xcite Posted December 10, 2017 Posted December 10, 2017 Hi. I've noticed that after last update some sensor items dissapeared from "LCD Items", and dissaperead very oddly. I didn't checked all items but noticed two of them dissapeared: "CPU Clock" and "GPU Clock". And they dissapeared only under "Graph" and "Gauge" options in items: But they're visisble under "Sensor item" and "Simple sensor item": Quote
Fiery Posted December 11, 2017 Posted December 11, 2017 We've fixed the issue in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
xcite Posted December 13, 2017 Author Posted December 13, 2017 Seems to be okay. Need to check it in next stable release... Quote
Fiery Posted December 18, 2017 Posted December 18, 2017 On 2017. 12. 13. at 8:22 PM, xcite said: Seems to be okay. Need to check it in next stable release... Thank you for your feedback. Quote
