Hi guys.
I'm getting fps drops, crashes, blue screens and i think this is related to my RAM because when i start a stability test it goes perfectly fine until i select system memory. It just stops and says " hardware failure detected test stopped" when i select system memory.  I ran it through memtest but no errors. All of my drivers are up to date, Windows and BIOS as well. I don't know what shall i do. Help.
Sorry for any grammarly mistake.
On 11.12.2017 at 12:20 PM, Fiery said:
Do you overclock your memory, or use special tuning settings for your RAM?
I'm sorry didnt see u replied. Well yeah i use special tuning setting for my RAM because if i dont i cant play any game and this was happening with all stock settings too
Please let me know more about your hardware configuration.  Such as motherboard model, CPU type, RAM type, Windows version, video card(s) model.
MSI B350 Tomahawk (Latest BIOS)
AMD Ryzen 5 1600
MSI GTX 1060 Gaming X 6G
Corsair Vengeance LPX 8GB 2400MHz
CoolerMaster MasterWatt Lite 600W 80+
Windows 10 64 Bit (Latest)
AMD Ryzen 5 1600
Thank you.  Please upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know if it helps.
13 minutes ago, Talha Akbayrak said:
It didn't work but it lastes more now :) Maybe something wrong with my BIOS settings?
It could be.  Have you tried running other memory stress or memory CRC checker tools?  Or generally any other stress testing tool that may also find stability issues.  If the issue can be confirmed by another software, it's definitely something in your hardware configuration, and not a glitch in AIDA64 ;)
7 minutes ago, Talha Akbayrak said:
I don't know any other stress testing tool. Can u tell me one?
Furmark, MemTest86, Prime95 come to mind :)
Alright i'll try when i have free time. Thanks.
By the way i already ran my RAM through memtest86, i didn't encounter any error.
No error with furmark.
