fixed: Wrong CPU Temperature in stress test (153°C)
On 12/8/2019 at 9:22 PM, tweestr said:
Hi!
My bug is like https://forums.aida64.com/topic/221-wrong-cpu-temperature-asus-m4a88td-m/
CPU Xeon e-5 2689, noname Chinese motherboard, Win 10 Pro x64, AIDA v.6.20.5300
I'm not sure that I can be helped, but thanks anyway. And sorry for my english :)
We'll remove the bogus CPU thermal reading in the next AIDA64 beta update.
  • Thanks 1
Thanks! The problem is resolved.
Great user support!
But during the stress test, anyway, the PC operation is completed by the BSOD. I thought this was because the sensor showed the extreme temperature of the CPU.
Probably, PC on Chinese components is not capable of stress tests :D
Great user support!
That could well be due to an only 99% stable configuration :) It happens to US designed motherboards as well ;)
