ASUS Gryphon Z97 Missing Fan Speed/Mixed Up Temps
Hello,
My Sensor Panel had been working flawlessly for months and months.   A few days ago my coolant temperature (sourced from T_Sensor3) and MoBo Fan (sourced from Assistant Fan) went missing.
Looking in SensorPanel Manager I found T_Sensor3's data available as Temperature #2 and the Assistant Fan is nowhere to be found.
Those 2 items  appear correct in the Asus ATKEX sections of the attached ISA dump and Sensor Report.
Paul
isasensordump.txt
Sensor Properties.txt
On your particular motherboard, if you have Asus AI Suite installed, AIDA64 will take the sensor readings using the ATKEX API.  But that will only work correctly with AIDA64 as long as you avoid renaming the sensor item labels in AI Suite.
