fixed: Temperature sensor with aquasuite X.5 does not appear (farbwerk)
Since updating to aquasuite X.5, information from the temperature sensor connected to the aquacomputer parbwerk is not output to aida64.
The same is true of the latest beta version of aida64.
In addition, the power consumption of the rtx 2080 super graphics card is not displayed in aida64 as a watt (displayed as TDP % only).
We will fix the issues coming up about Aqua Computer devices due to the latest firmware upgrade in the next AIDA64 beta update.
As for power consumption, it is a calculated value (based on the TDP of the video card) and not a measured value as it is displayed in other tools like GPU-Z.  If you know the TDP of your video card, you can use the Correction facility (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction) to apply the TDP as the Ratio to end up having the same calculated value as in other monitoring software.
Thank you for relply!
2 hours ago, bluechopa said:
I updated it but it still doesn't show up. :(
Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aqua Computer Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Also right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
here you are. thanks relpy
aquacomputerdump.txt usbdump.txt
On ‎10‎/‎18‎/‎2019 at 12:24 PM, bluechopa said:
Thank you!  Make sure to upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know if it helps.
18 hours ago, bluechopa said:
WOW!
The problem is finally solved! Thank you very much for the quick update!
Thank you for your help and feedback!
