Bober Posted September 6, 2018 Posted September 6, 2018 I was doing some stress testing for an overclock when AIDA64 showed an error for hardware failure. I got worried about that so I changed my settings back to stock, AIDA at times showed -100000 current and one of the cores drop down to 800MHz very quickly. Should I be worried? Quote
Fiery Posted September 7, 2018 Posted September 7, 2018 -10000 indicates a measurement issue. It could be due to excessive overclocking, but it can also be completely unrelated. Can you see such "hiccups" in current measurement when the CPU is not overclocked or less overclocked? Quote
Bober Posted September 12, 2018 Author Posted September 12, 2018 On 9/7/2018 at 8:50 AM, Fiery said: -10000 indicates a measurement issue. It could be due to excessive overclocking, but it can also be completely unrelated. Can you see such "hiccups" in current measurement when the CPU is not overclocked or less overclocked? I only saw this at stock speeds when I default my BIOS. I now have it clocked at 4.5GHz 1.120v manually, I assume because there is no automatic voltage control the "problem" disappeared. It seemed strange to me to see a negative value on wattage. Quote
Fiery Posted September 12, 2018 Posted September 12, 2018 6 hours ago, Bober said: I only saw this at stock speeds when I default my BIOS. I now have it clocked at 4.5GHz 1.120v manually, I assume because there is no automatic voltage control the "problem" disappeared. It seemed strange to me to see a negative value on wattage. What motherboard do you have? Is it made by Asus? Quote
daimos Posted September 17, 2018 Posted September 17, 2018 No, not only asus, asrock z270 k6 with 7700k stock is here Saw also in internet, that this is common problem: https://youtu.be/A_uZFTY8m5A?t=11m19s Quote
Bober Posted September 18, 2018 Author Posted September 18, 2018 20 hours ago, daimos said: No, not only asus, asrock z270 k6 with 7700k stock is here Saw also in internet, that this is common problem: https://youtu.be/A_uZFTY8m5A?t=11m19s Oh woah ok. It looks like it's constant for you as mine just dropped down occasionally. Quote
Fiery Posted September 18, 2018 Posted September 18, 2018 On 9/12/2018 at 9:51 PM, Bober said: Yes. Asus Strix Z370-F. Thank you. Here's the fix for your motherboard as well as other motherboards that are affected by the same anomaly. https://www.aida64.com/downloads/latesta64xebeta 1 1 Quote
Bober Posted September 19, 2018 Author Posted September 19, 2018 Glad it's just a software problem then. Thought I bricked something haha. Quote
Fiery Posted September 19, 2018 Posted September 19, 2018 10 hours ago, daimos said: Thank you, really working! Thank you for your feedback Quote
