Ryzen 3700X instant crash in FPU test
Hello,
I just build a new System
CPU: Ryzen 3700X, Wraith Prism cooler
MoBo: AsRock Taichi x570
Ram: G.Skill Trident Z 3600 (CL16)
GPU: GTX780 (will be upgraded with a custom 5700xt)
PUS: BeQuiet Dark Power 11 750W 80+Platinum
I enabled the XMP2 Profile for my Ram everything else is stock no OC or anything.
First I noticed a crash in 3DMark TimeSpys CPU Test - my system would just go black and restart, so ne freezes, no bluescreens.
Then I ran AIDA64 in CPU mode - no crashes (10 min Run)
Then I ran the FPU test - crash within seconds, agian no bluescreen just blackscreen and restart
Is this normal for the new Ryzen generation?
Or do I have a defective CPU?
Greetings
NIoSaT
Just now, NIoSaT said:
Hello,
Greetings
NIoSaT
It's not normal at all.  I suspect there's a power delivery issue that prevents your CPU from working stable under heavy load.  My first move would be to try to get a replacement (or borrow one) PSU and check if it makes a difference.
Thanks for the quick answer!
I will try to find another PSU to test.
But I did another test with Ryzen Master open, there I can see the Wattage, Current etc.
Wattage and Current seemed well within range, but the temps were rising quite steeply and I stopped the test at 90° CPU Temp
Could the temps be the problem?
--UPDATE--
I now lowered my RAM Speeds - I disabled the XMP2.0 Profile
Now it seems stable - no crashes so far in TimeSpy and I could run the FPU Test in AIDA64 for 5 Minutes wihout a crash (at 93°C)
But should my RAM/System not be able to run with its XMP Profile?
Or are the XMP Profiles generally "bad" or less stabel than an manual OC?
On ‎8‎/‎12‎/‎2019 at 1:12 AM, NIoSaT said:
--UPDATE--
Not all RAM and motherboard combinations will work with the XMP profile.  You may need to manually tweak the memory timings and DRAM voltage settings to make it stable.
I am playing with the settings a bit at the moment.
I can get it stable in normal windows usage and I get no errors in Ram test, even for hours.
One other Idea I found is that it could be the Infintiy Fabric that is unstable, this would explain why dedicated Ram tests don't show any errors but I still get crashes under load.
AFAIK lowering DRAM clock will also put less stress on the Infinity Fabric.
