In server tab > logon screen, I can see the same user repeated twice.
(i.e. I logged with username Rafael, but in logon screen I see two users named Rafael, with the same Logon Server RAFAEL-7 and the same Logon Domain Rafael-7).
Why this repetition? A username should be univocal.
Thank you.
On Windowx XP and Windows 7 systems we can see only a single entry. Do you use Windows 7 or Windows Server 2008 or Windows Server 2008 R2? Your computer is not logged into a domain, is it?
My pc is part of a local area network. For home purposes.
OS in question is Windows 7 x64 Ultimate.
Edit: with netplwiz command I can see a window reporting me that my username account is associated to Homeusers and Administrators group.
This could explain the behavior? Personally I don't like & use Windows 7 Home Group. Maybe this has been done automatically by Win7.
Hope this helps.
Hope this helps.
That's a normal to have the user associated to both those groups.
