Greg Posted October 18, 2017 Posted October 18, 2017 Hello all. I am new to this forum but I've been using Aida64 for a while now. I've just moved over to a Ryzen build and I have noticed that the fan labels (in Stability test) are the wrong way round. "Chassis" is labelled as "CPU" and visa-versa. My mobo is an ASRock A320M-DGS if that helps. I can confirm that my fans are plugged into the correct headers on the board. Is there anything I can configure to correct this? Thank you! Quote
Fiery Posted October 19, 2017 Posted October 19, 2017 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
Greg Posted October 19, 2017 Author Posted October 19, 2017 Thank you Fiery - see attached. Greg isa sensor dump.txt Quote
Fiery Posted October 25, 2017 Posted October 25, 2017 Thank you. We'll implement advanced support for your motherboard in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new AIDA64 beta build is available for download. 1 Quote
Fiery Posted October 27, 2017 Posted October 27, 2017 On 2017. 10. 25. at 10:10 PM, Greg said: Thank you. That is great news. The above mentioned new AIDA64 beta build is now available for download: https://www.aida64.com/downloads/latesta64xebeta 1 Quote
Greg Posted October 27, 2017 Author Posted October 27, 2017 Absolutely brilliant! Works perfectly! Thank you. :-) Quote
