no1yak Posted April 7, 2019 Posted April 7, 2019 HI, Using your latest beta version 5.99.4975. My Samsung 970 Evo plus is showing up twice in the sensor section. My mainboard is an Asus Maximus Hero XI. If I return to your stable version then only one instance of the drive is shown. Regards P. Clayton Quote
Fiery Posted April 7, 2019 Posted April 7, 2019 1 hour ago, no1yak said: HI, Using your latest beta version 5.99.4975. My Samsung 970 Evo plus is showing up twice in the sensor section. My mainboard is an Asus Maximus Hero XI. If I return to your stable version then only one instance of the drive is shown. Regards P. Clayton Yes, it's because we've recently added support for measuring the secondary temperature for NVMe SSDs. In the next AIDA64 beta the two lines will be joined together to avoid confusion. Quote
no1yak Posted April 7, 2019 Author Posted April 7, 2019 Thanks for the reply, not a problem, just curious as to why it showed up twice. Regards P. Clayton Quote
Fiery Posted April 7, 2019 Posted April 7, 2019 1 hour ago, no1yak said: Thanks for the reply, not a problem, just curious as to why it showed up twice. Regards P. Clayton The above mentioned new AIDA64 beta update is now available for download: https://www.aida64.com/downloads/latesta64xebeta Quote
