Thrustir Posted March 24, 2019 Posted March 24, 2019 Can someone please help me determine whats causing the over heating. I looked into this software to determine what was causing my games to studder, and get that odd fps drop but i dont know much about rigs so any pointers that would be greatly appreciated. THANKS! Quote
Fiery Posted March 25, 2019 Posted March 25, 2019 17 hours ago, Thrustir said: Can someone please help me determine whats causing the over heating. I looked into this software to determine what was causing my games to studder, and get that odd fps drop but i dont know much about rigs so any pointers that would be greatly appreciated. THANKS! What subtest(s) do you have enabled in the AIDA64 System Stability Test when it indicates overheating? Quote
IvanDenis Posted January 1, 2020 Posted January 1, 2020 I do have a few questions. I was reading different reviews about Aurora R7 but unable to ge the answers of following: How many m.2 SSD's are supported by the Alienware Aurora R7 motherboard? How to clone the m.2 to another with higher capacity m.2? The secondary 3.5 Hard Drive 2TB can be replaced by a 4TB or 2 TB is the maximun storage? I saw a few Alienware Aurora R7 reviews like this one here https://www.reviewsed.com/alienware-aurora-r7-review/ Though still looking for the answers. Thank you. Quote
Fiery Posted January 8, 2020 Posted January 8, 2020 On 1/1/2020 at 10:51 AM, IvanDenis said: I do have a few questions. I was reading different reviews about Aurora R7 but unable to ge the answers of following: How many m.2 SSD's are supported by the Alienware Aurora R7 motherboard? How to clone the m.2 to another with higher capacity m.2? The secondary 3.5 Hard Drive 2TB can be replaced by a 4TB or 2 TB is the maximun storage? I saw a few Alienware Aurora R7 reviews like this one here Though still looking for the answers. Thank you. I'm afraid we (the developers of AIDA64) don't know the answer to those, but maybe there're other forum users here who would be able to help you out. Quote
glocked89 Posted January 15, 2020 Posted January 15, 2020 On 1/1/2020 at 1:51 AM, IvanDenis said: I do have a few questions. I was reading different reviews about Aurora R7 but unable to ge the answers of following: How many m.2 SSD's are supported by the Alienware Aurora R7 motherboard? How to clone the m.2 to another with higher capacity m.2? The secondary 3.5 Hard Drive 2TB can be replaced by a 4TB or 2 TB is the maximun storage? I saw a few Alienware Aurora R7 reviews like this one here https://www.reviewsed.com/alienware-aurora-r7-review/ Though still looking for the answers. Thank you. I would avoid the Aurora R7 and any Alienware system in general. The R7 has one m.2 slot and its compatibility with the m.2 ssds on the market is quite low. You will have it try different ones out. The hard drive can be replaced by a larger one with no problems. To go further with why I would advise you to steer clear: -Very bad memory compatibility at high speeds/low timings. The motherboard will only boot up with 2933mhz max. -Terrible case layout. The PSU is right up next to the CPU and the GPU is directly below the PSU creating a small hotbox and blocking the airflow from your front intake fan to the top exhaust radiator. -The aio uses only a 120mm radiator which is really too small for the CPUs they're putting in the Aurora R7. They make up for the small radiator by using a jet turbine Nidec 120x35mm 4500rpm fan that regularly reaches 50dba based on your load. -The motherboard is gimped. They bifurcated the PCIe slots to x8 only. Sure you can do SLI/NVLink x8/x8, but if you're sticking to one card you're only getting x8 no matter what. -The alienware overclocking controls have no advanced options. You can only change frequency, voltage, and voltage offset. The same story applies if you enter the BIOS. Its barebones. -Finally, Dell Support Assist is built into the motherboard and you can't disable it! If you want to change your CPU fan to something quieter or better, you will have a forced fan test at boot that lasts for about a minute. You cannot skip it, it is unavoidable. -Bloatware! I'm not sure if is the case with all of them, but I took large latency hits testing with Latencymon. The Aurora series from alienware is not a good deal. They cut corners and use cheap parts. I got suckered into it with my first "premium" PC and I regret it. I will always recommend building your own system. You'll get exactly what you want Quote
