pbcopter Posted April 12, 2019 Posted April 12, 2019 In AIDA64 Build 4987 beta - CPU temps, Fans, Volts missing with secure boot enabled (just enabled secure boot on this board first time). Build 4983 beta and 4975 beta are okay. All are okay with secure boot disabled. Gigabyte X299-WU8 motherboard running Windows 10 19H1 build 18362.53 Quote
Fiery Posted April 13, 2019 Posted April 13, 2019 8 hours ago, pbcopter said: In AIDA64 Build 4987 beta - CPU temps, Fans, Volts missing with secure boot enabled (just enabled secure boot on this board first time). Build 4983 beta and 4975 beta are okay. All are okay with secure boot disabled. Gigabyte X299-WU8 motherboard running Windows 10 19H1 build 18362.53 Kernel drivers have been updated to make sure they work with Secure Boot enabled at Beta Build 4975. They weren't updated since then, so if you have issues loading the kernel driver with Secure Boot, it must be because you have a stuck old kernel driver somewhere on your system. Such kernel drivers were shipped with AIDA64 Beta Builds 4942 through 4972. Try to remove all instances of AIDA64 from your computer, and scan the drives for files called KERNELD.*, and make sure to remove them all. ALso make sure to backup your settings (AIDA64.INI file) and license (PKEY.TXT file) before uninstalling a certain AIDA64 instance. Quote
pbcopter Posted April 13, 2019 Author Posted April 13, 2019 Yes, it appears that an old version of KERNELD.X64 was located in the folder updated to build 4987. I re-updated from build 4983 and all is well. Thank you. Paul Quote
