pimp1310 Posted June 24, 2018 Posted June 24, 2018 Hello, i try to set up a LCD sensorpanel on my tablet, first it works but i had much problems, the first: I tried to make a Gauge, under sensorpanel it names "GAUGE" under LCD Panel it names "ARC Gauge ". and unter ARC GAuge i cant choose my own graphics for the Gauge........... Is it not possible?? THX Quote
Fiery Posted June 25, 2018 Posted June 25, 2018 The LCD module doesn't support pre-drawn gauges, but only the on-the-fly generated arc gauge. That's basically the only difference between the otherwise similar SensorPanel module and the External LCD module. Quote
pimp1310 Posted June 25, 2018 Author Posted June 25, 2018 Yeah and this is the Problem, without this ITS Not possible to create nice optical Panels....... Quote
Fiery Posted June 26, 2018 Posted June 26, 2018 22 hours ago, pimp1310 said: Yeah and this is the Problem, without this ITS Not possible to create nice optical Panels....... The regular gauges are not available in the RemoteSensor module due to performance considerations as well as scaling issues. Quote
