Wrong read in CPU-OPT fan speed sensor (ASRock Z270 Taichi)
Why AIDA64 is showing my  CPU-OPT fan speed sensor, which is connected to the pump of cougar helor 360mm, as PSU fan speed?
I think its impossible to read the fan speed of the PSU if it is not connected to the motherboard via USB cable.
25 minutes ago, Fumero said:
Why AIDA64 is showing my  CPU-OPT fan speed sensor, which is connected the pump of cougar helor 360mm, as PSU fan speed?
Here we go
isasensordump.txt
24 minutes ago, Fiery said:
Thank you, we'll fix the issue in the next AIDA64 beta update.  I'll post a message into this topic once the new build is available for download.
Thank you very much.
