Shadowfire Posted January 31, 2019 Report Share Posted January 31, 2019 Hi, Just upgraded Aida64 to the latest version and all the sensor information is now missing. My rather old version (5.70.3800) displays over 15 items (5 fans\10 voltages). Can support for the Supermicro X10sra motherboard be added back in? Thanks in advance, Mark Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 31, 2019 Report Share Posted January 31, 2019 1 hour ago, Shadowfire said: Hi, Just upgraded Aida64 to the latest version and all the sensor information is now missing. My rather old version (5.70.3800) displays over 15 items (5 fans\10 voltages). Can support for the Supermicro X10sra motherboard be added back in? Thanks in advance, Mark It wasn't removed. Try to restart Windows and check the sensor readings again. Quote Link to comment Share on other sites More sharing options...
Shadowfire Posted February 1, 2019 Author Report Share Posted February 1, 2019 Hi Fiery, I've restarted and reinstalled several times. No change. Only GPU\CPU sensors are displayed under Computer->Sensor. No motherboard voltages or fan speeds. Reinstalling v5.70.3800 and everything returns. I can duplicate this on my other machine which has an earlier Supermicro X9sra motherboard. Cheers, Mark Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 4, 2019 Report Share Posted February 4, 2019 On 2/1/2019 at 11:40 PM, Shadowfire said: Hi Fiery, I've restarted and reinstalled several times. No change. Only GPU\CPU sensors are displayed under Computer->Sensor. No motherboard voltages or fan speeds. Reinstalling v5.70.3800 and everything returns. I can duplicate this on my other machine which has an earlier Supermicro X9sra motherboard. Cheers, Mark Using AIDA64 v5.99, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
Shadowfire Posted February 5, 2019 Author Report Share Posted February 5, 2019 Thanks Fiery, Dumps attached. Cheers, Mark isasensordump.txt smbusdump_full.txt Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 5, 2019 Report Share Posted February 5, 2019 3 hours ago, Shadowfire said: Thanks Fiery, Dumps attached. Cheers, Mark isasensordump.txt smbusdump_full.txt Thank you! Please upgrade to the latest beta version of AIDA64 available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote Link to comment Share on other sites More sharing options...
Shadowfire Posted February 6, 2019 Author Report Share Posted February 6, 2019 Perfect! Thanks for your help Fiery! Cheers, Mark Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 8, 2019 Report Share Posted February 8, 2019 On 2/6/2019 at 9:20 PM, Shadowfire said: Perfect! Thanks for your help Fiery! Cheers, Mark Thank you for your feedback! Quote Link to comment Share on other sites More sharing options...
