Ryan Norton Posted January 30, 2019 Posted January 30, 2019 I go to what I can look at and t he only GPU temperature I can monitor relating to GPU is GPU diode not GPU core temperatures or anything of the sort. Quote
Fiery Posted January 30, 2019 Posted January 30, 2019 1 hour ago, Ryan Norton said: I go to what I can look at and t he only GPU temperature I can monitor relating to GPU is GPU diode not GPU core temperatures or anything of the sort. Most video cards only provide a single GPU thermal reading. Quote
Ryan Norton Posted January 30, 2019 Author Posted January 30, 2019 6 hours ago, Fiery said: Most video cards only provide a single GPU thermal reading. Would a GT 1030 not provide GPU core readings? Quote
Fiery Posted January 30, 2019 Posted January 30, 2019 8 minutes ago, Ryan Norton said: Would a GT 1030 not provide GPU core readings? GT1030 only provides a single GPU temperature reading. You can call it "GPU", "GPU Core" or "GPU Diode", it's the same thing for GT1030. The thermal reading is provided by the ForceWare video driver, and measured by an on-die thermal diode located on the GPU die. Quote
Ryan Norton Posted January 30, 2019 Author Posted January 30, 2019 1 hour ago, Fiery said: GT1030 only provides a single GPU temperature reading. You can call it "GPU", "GPU Core" or "GPU Diode", it's the same thing for GT1030. The thermal reading is provided by the ForceWare video driver, and measured by an on-die thermal diode located on the GPU die. So GPU CORE and GPU Diode are the exact same thing? Quote
Fiery Posted January 30, 2019 Posted January 30, 2019 46 minutes ago, Ryan Norton said: So GPU CORE and GPU Diode are the exact same thing? Yes. But it's not relevant how you call it, since GT1030 (just like many other GPUs) have only a single thermal diode on the GPU die. Quote
