im using CORSAIR H100i Platinum RGB.
and also im using AIDA64 Remote Panel.
i bought this liquid cooler few days ago, and i experienced if i set the Addressable RGB mode(like Rainbow effect),
occured H100i cooler USB disconnect- and reconnect issue.
so, i thought it is H100i problem, so i got a new one, but it is same problem occured.
i guess it is software problem,
finally, i figured out this is "AIDA64 conflict H100i Platinum RGB."
first, i reporeted corsair forum. but they are said, it is only can AIDA64 developer.
i dont know who can resolve this issue.
few minute ago, i experienced only Liquid temp is hide bug.
so quickly, i set the Rainbow Effect H100i platinum,
and this issue is not occured.
but i reboot my computer, liquid temp is re showing and same problem occured.
if u can make the Disable for liquid temp option, i think it is can resolve.
can u make this option or you know how to disable liquid temp monitoring?
We will add the requested option called Corsair Hydro Platinum sensor support to the AIDA64 / main menu / File / Preferences / Stability page in the next AIDA64 beta update.  I'll post a message into this topic once the new beta build is available for download.
