Lawrence Posted October 13, 2019 Posted October 13, 2019 Hi, 1) How can I check the voltage of the CMOS baterry, without extracting it from the PC ( a software )? 2) The steps to replace a CMOS baterry ? How I extract it from the PC ? Thank you Quote
Fiery Posted October 14, 2019 Posted October 14, 2019 20 hours ago, Lawrence said: Hi, 1) How can I check the voltage of the CMOS baterry, without extracting it from the PC ( a software )? 2) The steps to replace a CMOS baterry ? How I extract it from the PC ? Thank you On some (but not all) systems AIDA64 reports the CMOS battery voltage as VBAT Battery voltage on the Computer / Sensor page. If it's not there, you need to try to find it in the BIOS Setup. In there it's usually shown on the PC Health Status page or H/W Monitor page. Replacing it requires a full power-down of the PC. Disconnect the power cord as well. You can remove the battery without any tools and virtually any CR2032 battery can be used as a replacement. Make sure to check the old battery though after removing it, that it's really a CR2032 part. Quote
