Latest build cause fans to throttle randomly (Corsair H100i)
Not sure of this is a bug with Aida or Corsair Link, but it only started happening when I upgraded to the latest beta.  My H100i fans will randomly spin at full speed for a second, then slowly go back to quiet mode (my setting) for 5 seconds, then throttle up again for a second.  This will repeat the entire time Aida is open.  As soon as I exit, everything returns to normal.
Been using Aida for a long time and have had this cooler for 2 years now and never had this issue.
On ‎2017‎. ‎07‎. ‎28‎. at 2:52 AM, Edrick said:
Yes, 4.8.082
Thank you. Can you please try to configure the same fan duty cycle (%) value in AIDA64 / main menu / File / Preferences / Hardware Monitoring that you have configured in Corsair Link Software?  Check the "Set Asetek fan speed" checkbox, and set both % values to the fan duty cycle of your choosing.
