Undermoose Posted September 26, 2011 Posted September 26, 2011 My old mobo used to give me SMART details for each individual drive in my raid set. Not this one? Quote
Undermoose Posted September 27, 2011 Author Posted September 27, 2011 I was wondering because I'm in raid mode and didn't see an option. The trick is to put it in IDE mode, enable S.M.A.R.T. and save bios settings, then enter back into the bios and turn raid back on. S.M.A.R.T. information was available in AIDA64 after this change on my two raid sets. Quote
Fiery Posted September 27, 2011 Posted September 27, 2011 You need to enable RAID SMART support in AIDA64 / main menu / File / Preferences / Stability. Make sure to restart AIDA64 after altering that option. Regards, Fiery Quote
Undermoose Posted September 27, 2011 Author Posted September 27, 2011 Hey thanks Fiery, I got that part years ago lol , but that's a very important part to clarify of course thank you. For this mobo, the problem was the SMART option in this motherboard's setup is hidden when you select RAID mode on the storage controller, however if you set it to IDE the option becomes visible and you can enable it and then change back to raid mode. Quote
