Hi,
Why does AIDA show for my ASUS motherboard 61 degrees C, when my CPU temps are only 46 C and 42 C.
Furthermore there are 5 different Motherboard Temperatures: Temp 1:  23C, Temp 2: 24 C, Temp3: 44C and Temp 4: 44C
Where on the motherboard are these 61 C measured ?
When this temp reaches about 76 C the system restarts (after  playing a game like XCom 2, where the GPU temp is not more than 66 C)
I would like to find out where on the board the temps are too high, respectively when and why the system is restarting?
Below a log file, hope this is helpful.
Thank you !
Sensor Eigenschaften
Sensortyp    Nuvoton NCT6776F  (ISA 290h)
GPU Sensortyp    Diode  (NV-Diode)
Motherboard Name    Asus Z9PA-D8 / Z9PE-D8 Series
Gehäusezutritt gefunden    Nein
Temperaturen
Motherboard    61 °C  (142 °F)
CPU1    46 °C  (115 °F)
CPU2    42 °C  (108 °F)
CPU Package    51 °C  (124 °F)
1. CPU / 1. Kern    39 °C  (102 °F)
1. CPU / 2. Kern    40 °C  (104 °F)
1. CPU / 3. Kern    39 °C  (102 °F)
1. CPU / 4. Kern    37 °C  (99 °F)
1. CPU / 5. Kern    36 °C  (97 °F)
1. CPU / 6. Kern    37 °C  (99 °F)
1. CPU / 7. Kern    35 °C  (95 °F)
1. CPU / 8. Kern    37 °C  (99 °F)
1. CPU / 9. Kern    33 °C  (91 °F)
1. CPU / 10. Kern    30 °C  (86 °F)
1. CPU / 11. Kern    34 °C  (93 °F)
1. CPU / 12. Kern    37 °C  (99 °F)
2. CPU / 1. Kern    36 °C  (97 °F)
2. CPU / 2. Kern    34 °C  (93 °F)
2. CPU / 3. Kern    35 °C  (95 °F)
2. CPU / 4. Kern    35 °C  (95 °F)
2. CPU / 5. Kern    36 °C  (97 °F)
2. CPU / 6. Kern    35 °C  (95 °F)
2. CPU / 7. Kern    33 °C  (91 °F)
2. CPU / 8. Kern    35 °C  (95 °F)
2. CPU / 9. Kern    32 °C  (90 °F)
2. CPU / 10. Kern    34 °C  (93 °F)
2. CPU / 11. Kern    30 °C  (86 °F)
2. CPU / 12. Kern    39 °C  (102 °F)
GPU Diode    37 °C  (99 °F)
Temperatur 1 (Motherboard)    23 °C  (73 °F)
Temperatur 2 (Motherboard)    24 °C  (75 °F)
Temperatur 3 (Motherboard)    44 °C  (111 °F)
Temperatur 4 (Motherboard)    44 °C  (111 °F)
CT2000MX500SSD1 (1813E1349A32)    43 °C  (109 °F)
CT2000MX500SSD1 (1803E10B3256)    36 °C  (97 °F)
Kühllüfter
CPU1    1537 RPM
CPU2    1580 RPM
Front #1    1481 RPM
Front #2    1182 RPM
Front #3    1403 RPM
Front #4    1194 RPM
Grafikprozessor (GPU)    1050 RPM  (22%)
Spannungswerte
CPU1 Kern    1.020 V
CPU2 Kern    1.154 V
CPU VID    1.051 V
+3.3 V    3.072 V
+5 V    5.427 V
+12 V    13.128 V
+3.3 V Bereitschaftsmodus    3.054 V
+5 V Bereitschaftsmodus    5.440 V
VBAT Batterie    3.540 V
CPU VTT    1.100 V
CPU1 VCCSA    1.040 V
CPU2 VCCSA    1.068 V
DIMM AB    1.584 V
DIMM CD    1.616 V
DIMM EF    1.584 V
DIMM GH    1.608 V
GPU Kern    0.881 V
Leistungswerte
CPU Package    41.68 W
CPU IA Cores    27.28 W
CPU Uncore    8.72 W
DIMM    5.68 W
GPU TDP%    8%
Debug Info F    164 164 164 164 164
Debug Info T    46 123 42 / 255 40
Debug Info V    00 17 B0 AF 5B FF 5E (03)
Debug Info I    C1 C333
Motherboard ID      : 63-0100-000001-00101111-011113-Chipset$0AMI001_BIOS DATE: 02/10/14 19:54:31 VER: 04.06.05
Motherboard Model   : Asus Z9PE-D8 WS
Motherboard Chipset : Intel Patsburg C602, Intel Ivy Bridge-EP
DMI MB Product      : Z9PE-D8 WS
DMI MB Version      : 1.0x
DMI MB Serial       : 140323883500047
DMI SYS Manufacturer: ASUSTeK COMPUTER INC.
DMI SYS Product     : Z9PE-D8 WS
DMI SYS Version     : 1.0x
DMI SYS Serial      : To be filled by O.E.M.
DMI BIOS Version    : 5404
------[ GPIO @ isa 0500 ]------
0000  C3 F5 0F 1F  C3 7F BB A1  00 00 00 00  FF 7F FB EB
0010  00 00 00 00  00 00 00 00  00 00 04 00  00 00 00 00
0020  00 00 08 00  00 00 00 00  00 00 00 00  01 74 00 00
0030  07 F0 0A 01  34 FF 5E 1E  EF FF FF BF  00 00 00 00
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h     (    0000h /     0000h)
ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h)
ITE SuperIO Device ID      = 0000h     (    0000h /     0000h)
ITE SuperIO Version        = 00h       (      00h /       00h)
Winbond SuperIO Port              = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0290h (0290h / 0000h)
Winbond SuperIO Device ID         = C333h (C333h / 0000h)
Winbond Sensor ID A3/5C/reg$58    = A3 / 5C / C1
ASpeed SuperIO Port = 00h
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------
0000  04 7F 04 7F  01 FF FF FF  FF FF FF FF  FF FF FF FF
0010  04 7F 00 00  00 00 FF FF  00 00 00 00  00 7C 00 00
0020  00 17 B0 AF  5C FF 5E 2E  FF FF FF DA  00 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0040  03 00 40 FF  FF 00 3F FF  2D FF FF FF  18 05 00 A3
0050  FF FF FF FF  FF FF FF FF  C1 FF FF FF  FF 05 04 FF
0060  22 FF FF FF  FF 01 07 FF  FF FF FF FF  FF FF FF FF
0070  00 0A 00 2E  00 7B 80 2A  00 FF FF FF  FF FF FF FF
0080  FF 03 1F 0F  FF 3C 3C 3C  00 00 00 00  00 00 00 00
0090  0A 00 00 00  00 0A 0A 0A  0A AA EF 80  FF 40 46 C4
00A0  0E 01 00 00  FF 00 00 FF  00 00 80 66  66 06 00 01
00B0  00 00 00 00  00 00 2D 00  1C 00 00 34  28 80 C4 FF
00C0  01 00 00 00  00 00 00 00  00 0C 02 FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------
0000  01 00 00 0A  0A 01 01 3C  FF 7F FF FF  00 FF FF FF
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  00 19 23 2D  37 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0030  FF 00 FF FF  00 3C FF FF  00 01 00 00  00 00 00 00
0040  FF FF FF FF  FF A4 00 FF  FF FF FF FF  FF FF 00 FF
0050  7B 80 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
0060  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0090  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------
0000  02 32 02 0A  0A 01 01 3C  FF 7F FF FF  00 FF FF FF
0020  00 28 32 3C  46 FF FF 8C  AA C8 E6 FF  FF FF FF FF
0030  FF 00 FF FF  00 4B FF FF  00 01 00 00  00 00 00 00
0050  2A 00 00 4B  00 50 00 FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------
0000  03 00 00 0A  0A 01 01 3C  FF 7F FF FF  00 FF FF FF
0050  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0020  FF FF FF 96  64 96 64 E1  96 FF FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  3F 00 03 FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  00 13 FF FF  00 00 00 FF  00 FE 1F B3  09 FF FF FF
0060  FF 01 00 00  00 00 00 00  FF FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------
0000  FF FF 00 00  00 00 FF FF  FF FF FF FF  FF 00 00 FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF 00 FF
0050  CA C7 80 FF  00 00 00 00  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 00 07 00  01 FF FF FF  FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------
0000  00 00 FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF 01 02 03  01 01 01 FF  00 00 00 2E  2E 2E 00 FF
0030  FF 1F FF 1F  FF 1F FF 1F  FF 1F 00 00  00 00 00 00
0040  00 00 00 00  02 02 02 FF  FF FF FF FF  FF FF 00 FF
0050  7F 7F 7F 7F  7F 7F 00 A4  00 A4 00 A4  00 A4 00 A4
0070  7F 7F 50 4B  04 7F 7F 50  4B 04 7F 7F  50 4B 04 FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------
0000  FF 95 02 10  00 00 00 00  00 63 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 F8  80 F8 80 F8  80 F8 80 00
0020  28 00 05 00  00 09 00 00  00 EF 00 00  00 00 00 00
0030  00 00 00 FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
   0027 0150 0250 007D 007E 0490 0491 0492 0493 0494 0495 062B 062C 062D 071C 0720
T:   46  123   42  255  255  255  255  255  255  255  255   46   46   46  128   40
   0020 0021 0022 0023 0024 0025 0026 0480 0481 0482 0483 0484 0485 0486 0487 0488 0489 048A 048B 048C 048D 048E 048F
V:  00   17   B0   AF   5C   FF   5E   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.07581 V ]
V:  00   17   B0   AF   5C   FF   5E   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.06079 V ]
V:  00   17   B0   AF   5C   FF   5E   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.03577 V ]
V:  00   17   B0   B0   5C   FF   5E   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.06079 V ]
V:  00   17   B0   B0   5C   FF   5F   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.02075 V ]
V:  00   17   B0   B0   5C   FF   5F   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.07581 V ]
V:  00   17   B0   B0   5C   FF   5F   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.06079 V ]
V:  00   17   B0   B0   5C   FF   5E   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.05078 V ]
V:  00   17   B0   B0   5C   FF   5E   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   FF   [ VID = 1.04578 V ]
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       :
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
------[ 17 SMBuses detected ]------
------[ SMBus #0 ]------
SMBus Type  : Intel ICH
SMBus Port  : B000
Can Have SPD: No
Scan Type   : Full
------[ SMBus Device B00-D18 ]------
  0000  F7 00 00 FF 00 00 00 00 00 17 FF FF FF FF FF FF  ................
  0010  00 00 00 3F 00 00 00 00 FF FF FF FF FF FF FF FF  ...?............
  0020  96 92 00 FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0030  FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0040  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0050  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0060  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0070  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0080  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  FFF7 FF00 FF00 FFFF FF00 FF00 FF00 FF00 FF00 FF17 FFFF FFFF FFFF FFFF FFFF FFFF
  0010  FF00 FF00 FF00 FF3F FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0020  FF96 FF92 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0030  FFFF FFFF FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0040  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0050  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0060  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0070  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0080  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0090  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00A0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00C0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00D0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00E0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00F0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D2D / NCT7904D Bank #0 ]------
  0000  39 43 FF FF FF FF FF FF 00 01 00 FF 5A 50 C5 51
  0010  FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF FF
  0020  FF FF 03 00 FF 00 03 00 03 FF 02 0A 00 02 F0 00
  0030  00 00 00 A0 00 00 68 2A EF 50 00 44 00 DB 0B B3
  0040  44 05 46 03 38 05 40 07 42 04 17 02 63 00 18 07
  0050  65 01 63 01 64 04 6A 03 6A 01 44 05 40 00 49 06
  0060  3F 05 3E 03 00 00 00 00 00 00 FF FF FF FF FF FF
  0070  00 00 FF FF FF FF FF FF FF FF 50 C5 51 FF FF FF
  0080  1B 0A 1B 01 1C 11 23 18 1E 03 23 08 FF 1F FF 1F
  0090  FF 1F FF 1F 00 00 00 00 FF FF FF FF FF FF FF FF
  00A0  2F 00 29 07 00 00 00 00 00 00 00 00 00 00 00 00
  00B0  00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00
  00C0  10 A0 B8 02 00 00 00 00 00 00 40 FF FF 1F 01 FF
  00D0  0F 0F 0F 0F 4F FF 80 00 00 00 00 00 00 0F 00 00
  00E0  00 00 00 00 00 00 FF FF 60 7F 00 60 00 0F 00 00
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00
------[ SMBus Device B00-D2D / NCT7904D Bank #1 ]------
  0000  47 03 38 02 5D 06 25 04 5D 06 25 04 FF 07 00 00
  0010  FF 07 00 00 41 00 25 04 FF 07 00 00 41 00 8A 00
  0020  FF 07 00 00 FF 07 00 00 FF 07 00 00 6B 04 57 07
  0030  6B 04 57 07 44 06 38 02 4B 00 3E 04 4B 00 27 04
  0040  4B 00 3E 04 41 00 8A 00 FF FF FF FF FF FF FF FF
  0060  69 0F 69 0F 00 00 00 00 00 00 FF FF FF FF FF FF
  0080  FF 07 00 00 FF 07 00 00 FF 07 00 00 FF FF FF FF
  0090  54 5F 55 50 54 5F 55 50 54 5F 55 50 54 5F 55 50
  00A0  64 5F 55 50 64 5F 55 50 64 5F 55 50 64 5F 55 50
  00B0  78 73 64 5F 78 73 64 5F 78 73 64 5F 78 73 64 5F
  00D0  4F 00 00 00 00 FF FF FF 00 00 00 00 00 00 00 FF
  00E0  00 00 00 00 FF FF FF FF 01 FF FF FF FF FF FF FF
  00F0  FF FF FF FF 40 01 00 FF 00 00 00 00 00 FF 02 01
------[ SMBus Device B00-D2D / NCT7904D Bank #2 ]------
  0000  B8 41 30 40 01 FF 01 83 63 63 63 63 03 FF 12 62
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0020  00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF
  0030  F3 2F F8 80 F2 9F F8 80 F8 80 F8 80 F8 80 F8 80
  0040  03 B5 00 07 00 00 00 00 F9 F2 F9 FF 05 05 00 00
  0050  00 FF FF FF 00 00 00 00 FF FF FF FF FF FF FF FF
  0060  20 00 00 00 08 00 00 00 00 FF 00 FF 00 00 00 00
  0070  00 00 00 00 FF FF FF FF FF FF 50 C5 51 FF FF FF
  0080  03 10 FF FF 00 00 00 00 63 63 00 00 14 14 00 00
  0090  04 10 04 10 00 00 00 00 00 00 00 00 F3 F3 F3 F3
  00C0  FF 07 FF FF 00 00 00 00 00 00 00 00 00 00 00 FF
  00D0  00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 07
  00E0  00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 07
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02
------[ SMBus Device B00-D2D / NCT7904D Bank #3 ]------
  0000  01 01 08 08 4C 01 01 00 02 05 06 05 06 00 00 00
  0010  FF FF FF FF 84 84 84 84 00 FF FF 00 00 FF FF FF
  0020  60 60 60 60 53 53 53 53 00 00 00 00 14 14 14 14
  0030  1E 1E 1E 50 FF FF FF FF 1E 1E 1E 50 FF FF FF FF
  0040  1E 1E 1E 50 FF FF FF FF 1E 1E 1E 50 FF FF FF FF
  0050  00 80 0F FF FF FF FF FF FF FF FF FF 00 00 00 00
  0060  FF FF FF FF 00 00 00 00 00 00 00 00 FF FF FF FF
  0080  00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF
  0090  00 00 80 00 00 06 FF FF FF FF FF FF FF FF FF FF
  00A0  00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 03
------[ SMBus Device B00-D2D / NCT7904D Bank #4 ]------
  0000  02 02 04 04 00 00 FF FF 05 06 05 06 00 00 FF FF
  0010  60 60 60 60 5A 5A FF FF FF FF FF FF FF FF FF FF
  0020  53 53 53 53 53 53 FF FF FF FF FF FF FF FF FF FF
  0050  19 23 2D 37 8C AA C8 E6 19 23 2D 37 8C AA C8 E6
  0060  FF FF FF FF FF FF FF FF 8C 8C FF FF FF FF FF FF
  0070  FF FF FF FF FF FF FF FF FF FF 50 C5 51 FF FF FF
  0080  FF FF FF FF FF FF FF FF 3C 50 3C 50 3C 50 3C 50
  0090  3C 50 3C 50 3C 50 3C 50 33 33 33 33 33 33 33 33
  00A0  00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00
  00B0  FF FF FF FF 00 00 00 00 00 00 00 00 FF FF FF FF
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 04
------[ SMBus Device B00-D30 ]------
  0000  23 DA E7 60 DA 58 0D 30 10 08 08 FF 18 00 83 00  #..`.X.0........
  0010  05 00 AF 40 40 00 00 00 00 EC 89 A0 20 00 E8 A1  ...@@....... ...
  0020  A9 4C E5 A1 24 4A 04 00 94 D0 8C 6E 6A 00 AA 22  .L..$J.....nj.."
  0030  44 33 B5 18 AA BB 3E 90 43 31 90 AC 00 DD 00 00  D3....>.C1......
  0040  A5 8D 00 00 40 40 40 40 40 40 40 41 41 F0 F1 83  ....@@@@@@@AA...
  0050  D9 83 D9 83 D9 47 02 4A D8 28 D0 1A BA E7 B9 65  .....G.J.(.....e
  0060  F0 18 F0 44 00 00 02 02 00 00 00 F4 7A 00 00 00  ...D........z...
  0070  00 03 00 03 55 C0 D3 BD 00 00 B0 19 3F 00 00 72  ....U.......?..r
  0080  DB EF D1 59 DB 6D D1 E7 B9 79 B9 45 0D 00 03 FF  ...Y.m...y.E....
  0090  01 07 C4 51 DB 00 00 00 00 00 1C 11 1F AD 50 00  ...Q..........P.
  00A0  00 00 00 00 00 00 00 00 00 03 00 00 03 FF 9F 00  ................
  00B0  00 00 0F 00 00 00 00 D3 FF 88 88 01 0F 0A FF 88  ................
  00C0  00 01 01 00 00 C0 00 00 00 00 00 00 00 00 00 80  ................
  00D0  20 00 20 00 80 33 00 00 08 00 01 00 00 00 00 00   . ..3..........
  00E0  00 00 00 15 15 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  2323 DADA E7E7 6060 DADA 5858 0D0D 3030 1010 0808 0808 FFFF 1818 0000 8383 0000
  0010  0505 0000 AFAF 4040 4040 0000 0000 0000 0000 ECEC 8989 A0A0 2020 0000 E8E8 A1A1
  0020  A9A9 4C4C E5E5 A1A1 2424 4A4A 0404 0000 9494 D0D0 8C8C 6E6E 6A6A 0000 AAAA 2222
  0030  4444 3333 B5B5 1818 AAAA BBBB 3E3E 9090 4343 3131 9090 ACAC 0000 DDDD 0000 0000
  0040  A5A5 8D8D 0000 0000 3F3F 3F3F 3F3F 3F3F 4040 4040 4040 4141 3131 F0F0 F1F1 8383
  0050  D9D9 8383 D9D9 8383 D9D9 4646 0202 4D4D D8D8 2929 D0D0 1919 BABA E7E7 B9B9 6A6A
  0060  F0F0 1818 F0F0 4444 0000 0000 0202 0202 0000 0000 0000 F4F4 7A7A 0000 0000 0000
  0070  0000 0303 0000 0303 5555 C0C0 D5D5 BDBD 0000 0000 B0B0 1A1A 3D3D 0000 0000 BBBB
  0080  DBDB E3E3 D1D1 ABAB DBDB 5E5E D1D1 EEEE B9B9 7272 B9B9 4545 0D0D 0000 0303 FEFE
  0090  FFFF 0707 C4C4 5151 DBDB 0000 0000 0000 0000 0000 1C1C 1111 1F1F ADAD 5050 0000
  00A0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0303 0000 0000 0303 FFFF 9F9F 0000
  00B0  0000 0000 0F0F 0000 0000 0000 0000 D3D3 FFFF 8888 8888 0101 0F0F 0A0A FFFF 8888
  00C0  0000 0101 0101 0000 0000 C0C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 8080
  00D0  2020 0000 2020 0000 8080 3333 0000 0000 0808 0000 0101 0000 0000 0000 0000 0000
  00E0  0000 0000 0000 1515 1515 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00F0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D32 ]------
  0000  65 7D F6 18 9F 1F 00 40 F2 08 E6 64 64 FB 00 00  e}.....@...dd...
  0010  05 03 AA C0 C0 00 00 00 00 F8 A0 A8 78 00 E5 A1  ............x...
  0020  2A 4B 14 11 20 CE 00 00 94 AA 2A CB 05 00 A8 26  *K.. .....*....&
  0030  40 30 50 00 A0 38 00 40 52 2F 00 80 00 B1 00 00  @0P..8.@R/......
  0040  FB 00 02 02 3D 3D 3C 3C 3D 3C 3C 3C 93 F2 F3 BF  ....==<<=<<<....
  0050  D9 BF D9 BF D9 3E 02 0E D8 00 D0 00 BB 02 B8 0E  .....>..........
  0060  F0 17 F0 36 36 00 00 00 00 00 00 F9 7C 00 00 00  ...66.......|...
  0070  00 03 00 03 51 22 2B 00 00 00 B0 09 0E 00 00 C3  ....Q"+.........
  0080  D8 00 D0 A8 D8 01 D0 B7 B9 FF BB 50 05 00 01 FF  ...........P....
  0090  01 07 C4 51 9B 00 00 72 00 00 1B 1F 1F AD 50 00  ...Q...r......P.
  00B0  00 00 0F 00 00 00 00 FF FF 88 88 01 0F 0A FF 88  ................
  00D0  00 00 00 00 80 33 00 00 08 00 01 00 00 00 00 00  .....3..........
  00E0  00 00 00 15 15 00 00 00 01 00 00 00 00 01 00 00  ................
  0000  6565 7D7D F6F6 1818 9F9F 1F1F 0000 4040 F2F2 0808 E6E6 6464 6464 FBFB 0000 0000
  0010  0505 0303 AAAA C0C0 C0C0 0000 0000 0000 0000 F8F8 A0A0 A8A8 7878 0000 E5E5 A1A1
  0020  2A2A 4B4B 1414 1111 2020 CECE 0000 0000 9494 AAAA 2A2A CBCB 0505 0000 A8A8 2626
  0030  4040 3030 5050 0000 A0A0 3838 0000 4040 5252 2F2F 0000 8080 0000 B1B1 0000 0000
  0040  FBFB 0000 0202 0202 3D3D 3D3D 3C3C 3C3C 3D3D 3C3C 3C3C 3C3C 9393 F2F2 F3F3 BFBF
  0050  D9D9 BFBF D9D9 BFBF D9D9 3F3F 0202 0D0D D8D8 0000 D0D0 0000 BBBB 0202 B8B8 0D0D
  0060  F0F0 1717 F0F0 3636 3636 0000 0000 0000 0000 0000 0000 F8F8 7C7C 0000 0000 0000
  0070  0000 0303 0000 0303 5151 2222 2B2B 0000 0000 0000 B0B0 0808 0E0E 0000 0000 B6B6
  0080  D8D8 0000 D0D0 A8A8 D8D8 0101 D0D0 D8D8 B9B9 FFFF BBBB 5050 0505 0000 0101 FDFD
  0090  0101 0707 C4C4 5151 9B9B 0000 0000 7272 0000 0000 1B1B 1F1F 1F1F ADAD 5050 0000
  00B0  0000 0000 0F0F 0000 0000 0000 0000 FFFF FFFF 8888 8888 0101 0F0F 0A0A FFFF 8888
  00D0  0000 0000 0000 0000 8080 3333 0000 0000 0808 0000 0101 0000 0000 0000 0000 0000
  00E0  0000 0000 0000 1515 1515 0000 0000 0000 0101 0000 0000 0000 0000 0101 0000 0000
------[ SMBus Device B00-D34 ]------
  0000  65 7D F6 18 9F 1F 00 40 F4 08 E6 64 64 FB 00 00  e}.....@...dd...
  0030  40 30 50 00 A0 38 00 40 52 2F 00 80 00 E7 00 00  @0P..8.@R/......
  0040  FB 00 02 02 40 40 40 40 40 40 3F 3F 73 F4 F5 C7  ....@@@@@@??s...
  0050  D9 C7 D9 C7 D9 40 02 05 D8 00 D0 00 BB 02 B8 01  .....@..........
  0060  F0 05 F0 1F 1F 00 00 00 00 00 00 F8 7B 20 00 00  ............{ ..
  0070  00 03 00 03 51 02 2B 00 00 00 B0 01 03 00 00 47  ....Q.+........G
  0080  D8 00 D0 18 D8 00 D0 AC B8 FF BB 50 05 00 01 05  ...........P....
  0090  02 07 C4 51 DB 00 00 74 00 00 0C 1F 1F AD 50 00  ...Q...t......P.
  0000  6565 7D7D F6F6 1818 9F9F 1F1F 0000 4040 F4F4 0808 E6E6 6464 6464 FBFB 0000 0000
  0030  4040 3030 5050 0000 A0A0 3838 0000 4040 5252 2F2F 0000 8080 0000 E7E7 0000 0000
  0040  FBFB 0000 0202 0202 4040 4040 4040 4040 4040 4040 3F3F 3F3F 7373 F4F4 F5F5 C7C7
  0050  D9D9 C7C7 D9D9 C7C7 D9D9 4141 0202 0505 D8D8 0000 D0D0 0000 BBBB 0202 B8B8 0101
  0060  F0F0 0505 F0F0 1F1F 1F1F 0000 0000 0000 0000 0000 0000 F8F8 7B7B 2020 0000 0000
  0070  0000 0303 0000 0303 5151 0202 2B2B 0000 0000 0000 B0B0 0101 0303 0000 0000 4747
  0080  D8D8 0000 D0D0 1818 D8D8 0000 D0D0 ACAC B8B8 FFFF BBBB 5050 0505 0000 0101 0505
  0090  0101 0707 C4C4 5151 DBDB 0000 0000 7474 0000 0000 0C0C 1F1F 1F1F ADAD 5050 0000
------[ SMBus Device B00-D36 ]------
  0000  26 9D F6 A2 D8 5B F9 30 10 08 08 FF 18 00 83 00  &....[.0........
  0030  44 33 B5 18 AA BB 3E 90 43 31 90 AC 00 F1 00 00  D3....>.C1......
  0040  A8 92 00 00 42 43 43 43 42 42 42 44 F5 F6 F7 8C  ....BCCCBBBD....
  0050  D9 8C D9 8C D9 54 02 32 D8 20 D0 29 B9 F3 B9 49  .....T.2. .)...I
  0060  F0 11 F0 4A 00 00 02 02 00 00 00 2A 95 00 00 00  ...J.......*....
  0070  00 03 00 03 55 C0 A7 C2 00 00 B0 12 2D 00 00 52  ....U.......-..R
  0080  DA 8C D1 51 D9 09 D1 24 BA 56 B9 45 0D 00 03 00  ...Q...$.V.E....
  0090  FC 07 C0 00 99 00 00 06 00 00 13 11 1F AD 50 00  ..............P.
  0000  2626 9D9D F6F6 A2A2 D8D8 5B5B F9F9 3030 1010 0808 0808 FFFF 1818 0000 8383 0000
  0030  4444 3333 B5B5 1818 AAAA BBBB 3E3E 9090 4343 3131 9090 ACAC 0000 F1F1 0000 0000
  0040  ABAB 9292 0000 0000 4242 4242 4242 4343 4343 4242 4141 4444 F1F1 F6F6 F7F7 8C8C
  0050  D9D9 8C8C D9D9 8C8C D9D9 5454 0202 2E2E D8D8 2020 D0D0 2A2A B9B9 F3F3 B9B9 4949
  0060  F0F0 1111 F0F0 4A4A 0000 0000 0202 0202 0000 0000 0000 2929 9595 0000 0000 0000
  0070  0000 0303 0000 0303 5555 C0C0 A7A7 C2C2 0000 0000 B0B0 1212 2D2D 0000 0000 4545
  0080  DADA 8C8C D1D1 5757 DADA 0909 D1D1 9393 BABA 5656 B9B9 4545 0D0D 0000 0303 FFFF
  0090  FCFC 0707 C0C0 1111 9898 0000 0000 0606 0000 0000 1313 1111 1F1F ADAD 5050 0000
------[ SMBus Device B00-D38 ]------
  0040  FB 00 02 02 3F 3F 3E 3E 3E 3E 3D 3D F3 F8 F9 C2  ....??>>>>==....
  0050  D9 C2 D9 C2 D9 40 02 11 D8 00 D0 00 BB 02 B8 11  .....@..........
  0060  F0 0E F0 37 37 00 00 00 00 00 00 24 91 00 00 00  ...77......$....
  0070  00 03 00 03 51 22 2B 00 00 00 B0 0A 08 00 00 E1  ....Q"+.........
  0080  D8 00 D0 C0 D8 00 D0 B4 B9 FF BB 50 05 00 01 00  ...........P....
  0090  04 07 00 11 D8 00 00 78 00 00 15 1F 1F AD 50 00  .......x......P.
  0040  FBFB 0000 0202 0202 3F3F 3F3F 3E3E 3E3E 3E3E 3E3E 3D3D 3D3D F3F3 F8F8 F9F9 C2C2
  0050  D9D9 C2C2 D9D9 C2C2 D9D9 4040 0202 1010 D8D8 0000 D0D0 0000 BBBB 0202 B8B8 1010
  0060  F0F0 0E0E F0F0 3737 3737 0000 0000 0000 0000 0000 0000 2424 9191 0000 0000 0000
  0070  0000 0303 0000 0303 5151 2222 2B2B 0000 0000 0000 B0B0 0A0A 0808 0000 0000 E1E1
  0080  D8D8 0000 D0D0 C0C0 D8D8 0000 D0D0 B4B4 B9B9 FFFF BBBB 5050 0505 0000 0101 F9F9
  0090  0404 0707 4040 0000 D8D8 0000 0000 7878 0000 0000 1515 1F1F 1F1F ADAD 5050 0000
------[ SMBus Device B00-D3A ]------
  0040  FB 00 26 06 40 41 41 40 40 41 40 40 F3 FA FB C8  ..&.@AA@@A@@....
  0050  D9 C8 D9 C8 D9 37 02 05 D8 00 D0 00 BB 02 B8 01  .....7..........
  0060  F0 08 F0 32 32 00 00 00 00 00 00 EF 77 20 00 00  ...22.......w ..
  0070  00 03 00 03 51 02 2B 00 00 00 B0 01 05 00 00 47  ....Q.+........G
  0090  07 07 00 11 D8 00 00 7A 00 00 18 1F 1F AD 50 00  .......z......P.
  0040  FBFB 0000 2626 0606 4040 4141 4141 4040 4040 4141 4040 4040 F3F3 FAFA FBFB C8C8
  0050  D9D9 C8C8 D9D9 C8C8 D9D9 3636 0202 0505 D8D8 0000 D0D0 0000 BBBB 0202 B8B8 0101
  0060  F0F0 0808 F0F0 3232 3232 0000 0000 0000 0000 0000 0000 EFEF 7777 2020 0000 0000
  0070  0000 0303 0000 0303 5151 0202 2B2B 0000 0000 0000 B0B0 0101 0505 0000 0000 4747
  0090  0707 0707 0000 1111 D8D8 0000 0000 7A7A 0000 0000 1818 1F1F 1F1F ADAD 5050 0000
  0000  00 00 00 04 00 00 00 00 00 51 13 12 07 22 07 18  .........Q..."..
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF52 FF13 FF12 FF07 FF22 FF07 FF18
  0010  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0020  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0030  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0040  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0050  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0060  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0070  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0080  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0090  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00A0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00B0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00C0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00D0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00E0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00F0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
------[ SMBus #1 ]------
SMBus Type  : Intel SNB-E/IVB-E/HSW-E/BDW-E
SMBus MMIO  : 00000000-47F78180
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B01-D18 ]------
  0000  EF 00 00 00 10 C8 54 01 01 01 01 15 01 01 FF FF  ......T.........
  0010  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0020  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0030  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  00EF 0000 0000 0000 0610 42C8 0054 2101 0101 6001 A301 2A15 0001 0001 FFFF FFFF
  0010  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0020  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0030  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B01-D50 ]------
  0000  12 0B 01 04 22 00 08 0B 11 01 08 09 00 FC 02 69  ...."..........i
  0010  78 69 28 69 11 10 79 20 08 3C 3C 00 D8 83 01 80  xi(i..y .<<.....
  0020  00 CA 00 00 00 00 00 00 84 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 0F 11 44 09 00  .............D..
  0040  80 B3 63 00 00 50 55 00 00 00 00 00 00 00 00 00  ..c..PU.........
  0070  00 00 00 00 80 AD 01 14 13 10 30 0E 8A A8 3E 48  ..........0...>H
  0080  4D 54 34 32 47 52 37 41 46 52 34 43 2D 52 44 20  MT42GR7AFR4C-RD
  0090  20 54 38 80 AD 00 54 49 34 33 4E 32 30 38 33 49   T8...TI43N2083I
  00A0  30 33 00 01 01 00 01 01 01 20 33 00 00 63 C0 00  03....... 3..c..
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92  ................
------[ SMBus Device B01-D54 ]------
------[ SMBus #2 ]------
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B02-D18 ]------
  0000  EF 00 00 00 10 C0 54 01 01 01 01 96 01 01 FF FF  ......T.........
  0000  00EF 0000 0000 0000 0610 42C0 0054 2101 0101 6001 A201 2796 0001 0001 FFFF FFFF
------[ SMBus Device B02-D50 ]------
  0070  00 00 00 00 80 AD 01 14 13 10 30 05 FC A8 3E 48  ..........0...>H
  0090  20 54 38 80 AD 00 57 49 34 33 4E 32 30 36 35 49   T8...WI43N2065I
  00A0  30 34 00 01 01 00 01 01 01 20 33 00 00 63 C0 00  04....... 3..c..
------[ SMBus Device B02-D54 ]------
------[ SMBus #3 ]------
SMBus MMIO  : 00000000-47F78190
Can Have SPD: No
Scan Type   : Full
------[ SMBus #4 ]------
Can Have SPD: No
Scan Type   : Full
------[ SMBus #5 ]------
SMBus MMIO  : 00000000-47FE8180
Can Have SPD: No
Scan Type   : Full
------[ SMBus #6 ]------
Can Have SPD: No
Scan Type   : Full
------[ SMBus #7 ]------
SMBus MMIO  : 00000000-47FE8190
Can Have SPD: No
Scan Type   : Full
------[ SMBus #8 ]------
Can Have SPD: No
Scan Type   : Full
------[ SMBus #9 ]------
SMBus MMIO  : 00000000-4FF78180
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B09-D18 ]------
  0000  EF 00 00 00 10 E0 54 01 01 01 01 96 01 01 FF FF  ......T.........
  0000  00EF 0000 0000 0000 0610 42DC 0054 2101 0101 6001 A201 2A96 0001 0001 FFFF FFFF
------[ SMBus Device B09-D50 ]------
  0070  00 00 00 00 80 AD 01 14 13 10 30 05 D3 A8 3E 48  ..........0...>H
------[ SMBus Device B09-D54 ]------
------[ SMBus #10 ]------
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B0A-D18 ]------
  0000  EF 00 00 00 10 00 54 01 01 01 01 96 01 01 FF FF  ......T.........
  0000  00EF 0000 0000 0000 0610 4304 0054 2101 0101 6001 A101 2A96 0001 0001 FFFF FFFF
------[ SMBus Device B0A-D50 ]------
  0070  00 00 00 00 80 AD 01 14 13 10 30 0E A9 A8 3E 48  ..........0...>H
------[ SMBus Device B0A-D54 ]------
------[ SMBus #11 ]------
SMBus MMIO  : 00000000-4FF78190
Can Have SPD: No
Scan Type   : Full
------[ SMBus #12 ]------
Can Have SPD: No
Scan Type   : Full
------[ SMBus #13 ]------
SMBus MMIO  : 00000000-4FFE8180
Can Have SPD: No
Scan Type   : Full
------[ SMBus #14 ]------
Can Have SPD: No
Scan Type   : Full
------[ SMBus #15 ]------
SMBus MMIO  : 00000000-4FFE8190
Can Have SPD: No
Scan Type   : Full
------[ SMBus #16 ]------
Can Have SPD: No
Scan Type   : Full
------[ Chips Found ]------
B00-D2D: Nuvoton NCT7904D
B00-D36: CHiL CHL8328
On your motherboard the motherboard temperature comes from the on-board NCT7904D sensor chip.  Other than that, it's not possible to tell in what way that temperature is measured.  Only Asus could tell you that, but I don't think they'd want to reveal that information.
