Hi,
i found bug in writing sensor values to WMI. It is related to do external hard drive. It shows correct values when hard drive is connected to PC but when you unplug it then WMI still shows last temperature value even if you turn off application and turn on it again without the drive. I use WMI with Samurize software. Any chance to fix that?
Best regards
Thanks for your reply. Latest beta did not solve the problem. But it is little better. If you have AIDA64 running and you disconnect external hard drive then temperature still freeze in last value. If you close AIDA and run it again then in first secon last remembered temperature value is showing than change to 0. It would be great if AIDA64 can change temperature to 0 after hard drive discconect when application is running how it was few betas ago. Thank you.
  • 4 weeks later...
