Micleo Posted November 5, 2010 Posted November 5, 2010 As you can see on screenshots the temperatures are a bit different. And Speedfan shows (on my opinion) the right temperature, because when the temp. of CPU become 80 degrees it starts beeping but in that case I can still touch the radiator on CPU. Please, correct this mistake. Quote
Fiery Posted November 6, 2010 Posted November 6, 2010 I'm not sure I understand your issue. AIDA64 shows the same 3 temperatures as SpeedFan: AIDA64 "Motherboard" temperature -> Temp2 in SpeedFan AIDA64 "CPU" temperature -> Temp3 in SpeedFan AIDA64 "Aux" temperature -> Temp1 in SpeedFan Do you mean the labelling of the 3 temperatures is incorrect? Shall we rename e.g. "Motherboard" temperature to "CPU"? Or you think "Aux" temperature is the actual CPU temperature? Can you please use Gigabyte's own software (EasyTune6) for a reference? That way we can decide with 100% certainty which temperature is labelled incorrectly in AIDA64. Thanks, Fiery Quote
Micleo Posted November 7, 2010 Author Posted November 7, 2010 I'm not sure I understand your issue. AIDA64 shows the same 3 temperatures as SpeedFan: AIDA64 "Motherboard" temperature -> Temp2 in SpeedFan AIDA64 "CPU" temperature -> Temp3 in SpeedFan AIDA64 "Aux" temperature -> Temp1 in SpeedFan Do you mean the labelling of the 3 temperatures is incorrect? Shall we rename e.g. "Motherboard" temperature to "CPU"? Or you think "Aux" temperature is the actual CPU temperature? Can you please use Gigabyte's own software (EasyTune6) for a reference? That way we can decide with 100% certainty which temperature is labelled incorrectly in AIDA64. Thanks, Fiery You are right. That's my fault. I confused with wrong temperatures that the sensor gave me. I thought Temp1 and Temp2 were the cores 1 & 2. You can delete my post. Quote
Fiery Posted November 7, 2010 Posted November 7, 2010 No problem Thank you for the clarification. Regards, Fiery Quote
