crickebones Posted August 31, 2011 Posted August 31, 2011 I had a temp sensor which I used to sense the ambient temperature of my room. It was taped to the side of my case. I recently switched cases and did not attach this sensor yet. The OSD now has a ghost temp that reports nothing and will not disappear. This happens when i remove fans I had monitored as well. Happens when I do not untick these things from the option menu before removing. Quote
Fiery Posted September 12, 2011 Posted September 12, 2011 In certain unfortunate cases such issues may happen due to a glitch in the hardware monitoring module of AIDA64. We'll try to improve that in AIDA64 v2.00 that is due in a few months. Until then, if you can identify which item is it, you can manually edit the AIDA64.INI file, and remove the OSD item(s) that cause the issues. I know it's not a sophisticated method though Regards, Fiery Quote
