Problem With LCD Smartie (aida.dll not working anymore) (Crystalfontz CFA634)
Hello..
I was using Aida 64 together with LCD Smartie Software on Win 7 64 for years now.
A few weeks ago i had to install Win 10 64 home prem. Since then i cant get Aida 64 running together with the LCD Smartie software.
I have a Crystalfontz 20x4 CF 634 LCD Display with USB To Serial Adapter Com Port 4 Baud Rate 19200.
Since the Win 10 Install i can get LCD smartie running proper but when it comes to the Aida64 show pages then an error occures "Can not load lpugin" The Plugin is named "Aida.dll"
Ok so i tried the LCD Support in Aida 64 directly...  I switched to Crystalfontz LCD Support..... there it shows "USB Device not found"
As i cant move on i registered here in the forum asking for help..
My Aida Software Version is 5.92 Extreme i guess .and LCD Smartie Version is 5.4 i guess.
Sorry for my bad english.. i try my best....
Does there exist a newer Aida.dll for LCD Smartie or is it somehow possible to activate the CF 634 in Aida directly...
Best regards....
(Move or forward This Post if it is the wrong  place here..)
Since LCD Smartie is not our software, nor did we develop the plugin for it, I cannot assist you regarding that issue.
As for the direct support for Crystalfontz in AIDA64, please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
I will check that...
thank you!
Hope this is what you need....
first i didnt find the debug mode but when i did read your post again i read that i hav to enable status bar in settings... then everthing was clear!
when i activate LCD Support for Logitech G15 G 19 LCD This works without problems.... its just the damn CF 634 that cant be found by Aida..
but the drivers are installed otherwise i would not be able to control the lcd via LCD Smartie or Crystal Control Software...
Strange days! :-)
------[ Versions ]------
Program Version : AIDA64 Extreme v5.92.4300
BenchDLL Version: 4.3.759-x64
Windows Version : Microsoft Windows 10 Home 10.0.15063.674 (64-bit)
Motherboard ID      : 63-0100-000001-00101111-101111-Chipset$1APTC015_BIOS DATE: 03/02/12 19:34:18 VER: 32.03
Motherboard Model   : Asus Maximus IV Gene-Z
Motherboard Chipset : Intel Cougar Point Z68, Intel Sandy Bridge
DMI MB Manufacturer : ASUSTeK Computer INC.
DMI MB Product      : Maximus IV GENE-Z
DMI MB Version      : Rev 1.xx
DMI MB Serial       : MB-1234567890
DMI SYS Product     : System Product Name
DMI SYS Version     : System Version
DMI SYS Serial      : System Serial Number
DMI BIOS Version    : 3203
------[ USB Devices ]------
Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
- [Port 1] Generic USB Hub
- - [Port 1] < No Device Connected >
- - [Port 2] < No Device Connected >
- - [Port 3] < No Device Connected >
- - [Port 4] < No Device Connected >
- - [Port 5] USB-Verbundgerät (Sound Blaster X7)
- - - Sound Blaster X7
- - - - Bluetooth (Sound Blaster X7)
- - - - Lautsprecher (Sound Blaster X7)
- - - - Line-In (Sound Blaster X7)
- - - - Mic-In/Mic-Array (Sound Blaster X7)
- - - - SPDIF-In (Sound Blaster X7)
- - - - SPDIF-Out (Sound Blaster X7)
- - - - USB-Host (Sound Blaster X7)
- - - - Was Sie hören (Sound Blaster X7)
- - - USB-Eingabegerät
- - - - HID-konformes Benutzersteuergerät
- - [Port 6] < No Device Connected >
Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
- - [Port 1] USB-Massenspeichergerät (USB to ATA/ATAPI Bridge)
- - - ST2000DM 001-9YN164 USB Device
- - - WDC WD40 EZRZ-00WN9B0 USB Device
- - [Port 3] USB-Verbundgerät (Gaming Mouse G502)
- - - - HID-konforme Maus
- - - - HID-konformer Systemcontroller
- - - - HID-konformes, vom Hersteller definiertes Gerät
- - - - HID-Tastatur
- - [Port 5] USB Serial Converter (USB <-> Serial)
- - - USB Serial Port (COM4)
- - [Port 6] USB-Eingabegerät (tubemeter 1.10)
- - [Port 7] < No Device Connected >
- - [Port 8] USB-Verbundgerät (aquaero)
ASMedia USB3.0 eXtensible Host Controller
------[ Generic USB Hub]------
Device Description   : Generic USB Hub
Device ID            : 8087-0024
Device Class         : 09 / 00 (Hi-Speed Hub with single TT)
Device Protocol      : 01
Revision             : 0000h
Supported USB Version: 2.00
Current Speed        : High  (USB 2.0)
------[ USB-Verbundgerät]------
Device Description   : USB-Verbundgerät
Device ID            : 041E-323A
Device Class         : EF / 02 (Interface Association Descriptor)
Revision             : 0100h
Manufacturer         : Creative Technology Ltd
Product              : Sound Blaster X7
Serial Number        : 000002du
Revision             : 0000h
------[ USB-Massenspeichergerät]------
Device Description   : USB-Massenspeichergerät
Device ID            : 152D-0539
Device Class         : 08 / 06 (Mass Storage)
Device Protocol      : 50
Revision             : 2805h
Manufacturer         : CFI
Product              : USB to ATA/ATAPI Bridge
Serial Number        : 891508200010A
Supported USB Version: 2.10
Device ID            : 046D-C332
Device Class         : 03 / 01 (Human Interface Device)
Device Protocol      : 02
Revision             : 0302h
Manufacturer         : Logitech
Product              : Gaming Mouse G502
Serial Number        : 178236613936
Current Speed        : Full  (USB 1.1)
------[ USB Serial Converter]------
Device Description   : USB Serial Converter
Device ID            : 0403-6001
Device Class         : FF / FF
Device Protocol      : FF
Revision             : 0200h
Manufacturer         : FTDI
Product              : USB <-> Serial
Serial Number        : 12345678
Supported USB Version: 1.10
------[ USB-Eingabegerät]------
Device Description   : USB-Eingabegerät
Device ID            : 0C70-F0B1
Device Class         : 03 / 00 (Human Interface Device)
Device Protocol      : 00
Revision             : 0110h
Manufacturer         : aqua computer
Product              : tubemeter 1.10
Current Speed        : Low  (USB 1.1)
Device ID            : 0C70-F001
Revision             : 0002h
Manufacturer         : Aqua Computer GmbH & Co. KG
Product              : aquaero
Serial Number        : 17031-23105
------[ DevClass / USB Hubs ]------
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_8087&pid_0024#5&1c9b8e1e&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_8087&PID_0024\5&1C9B8E1E&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0000</REV>
<DESC>USB-Root-Hub</DESC><DEVPATH>\\?\usb#root_hub20#4&3113f1a8&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB20\4&3113F1A8&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>ASMedia USB Root Hub</DESC><DEVPATH>\\?\usb#asmediaroot_hub#5&3147820f&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ASMEDIAROOT_HUB\5&3147820F&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>USB-Root-Hub</DESC><DEVPATH>\\?\usb#root_hub20#4&36206eee&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB20\4&36206EEE&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0607&asmediausbd_hub#00000830#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_05E3&PID_0607&ASMEDIAUSBD_HUB\00000830</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0801</REV>
<DESC>ASMedia USB Root Hub</DESC><DEVPATH>\\?\usb#asmediaroot_hub#5&338e9af1&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ASMEDIAROOT_HUB\5&338E9AF1&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_8087&pid_0024#5&355c47ba&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_8087&PID_0024\5&355C47BA&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0000</REV>
------[ DevClass / USB Devices ]------
<DESC>USB-Verbundgerät</DESC><DEVPATH>\\?\usb#vid_041e&pid_323a#000002du#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_041E&PID_323A\000002DU</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>0100</REV>
<DESC>USB-Massenspeichergerät</DESC><DEVPATH>\\?\usb#vid_152d&pid_0539#891508200010a#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_152D&PID_0539\891508200010A</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>2805</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0607&asmediausbd_hub#00000830#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_05E3&PID_0607&ASMEDIAUSBD_HUB\00000830</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0801</REV>
<DESC>USB-Verbundgerät</DESC><DEVPATH>\\?\usb#vid_046d&pid_c228#10000030#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_046D&PID_C228\10000030</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0110</REV>
<DESC>USB-Verbundgerät</DESC><DEVPATH>\\?\usb#vid_046d&pid_c229#20000030#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_046D&PID_C229\20000030</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0023</REV>
<DESC>USB-Verbundgerät</DESC><DEVPATH>\\?\usb#vid_046d&pid_c332#178236613936#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_046D&PID_C332\178236613936</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0302</REV>
<DESC>USB-Eingabegerät</DESC><DEVPATH>\\?\usb#vid_0c70&pid_f0b1#6&df2ee03&0&6#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0C70&PID_F0B1\6&DF2EE03&0&6</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000006</ADDR><REV>0110</REV>
<DESC>USB-Verbundgerät</DESC><DEVPATH>\\?\usb#vid_0c70&pid_f001#17031-23105#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0C70&PID_F001\17031-23105</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000008</ADDR><REV>0002</REV>
<DESC>USB Serial Converter</DESC><DEVPATH>\\?\usb#vid_0403&pid_6001#12345678#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0403&PID_6001\12345678</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV>
------[ DevClass / Human Interface Devices ]------
<DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_02#8&946d364&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_02\8&946D364&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>0000000A</ADDR><REV>0002</REV>
<DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c332&mi_01&col05#8&8f00e91&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C332&MI_01&COL05\8&8F00E91&0&0004</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000004</ADDR><REV>0302</REV>
<DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c229&mi_01&col01#9&20bc1099&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C229&MI_01&COL01\9&20BC1099&0&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000004</ADDR><REV>0023</REV>
<DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c229&mi_01&col02#9&20bc1099&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C229&MI_01&COL02\9&20BC1099&0&0001</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000004</ADDR><REV>0023</REV>
<DESC>HID-konforme Maus</DESC><DEVPATH>\\?\hid#vid_046d&pid_c231#2&2d0d5a5a&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C231\2&2D0D5A5A&0&0000</INSTANCE><BUSNUM>0000000B</BUSNUM>
<DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c332&mi_01&col01#8&8f00e91&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C332&MI_01&COL01\8&8F00E91&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000004</ADDR><REV>0302</REV>
<DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_00&col01#8&2ccde19&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_00&COL01\8&2CCDE19&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000008</ADDR><REV>0002</REV>
<DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c228&mi_00#9&24a4c7de&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C228&MI_00\9&24A4C7DE&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000002</ADDR><REV>0110</REV>
<DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c228&mi_01&col01#9&4b39c4b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C228&MI_01&COL01\9&4B39C4B&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000003</ADDR><REV>0110</REV>
<DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_041e&pid_323a&mi_04#8&396d7ef2&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_041E&PID_323A&MI_04\8&396D7EF2&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000009</ADDR><REV>0100</REV>
<DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f0b1#7&1c27cb45&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F0B1\7&1C27CB45&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000006</ADDR><REV>0110</REV>
<DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c332&mi_01&col02#8&8f00e91&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C332&MI_01&COL02\8&8F00E91&0&0001</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000004</ADDR><REV>0302</REV>
<DESC>HID-konforme Maus</DESC><DEVPATH>\\?\hid#vid_046d&pid_c332&mi_00#8&1ae72f31&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C332&MI_00\8&1AE72F31&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000003</ADDR><REV>0302</REV>
<DESC>HID-konforme Maus</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_00&col02#8&2ccde19&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_00&COL02\8&2CCDE19&0&0001</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000008</ADDR><REV>0002</REV>
<DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c228&mi_01&col02#9&4b39c4b&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C228&MI_01&COL02\9&4B39C4B&0&0001</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000003</ADDR><REV>0110</REV>
<DESC>HID-konformer Systemcontroller</DESC><DEVPATH>\\?\hid#vid_046d&pid_c332&mi_01&col03#8&8f00e91&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C332&MI_01&COL03\8&8F00E91&0&0002</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000004</ADDR><REV>0302</REV>
<DESC>HID-Tastatur</DESC><DEVPATH>\\?\hid#vid_046d&pid_c232#2&6aae8d8&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C232\2&6AAE8D8&0&0000</INSTANCE><BUSNUM>0000000A</BUSNUM>
<DESC>HID-konformes Benutzersteuergerät</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_01&col01#8&1a906a5e&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_01&COL01\8&1A906A5E&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000009</ADDR><REV>0002</REV>
<DESC>HID-konformer Systemcontroller</DESC><DEVPATH>\\?\hid#vid_0c70&pid_f001&mi_01&col02#8&1a906a5e&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0C70&PID_F001&MI_01&COL02\8&1A906A5E&0&0001</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000009</ADDR><REV>0002</REV>
<DESC>HID-konformes, vom Hersteller definiertes Gerät</DESC><DEVPATH>\\?\hid#vid_046d&pid_c332&mi_01&col04#8&8f00e91&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_046D&PID_C332&MI_01&COL04\8&8F00E91&0&0003</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000004</ADDR><REV>0302</REV>
------[ HID Device Info / HID-konformes, vom Hersteller definiertes Gerät ]------
Product                   : aquaero Device
Revision                  : 0002h
Device Instance           : HID\VID_0C70&PID_F001&MI_02\8&946D364&0&0000
Usage                     : 0001h
Usage Page                : FF00h
Input Report Byte Length  : 1038
Output Report Byte Length : 2114
Feature Report Byte Length: 2707
Revision                  : 0302h
Device Instance           : HID\VID_046D&PID_C332&MI_01&COL05\8&8F00E91&0&0004
Usage                     : 0002h
Usage Page                : FF00h
Input Report Byte Length  : 20
Output Report Byte Length : 20
Feature Report Byte Length: 0
Product                   : G19 Gaming Keyboard (Macro interface)
Device ID                 : 046D-C229
Revision                  : 0023h
Device Instance           : HID\VID_046D&PID_C229&MI_01&COL02\9&20BC1099&0&0001
Usage                     : 0000h
Usage Page                : FF00h
Input Report Byte Length  : 4
Output Report Byte Length : 0
Feature Report Byte Length: 258
------[ HID Device Info / HID-konformes Benutzersteuergerät ]------
Device ID                 : 046D-C228
Revision                  : 0110h
Device Instance           : HID\VID_046D&PID_C228&MI_01&COL01\9&4B39C4B&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0100h
Device Instance           : HID\VID_041E&PID_323A&MI_04\8&396D7EF2&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 17
Output Report Byte Length : 65
Feature Report Byte Length: 65
Revision                  : 0110h
Device Instance           : HID\VID_0C70&PID_F0B1\7&1C27CB45&0&0000
Usage                     : 0001h
Usage Page                : FFA0h
Input Report Byte Length  : 55
Output Report Byte Length : 28
Revision                  : 0302h
Device Instance           : HID\VID_046D&PID_C332&MI_01&COL02\8&8F00E91&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Revision                  : 0110h
Device Instance           : HID\VID_046D&PID_C228&MI_01&COL02\9&4B39C4B&0&0001
Usage                     : 0001h
Usage Page                : FF00h
Input Report Byte Length  : 8
------[ HID Device Info / HID-konformer Systemcontroller ]------
Revision                  : 0302h
Device Instance           : HID\VID_046D&PID_C332&MI_01&COL03\8&8F00E91&0&0002
Usage                     : 0080h
Usage Page                : 0001h
Product                   : aquaero System Control
Revision                  : 0002h
Device Instance           : HID\VID_0C70&PID_F001&MI_01&COL01\8&1A906A5E&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 3
Revision                  : 0002h
Device Instance           : HID\VID_0C70&PID_F001&MI_01&COL02\8&1A906A5E&0&0001
Usage                     : 0080h
Usage Page                : 0001h
Revision                  : 0302h
Device Instance           : HID\VID_046D&PID_C332&MI_01&COL04\8&8F00E91&0&0003
Usage                     : 0001h
Usage Page                : FF00h
Input Report Byte Length  : 7
Output Report Byte Length : 7
------[ DevClass / COM Ports ]------
<DESC>USB Serial Port (COM4)</DESC><DEVPATH>\\?\ftdibus#vid_0403+pid_6001+12345678a#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}</DEVPATH><INSTANCE>FTDIBUS\VID_0403+PID_6001+12345678A\0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR>
------[ DevClass / LPT Ports ]------
< No LPT Port Found >
------[ DevClass / Modems ]------
< No Modem Found >
------[ DevClass / SideShow Devices ]------
< No SideShow Device Found >
------[ DevClass / GX3 Devices ]------
< No GX3 Device Found >
------[ DevClass / USBXpress Devices ]------
< No USBXpress Device Found >
------[ LibUsb0 Devices ]------
< No LibUsb0 Device Found >
------[ CH341 Devices ]------
< No CH341 Device Found >
------[ FTD2xx Devices ]------
< No FTD2xx Device Found >
------[ LibMPSSE Devices ]------
< No LibMPSSE Device Found >
------[ SiUSBXp Devices ]------
SiUSBXp.dll Path =
< No SiUSBXp Device Found >
------[ T-Balancer Devices ]------
< No T-Balancer Device Found >
------[ Koolance TMS-200 Devices ]------
< No T-Koolance TMS-200 Device Found >
Thank you for the data.  It seems to me that the problem is that your CFA634 display is not the CFA634-USB display that is supported by AIDA64.  Our software currently only supports factory USB variants of Crystalfontz displays.  It doesn't support serial displays connected with proprietary (or 3rd party) solutions like what you seem to be using.  Or maybe you have a factory (Crystalfontz made) CFA634 version that predates the CFA634-USB variant that we are aware of?
Hi Fiery...
Sorry i dont know that... what i know is that it is very old... and that i upgraded it from Serial Port to USB with an Adapter Board..
So you think it is not compatible anymore... sad to hear that!
I guess that i have to look for an alternativ LCD Software than LCD Smartie becaus the Aida.ddl is not supported anymore..
i will have to look for a software that can control my LCD and can read Hard/Software sonsors from Aida 64...
Thank you very much for your help!
Hi again!
One more question....
If i buy a newer version of the CF 634  LCD  Display theat works good with the Aida LCD Suoftware..
What do i have to keep in mind? what is important? build version?
would you buy a CF 634 again or preffer another 20x4 lc display?
thx.
On ‎2017‎. ‎10‎. ‎25‎. at 11:43 AM, 4sur5al said:
Hi again!
thx.
If you purchase a USB-connected device from Crystalfontz, it should be supported by AIDA64 right out of the box.  It's up to you to decide which Crystalfontz display is best for your needs.
