1E 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #3]------ 0000 03 00 00 0A 0A 01 01 3C FF FF FF FF 00 FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 00 19 23 2D 37 FF FF 8C AA C8 E6 FF FF FF FF FF 0030 FF 00 FF FF 00 3C FF FF 00 01 00 00 00 00 00 00 0040 FF FF FF FF FF 51 03 FF FF FF FF FF FF FF 07 FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #4]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF 0020 FF FF FF 96 64 96 64 E1 96 FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 3F 00 03 FF FF FF FF FF FF FF FF FF FF FF 07 FF 0050 31 13 FF FF 00 00 00 FF 00 DE 1D B1 09 FF FF FF 0060 FF 01 00 00 00 00 00 00 FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #5]------ 0000 FF FF 00 00 00 00 FF FF FF FF FF FF FF 00 00 FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 07 FF 0050 D5 00 00 FF 00 00 00 00 FF FF FF FF FF FF FF FF 0060 00 00 00 00 00 00 07 01 01 FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #6]------ 0000 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 FF 01 02 03 01 01 01 FF 00 00 00 22 22 22 07 FF 0030 2E 1D FF 1F 31 15 FF 1F FF 1F 00 00 00 00 00 00 0040 00 00 00 00 02 02 02 FF FF FF FF FF FF FF 07 FF 0050 7F 7F 7F 7F 7F 7F 03 83 00 A4 03 51 00 A4 00 A4 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 7F 7F 50 4B 04 7F 7F 50 4B 04 7F 7F 50 4B 04 FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #7]------ 0000 FF 95 02 10 00 00 00 00 00 62 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 F2 12 F8 80 F8 80 F8 80 01 0020 2A 01 06 00 00 00 EF AD 00 EF 00 00 00 00 00 00 0030 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 07 FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0027 0150 0250 007D 007E 062B 0720 T: 34 31 30 255 255 34 42 T: 34 31 30 255 255 34 43 T: 34 31 30 255 255 34 41 T: 34 31 30 255 255 34 40 T: 34 31 30 255 255 34 40 T: 34 31 31 255 255 34 39 T: 34 31 30 255 255 34 40 T: 34 31 30 255 255 34 39 T: 34 31 30 255 255 34 39 T: 34 32 30 255 255 34 39 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : Quote Link to comment Share on other sites More sharing options...
Fiery Posted June 13, 2011 Report Share Posted June 13, 2011 Thank you, that's what we were looking for. But I'm afraid your motherboard is one of those ASRock boards that use a special GPIO-based fan muxing. It effectively means only the BIOS Setup and ASRock's own Windows utility (F-Stream) can measure fan RPM for the muxed fan header called "CPU Fan2". You need to connect your fan to another fan header to let AIDA64 read the fan speed. Quote Link to comment Share on other sites More sharing options...
byw7 Posted November 2, 2011 Author Report Share Posted November 2, 2011 You need to connect your fan to another fan header to let AIDA64 read the fan speed. ...if I want to realize this for my 7Volt Fan, what is the better Option a Header with 3PIN (Molex) or 4PIN (Molex)? Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 2, 2011 Report Share Posted November 2, 2011 I guess 3-pin would be better, although we don't have first-hand experiences on 7-Volt fans. Quote Link to comment Share on other sites More sharing options...
