Greg Posted May 7, 2018 Posted May 7, 2018 Can you help me get the fan speed sensor detected please? This particular model of computer only has a single fan for the whole system (being a tiny machine). Quote
Fiery Posted May 7, 2018 Posted May 7, 2018 17 minutes ago, Greg said: Can you help me get the fan speed sensor detected please? This particular model of computer only has a single fan for the whole system (being a tiny machine). Not all notebooks are able to monitor the fan RPM, but we can give it a try. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. BTW, do you have a factory software (made by Lenovo) that can measure the fan RPM? Or can you see the fan RPM in the BIOS Setup perhaps? Thanks, Fiery Quote
Greg Posted May 7, 2018 Author Posted May 7, 2018 It's not a notebook, but a very small VESA mounting PC; but I guess many/all of the internals are notebook orientated. There is no Lenovo software on my system to measure the speed and the BIOS does not give it either. The BIOS allows me to 3 options: Low Acoustic (low speed until needed), Low Thermal (slightly higher than normal fan) and Full Speed. I will do the ISA sensor dump now... isasensordump.txt Quote
Fiery Posted May 18, 2018 Posted May 18, 2018 On 2018. 05. 07. at 6:47 PM, Greg said: It's not a notebook, but a very small VESA mounting PC; but I guess many/all of the internals are notebook orientated. There is no Lenovo software on my system to measure the speed and the BIOS does not give it either. The BIOS allows me to 3 options: Low Acoustic (low speed until needed), Low Thermal (slightly higher than normal fan) and Full Speed. I will do the ISA sensor dump now... isasensordump.txt Thank you. Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works. 1 Quote
Greg Posted May 20, 2018 Author Posted May 20, 2018 AMAZING!!!! Great work. It shows the fan speed now. Thank you. Quote
Fiery Posted May 30, 2018 Posted May 30, 2018 On 5/20/2018 at 6:43 PM, Greg said: AMAZING!!!! Great work. It shows the fan speed now. Thank you. Thank you for your feedback 1 Quote
goolby Posted November 19, 2019 Posted November 19, 2019 On 5/7/2018 at 6:10 PM, Fiery said: Not all notebooks are able to monitor the fan RPM, but we can give it a try. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. BTW, do you have a factory software (made by Lenovo) that can measure the fan RPM? Or can you see the fan RPM in the BIOS Setup perhaps? Thanks, Fiery Hi, I have a Lenovo ThinkCentre M720q, can fan speed be added to this very small VESA mounting PC? ------[ Versions ]------ Program Version : AIDA64 Extreme v6.10.5224 Beta BenchDLL Version: 4.5.811-x64 Windows Version : Microsoft Windows 10 Education 10.0.18363.476 (64-bit) ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Lenovo 312D Motherboard Chipset : Intel Cannon Point B360, Intel Coffee Lake-S DMI MB Manufacturer : LENOVO DMI MB Product : 312D DMI MB Version : SDK0K17763 WIN 1801944588885 DMI MB Serial : DMI SYS Manufacturer: LENOVO DMI SYS Product : 10T8S95T00 DMI SYS Version : Lenovo product DMI SYS Serial : PC154N4B DMI BIOS Version : M1UKT45A ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h ( 0000h / 0000h) ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h) ITE SuperIO Device ID = 0000h ( 0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 2Eh Winbond SuperIO HWMonitor Port/60 = 0A20h (0A20h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = D441h (D441h / 0000h) Winbond Sensor ID A3/5C/reg$58 = FF / FF / FF Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : <TYPE>0</TYPE><LEN>4</LEN><DATA>3010</DATA> _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : Thanks, John Quote
Fiery Posted November 19, 2019 Posted November 19, 2019 8 minutes ago, goolby said: Hi, I have a Lenovo ThinkCentre M720q, can fan speed be added to this very small VESA mounting PC? ------[ Versions ]------ [...] Thanks, John I'm afraid we cannot figure out how to measure the fan RPM for your particular system Quote
goolby Posted November 19, 2019 Posted November 19, 2019 6 hours ago, Fiery said: I'm afraid we cannot figure out how to measure the fan RPM for your particular system Bad news then , it's really a great tiny system apart for the fan curve that it has. After some time and when the temperature is around 45C the fan goes in this up and down spiral, ramping up and down, up and down... it's driving me crazy! :)) I tried different Bios versions and I had a motherboard swap on warranty but it's still doing the same. I was hoping that I could record the RPM and open a support ticket with Lenovo but there is no app available currently that is able to show fan RPM, it's easy to show than to explain. Oh well, maybe they will fix it in a future Bios version. Thanks for the replay. Quote
