Hello,
Im currently running into alot of problems where AIDA64 Buisness does not find the maximum screen resolution on laptops.
It does show it under Supported Video Modes.
6 minutes ago, Novius said:
Hello,
It's because your displays are not included in the AIDA64 monitor database yet.  We've added this one, but if you have more where it shows "[NoDB]" in the monitor name, please post them as well, and we'll add them too.
  • 4 weeks later...
1 hour ago, Novius said:
Hello,
Okay, is this due to some setup i forgot to do in AIDA? Or why does this problem occour.
Best regards
It's because model/SKU information wasn't encoded in the EDID block of your monitor by the manufacturer of the monitor (AU Optronics in this case).
On 11/28/2018 at 3:40 PM, Fiery said:
Thanks a lot!  We've added this display to AIDA64.
Hello,
When can i start seeing this in my AIDA logs?
Do i need to update something?
20 minutes ago, Novius said:
Hello,
Make sure to always use the latest AIDA64 beta build.  We'll add the one you've posted 3 hours ago in the next AIDA64 beta as well.
  • 4 weeks later...
  • 4 months later...
  • 2 months later...
On ‎9‎/‎20‎/‎2019 at 9:26 AM, Novius said:
The first one lacks the necessary information to detect it properly, but we'll add the second one in the next AIDA64 update due in a day or two.
