fixed: Missing AIO Pump fan sensor reading (Asus Strix X470-F Gaming)
timiman
Using the latest beta (v5.99.4936) for evaluating purposes I cannot find the fan sensor named 'AIOPUMP' in sensors' list.
This sensor is visible and enabled in BIOS.
And visible in other hardware monitoring applications.
Other fans like CPU and Chassis #1-#3 are shown without any problem.
I think this sensor was visible in previous AIDA64 versions, but haven't noted which one was the last 'good' one.
Thank you.
isasensordump.txt
Thank you.
isasensordump.txt
Please upgrade to the latest beta version of AIDA64 available at:
Let me know how it works.
