Squall Leonhart Posted October 7, 2011 Posted October 7, 2011 On all versions past 1632 (1632 being the last to work properly) This is not all thats missing, but i didn't want to fill the page with screenshots missing sensor items also include Mhz, GPU VPU and MC Voltages including gpu CPU Usage Temps including gpu and vram FAN RPMs including the GPU fan. Quote
Fiery Posted October 7, 2011 Posted October 7, 2011 Have you tried to restart your computer after upgrading to the new release? Quote
Squall Leonhart Posted October 7, 2011 Author Posted October 7, 2011 Yes, i rebooted, then i replaced the old version and it worked again, and switched back and it still didn't. i would surmise the nahalem fxes for windows 8 may have broken something, as a fellow windows 7 user with an x38 had no problems with the upgrade. i should note he didn't reboot :\ it appears to be the aida application itself, using the newer files with the 1632 exe works fine. Quote
Squall Leonhart Posted October 8, 2011 Author Posted October 8, 2011 It seems something (maybe the nahalem fixes on windows 8) has broken the ability to detect info on the sm and isa buses Quote ------[ AIDA64 v1.85.1647 Beta ]------------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus Rampage II Gene Motherboard Chipset : Intel Tylersburg X58 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : Rampage II GENE DMI MB Version : Rev 2.xx DMI MB Serial : MS1C92BJDZ01491 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : ------[ 0 SMBuses detected ]------ Quote ------[ AIDA64 v1.85.1647 Beta ]------------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus Rampage II Gene Motherboard Chipset : Intel Tylersburg X58 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : Rampage II GENE DMI MB Version : Rev 2.xx DMI MB Serial : MS1C92BJDZ01491 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = 0000h Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = 0000h ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : Quote ------[ AIDA64 v1.85.1647 Beta ]------------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus Rampage II Gene Motherboard Chipset : Intel Tylersburg X58 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : Rampage II GENE DMI MB Version : Rev 2.xx DMI MB Serial : MS1C92BJDZ01491 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : ------[ PCI Devices ]------ B02-D00-F00 [10DE-05E6] [3842-1171] [CC0300]: EVGA e-GeForce GTX 275 Video Adapter B00-D1F-F02 [8086-3A22] [1043-82D4] [CC0101]: Intel 82801JB ICH10 - 6-port SATA AHCI Controller B05-D00-F00 [1106-3403] [1043-8384] [CC0C00]: VIA OHCI Compliant IEEE 1394 Host Controller B06-D00-F00 [10EC-8168] [1043-82C6] [CC0200]: Realtek RTL8168C/8111C PCI-E Gigabit Ethernet Adapter B08-D00-F00 [1102-0005] [415A-0034] [CC0480]: Auzentech X-Fi Prelude 7.1 Sound Card B00-D00-F00 [1103-2210] [FBF0-90DC] [CC0000]: HighPoint RocketRAID 2210 PCI-X SATA-II RAID Controller B00-D1B-F00 [8086-3A3E] [1043-82EA] [CC0403]: Intel 82801JB ICH10 - High Definition Audio Controller B00-D00-F00 [8086-3405] [1043-836B] [CC0800]: HighPoint RocketRAID 2210 PCI-X SATA-II RAID Controller B00-D14-F02 [8086-3423] [0000-0000] [CC0800]: Intel Tylersburg Chipset - IOH Control/Status and RAS Registers [b-2] B00-D14-F01 [8086-3422] [0000-0000] [CC0800]: Intel Tylersburg Chipset - Scratchpad/GPIO Registers [b-2] B00-D01-F00 [8086-3408] [1043-836B] [CC0604]: Intel Tylersburg Chipset - PCI Express Root Port 1 (x4/x2) [b-2] B00-D03-F00 [8086-340A] [1043-836B] [CC0604]: Intel Tylersburg Chipset - PCI Express Root Port 3 (x16/x8/x4) [b-2] B00-D07-F00 [8086-340E] [1043-836B] [CC0604]: Intel Tylersburg Chipset - PCI Express Root Port 7 (x16/x8/x4) [b-2] B00-D14-F00 [8086-342E] [0000-0000] [CC0800]: Intel Tylersburg Chipset - System Management Registers [b-2] B00-D14-F03 [8086-3438] [0000-0000] [CC0800]: Intel Tylersburg Chipset - Throttle Registers [b-2] B00-D1E-F00 [8086-244E] [1043-82D4] [CC0604]: Intel 82801JB I/O Controller Hub 10 (ICH10) [A-0] B00-D1C-F00 [8086-3A40] [1043-82EA] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 1 B00-D1C-F02 [8086-3A44] [1043-82EA] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 3 B00-D1C-F03 [8086-3A46] [1043-82EA] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 4 B00-D1C-F04 [8086-3A48] [1043-82EA] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 5 B00-D1F-F03 [8086-3A30] [1043-82D4] [CC0C05]: Intel 82801JB ICH10 - SMBus Controller B00-D1F-F00 [8086-3A16] [1043-82D4] [CC0601]: Intel 82801JB ICH10R - LPC Bridge B00-D1D-F07 [8086-3A3A] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB2 Enhanced Host Controller B00-D1A-F07 [8086-3A3C] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB2 Enhanced Host Controller B00-D1D-F00 [8086-3A34] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1D-F01 [8086-3A35] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1D-F02 [8086-3A36] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1A-F00 [8086-3A37] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1A-F01 [8086-3A38] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1A-F02 [8086-3A39] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B02 D00 F00: EVGA e-GeForce GTX 275 Video Adapter Offset 000: DE 10 E6 05 00 00 00 00 A1 00 00 03 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 42 38 71 11 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1F F02: Intel 82801JB ICH10 - 6-port SATA AHCI Controller Offset 000: 86 80 22 3A 00 00 00 00 00 00 01 01 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B05 D00 F00: VIA OHCI Compliant IEEE 1394 Host Controller Offset 000: 06 11 03 34 00 00 00 00 00 00 00 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 84 83 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B06 D00 F00: Realtek RTL8168C/8111C PCI-E Gigabit Ethernet Adapter Offset 000: EC 10 68 81 00 00 00 00 02 00 00 02 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 C6 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B08 D00 F00: Auzentech X-Fi Prelude 7.1 Sound Card Offset 000: 02 11 05 00 00 00 00 00 00 00 80 04 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 5A 41 34 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D00 F00: HighPoint RocketRAID 2210 PCI-X SATA-II RAID Controller Offset 000: 03 11 10 22 00 00 00 00 01 00 00 00 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 F0 FB DC 90 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1B F00: Intel 82801JB ICH10 - High Definition Audio Controller Offset 000: 86 80 3E 3A 00 00 00 00 00 00 03 04 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EA 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D00 F00: HighPoint RocketRAID 2210 PCI-X SATA-II RAID Controller Offset 000: 86 80 05 34 00 00 00 00 12 00 00 08 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 6B 83 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F02: Intel Tylersburg Chipset - IOH Control/Status and RAS Registers [b-2] Offset 000: 86 80 23 34 00 00 00 00 12 00 00 08 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F01: Intel Tylersburg Chipset - Scratchpad/GPIO Registers [b-2] Offset 000: 86 80 22 34 00 00 00 00 12 00 00 08 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D01 F00: Intel Tylersburg Chipset - PCI Express Root Port 1 (x4/x2) [b-2] Offset 000: 86 80 08 34 00 00 00 00 12 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 6B 83 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D03 F00: Intel Tylersburg Chipset - PCI Express Root Port 3 (x16/x8/x4) [b-2] Offset 000: 86 80 0A 34 00 00 00 00 12 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 6B 83 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D07 F00: Intel Tylersburg Chipset - PCI Express Root Port 7 (x16/x8/x4) [b-2] Offset 000: 86 80 0E 34 00 00 00 00 12 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 6B 83 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F00: Intel Tylersburg Chipset - System Management Registers [b-2] Offset 000: 86 80 2E 34 00 00 00 00 12 00 00 08 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F03: Intel Tylersburg Chipset - Throttle Registers [b-2] Offset 000: 86 80 38 34 00 00 00 00 12 00 00 08 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1E F00: Intel 82801JB I/O Controller Hub 10 (ICH10) [A-0] Offset 000: 86 80 4E 24 00 00 00 00 90 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1C F00: Intel 82801JB ICH10 - PCI Express Root Port 1 Offset 000: 86 80 40 3A 00 00 00 00 00 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EA 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1C F02: Intel 82801JB ICH10 - PCI Express Root Port 3 Offset 000: 86 80 44 3A 00 00 00 00 00 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EA 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1C F03: Intel 82801JB ICH10 - PCI Express Root Port 4 Offset 000: 86 80 46 3A 00 00 00 00 00 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EA 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1C F04: Intel 82801JB ICH10 - PCI Express Root Port 5 Offset 000: 86 80 48 3A 00 00 00 00 00 00 04 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EA 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1F F03: Intel 82801JB ICH10 - SMBus Controller Offset 000: 86 80 30 3A 00 00 00 00 00 00 05 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1F F00: Intel 82801JB ICH10R - LPC Bridge Offset 000: 86 80 16 3A 00 00 00 00 00 00 01 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1D F07: Intel 82801JB ICH10 - USB2 Enhanced Host Controller Offset 000: 86 80 3A 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1A F07: Intel 82801JB ICH10 - USB2 Enhanced Host Controller Offset 000: 86 80 3C 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1D F00: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 34 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1D F01: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 35 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1D F02: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 36 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1A F00: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 37 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1A F01: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 38 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1A F02: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 39 3A 00 00 00 00 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ SMBus Ctrl / C @ B00 D1F F03 ]------ Offset 000: 86 80 30 3A 00 00 00 00 00 00 05 0C 00 00 00 00 ..0:............ Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 ............C... Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Ctrl / NC @ B00 D1F F03 ]------ Offset 000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ !!! Weird SMBus I/O Base = 0000 !!! Quote
Squall Leonhart Posted October 8, 2011 Author Posted October 8, 2011 here is a healthy smbus dump Quote ------[ AIDA64 v1.85.1632 Beta ]------------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 65-1501-000001-00101111-032211-TYLERSBURG$A1234000_BIOS DATE: 03/22/11 16:36:18 VER: 08.00.15 Motherboard Model : Asus Rampage II Gene Motherboard Chipset : Intel Tylersburg X58, Intel Nehalem DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : Rampage II GENE DMI MB Version : Rev 2.xx DMI MB Serial : MS1C92BJDZ01491 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 1501 ------[ GPIO @ isa 0500 ]------ 0000 C3 F5 7D 19 83 2E DF E0 00 00 00 00 FF EC FE F7 0010 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 0020 00 00 08 00 00 00 00 00 00 00 00 00 82 24 00 00 0030 FF 00 03 03 CF FF 54 0E CF FF F4 1D 00 00 00 00 ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel ICH SMBus Port : 0400 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D20 ]------ 0000 FF 80 17 7F FF FF FF FF FF FF FF FF FF FF FF FF ............... 0010 00 FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF ................ 0020 20 00 FF FF FF 20 B2 FF FF FF FF FF FF FF FF FF .... .......... 0030 FF FF FF FF FF FF FF FF 74 03 FF FF FF FF FF FF ........t....... 0040 FF FF FF FF FF FF FF FF FF FF 99 FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF 2C FF FF FF FF FF ..........,..... 0070 FF FF FF FF FF FF FF FF 02 08 00 00 FF FF 80 FF ................ 0080 00 FF FF FF FF FF FF FF FF FF FF 38 EC FF FF FF ...........8.... 0090 FF FF FF FF FF FF AE FF FF 41 98 01 FF FF FF FF .........A...... 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 00 03 72 72 03 02 01 85 49 00 00 00 00 00 00 00 ..rr....I....... 00E0 00 00 10 10 10 10 10 10 10 10 10 FF 07 FF 00 00 ................ 00F0 FF 11 FF FF FF 01 02 FF FF CD C0 10 FF FF FF FF ................ ------[ SMBus Device B00-D20 ]------ 0000 FFFF 3780 6617 FF7F FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 7700 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 54B0 FFFF FFFF FFFF FFFF FFFF FFFF 0020 7620 0000 FFFF FFFF FFFF 0020 00B2 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0074 0003 FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0099 FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 012C FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ED02 0208 3500 5E00 FFFF FFFF 1982 FFFF 0080 DE00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0038 DA45 FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF DADD FFFF FFFF 8641 3298 9701 FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FA00 9803 7572 1E72 5803 3402 8001 BA85 BA49 C000 7D00 1600 0000 6B00 D600 BD00 00E0 1B00 7000 BD10 D610 C010 AB10 1610 7D10 3A10 5110 EC10 FFFF F407 FFFF 3700 5C00 00F0 4AFF B717 FFFF FFFF FFFF 7E01 0002 FFFF FFFF EECD 70C0 2510 B0FF FFFF FFFF FFFF ------[ SMBus Device B00-D30 ]------ 0000 03 00 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF 00 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF 00 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF 00 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D30 ]------ 0000 0003 0000 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 00FF 0000 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 00FF 0000 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 00FF 0000 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D32 ]------ 0000 03 40 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF .@.............. 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF 40 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF .@.............. 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF 40 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF .@.............. 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF 40 00 C0 00 00 C0 00 FF FF FF FF FF FF FF FF .@.............. 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D32 ]------ 0000 4003 0040 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 40FF 0040 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 40FF 0040 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 40FF 0040 C000 00C0 FF00 FF00 FFC0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D37 ]------ 0000 02 00 38 38 41 00 00 00 00 00 00 00 00 00 00 00 ..88A........... 0010 00 00 FF 0F 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 03 00 83 12 12 28 00 00 00 00 ...........(.... 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D37 ]------ 0000 0002 3800 3838 4138 0041 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0010 0000 FF00 0FFF 000F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0020 0000 0000 0000 0000 0000 0300 0003 8300 1283 1212 2812 0028 0000 0000 0000 0000 0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0200 ------[ SMBus Device B00-D38 ]------ 0000 FF 72 7D 58 89 72 58 FF FF FF FF 00 00 FF FF FF .r}X.rX......... 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 00 FF FF FF C8 00 51 00 00 42 00 FF FF 04 00 FF ......Q..B...... 0040 FF FF FF FF FF 20 FF FF 00 FF FF FF 00 FF FF FF ..... .......... 0050 00 00 00 00 00 00 FF FF FF FF FF 00 FF FF FF FF ................ 0060 FF 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF 27 7F 61 00 08 A2 ..........'a... 0090 E9 04 76 06 8C 04 E4 05 1B 04 E4 05 93 05 E2 04 ..v............. 00A0 00 04 3E 07 63 07 9E 07 FF FF FF FF 46 00 FF FF ..>.c.......F... 00B0 FF 85 01 09 28 00 00 00 00 FF FF FF FF FF FF FF ....(........... 00C0 FF 00 00 00 04 00 00 00 00 A0 FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D38 ]------ 0000 FFFF 7272 7D7D 5858 8989 7272 5858 FFFF FFFF FFFF FFFF 0000 0000 FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 0000 FFFF FFFF FFFF C8C8 0000 5151 0000 0000 4242 0000 FFFF FFFF 0404 0000 FFFF 0040 FFFF FFFF FFFF FFFF FFFF 2020 FFFF FFFF 0000 FFFF FFFF FFFF 0000 FFFF FFFF FFFF 0050 0000 0000 0000 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF 0000 FFFF FFFF FFFF FFFF 0060 FFFF 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 2727 7F7F 6161 0000 0808 A2A2 0090 E2E2 0404 7676 0606 8C8C 0404 DDDD 0505 1B1B 0707 E4E4 0505 9393 0404 E2E2 0404 00A0 0000 0000 3E3E 0404 6363 0707 9A9A 0707 FFFF FFFF FFFF FFFF 4646 0000 FFFF FFFF 00B0 FFFF 8585 0101 0909 2828 0000 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF 0000 0000 0000 0404 0000 0000 0000 0000 A0A0 FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D40 ]------ 0000 FF FF FF FF FF FF FF 00 00 FF FF FF FF FF FF FF ................ 0010 FF 64 64 5A 64 64 64 FF FF FF FF FF FF FF FF FF .ddZddd......... 0020 FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 00 00 00 97 FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF 10 78 14 00 56 EC ...........x..V. 0090 7F 07 EB 06 00 00 00 00 FF FF FF FF FF FF FF FF ............... 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 2E 34 38 22 00 2B A8 FF FF FF FF FF FF 00 70 00 .48".+........p. 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D40 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF 6464 6464 5A5A 6464 6464 6464 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 0000 0000 0000 9797 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 1010 7878 1414 0000 5656 ECEC 0090 7F7F 0707 EBEB 0606 0000 0000 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 2E2E 3434 3838 2222 0000 2B2B A8A8 FFFF FFFF FFFF FFFF FFFF FFFF 0000 7070 0000 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D44 ]------ 0000 00 00 00 04 00 00 00 00 00 48 14 11 06 08 10 11 .........H...... 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF49 FF14 FF11 FF06 FF08 FF10 FF11 0010 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0020 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0030 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0040 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0050 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0070 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0080 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 0090 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00A0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00B0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00C0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00D0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00E0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 00F0 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 ------[ SMBus Device B00-D4E ]------ 0000 02 00 32 32 46 00 00 00 00 00 00 00 00 00 00 00 ..22F........... 0010 00 00 FF 0F 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 03 00 83 12 12 28 00 00 00 00 ...........(.... 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D4E ]------ 0000 0002 3200 3232 4632 0046 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0010 0000 FF00 0FFF 000F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0020 0000 0000 0000 0000 0000 0300 0003 8300 1283 1212 2812 0028 0000 0000 0000 0000 0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0040 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0200 ------[ SMBus Device B00-D50 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 09 0D 00 00 00 00 5B 11 ..............[. 0080 43 4D 33 58 32 47 31 36 30 30 43 38 44 20 20 20 CM3X2G1600C8D 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 0C 4A 11 12 01 08 01 08 00 2D 0A 50 14 00 50 50 .J.......-.P..PP 00C0 50 78 10 F0 95 3E 00 70 03 3C 3C 01 2C 3C 00 00 Px...>.p.<<.,<.. 00D0 10 00 27 00 00 00 00 00 00 00 00 00 00 00 00 00 ..'............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D52 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 09 0D 00 00 00 00 5B 11 ..............[. 0080 43 4D 33 58 32 47 31 36 30 30 43 38 44 20 20 20 CM3X2G1600C8D 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 0C 4A 11 12 01 08 01 08 00 2D 0A 50 14 00 50 50 .J.......-.P..PP 00C0 50 78 10 F0 95 3E 00 70 03 3C 3C 01 2C 3C 00 00 Px...>.p.<<.,<.. 00D0 10 00 27 00 00 00 00 00 00 00 00 00 00 00 00 00 ..'............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D54 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 34 00 .........R....4. 0010 6C 78 6C 3C 6C 11 20 95 70 03 3C 3C 01 2C 83 81 lxl<l. .p.<<.,.. 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 1F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 02 9E 01 09 0D 00 00 00 00 5B 11 ..............[. 0080 43 4D 33 58 32 47 31 36 30 30 43 38 44 20 20 20 CM3X2G1600C8D 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 0C 4A 11 12 01 08 01 08 00 2D 0A 50 14 00 50 50 .J.......-.P..PP 00C0 50 78 10 F0 95 3E 00 70 03 3C 3C 01 2C 3C 00 00 Px...>.p.<<.,<.. 00D0 10 00 27 00 00 00 00 00 00 00 00 00 00 00 00 00 ..'............. 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ Chips Found ]------ B00-D20: ON ASP0800 (Asus EPU2) B00-D52: SPD ISA Bus Quote ------[ AIDA64 v1.85.1632 Beta ]------------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 65-1501-000001-00101111-032211-TYLERSBURG$A1234000_BIOS DATE: 03/22/11 16:36:18 VER: 08.00.15 Motherboard Model : Asus Rampage II Gene Motherboard Chipset : Intel Tylersburg X58, Intel Nehalem DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : Rampage II GENE DMI MB Version : Rev 2.xx DMI MB Serial : MS1C92BJDZ01491 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 1501 ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 2Eh Winbond SuperIO HWMonitor Port = 0290h Winbond SuperIO Device ID = A513h Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1 Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0290 ]------ 0000 04 FF 04 FF 00 00 28 20 01 9B 01 01 3C 3C 04 04 0010 04 FF 30 00 00 01 01 3C 43 17 00 00 2D FF FF D9 0020 9D D7 D0 CE CB FF A2 23 FF 4E FF DA 00 04 03 03 0030 84 35 C0 14 42 0C 18 C2 80 21 12 11 05 24 65 FF 0040 03 FE 00 FF FF 00 3F 35 2D 24 80 C0 90 95 00 A3 0050 FF FF 00 FF FF FF 00 80 C1 EF FF FF 19 E4 00 05 0060 04 FF 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 00 0070 00 00 00 00 00 FF FF FF FF FF FF 4B 22 00 23 FF 0080 04 FF 04 FF 00 00 28 20 01 9B 01 01 3C 3C 04 04 0090 04 FF 30 00 00 01 01 3C 43 17 00 00 2D FF FF D9 00A0 9D D7 D0 CE CB FF A2 23 FF 4E FF DA 00 04 03 03 00B0 84 35 C0 14 42 0C 18 C2 80 21 12 11 05 24 65 FF 00C0 03 00 00 FF FF 00 3F 35 2D 24 80 C0 90 95 00 A3 00D0 FF FF 00 FF FF FF 00 80 C1 EF FF FF 19 E4 00 05 00E0 04 FF 50 00 01 01 3C FF 0A FF 01 FF FF FF FF 00 00F0 00 00 00 00 00 FF FF FF FF FF FF 4B 22 00 23 FF 0027 0150 0250 007D 007E T: 35 36 21 0 35 T: 35 36 21 0 35 T: 35 34 21 0 35 T: 35 34 21 0 35 T: 35 35 21 0 35 T: 35 34 21 0 35 T: 35 35 21 0 35 T: 35 34 21 0 35 T: 35 34 21 0 35 T: 35 34 21 0 35 Bnk0 FF FF 00 FF FF FF 00 80 C1 EF FF FF 19 E4 00 05 Bnk1 22 00 00 4B 00 50 05 BE FF FF FF FF FF FF FF FF Bnk2 15 80 00 4B 00 50 1A 00 FF FF FF FF FF FF FF FF Bnk3 02 03 04 07 07 03 02 04 00 00 00 C0 7F 0B 00 00 Bnk4 3B 13 FF 00 00 00 00 00 00 DE 1D AB 09 5F 20 7F Bnk5 D5 88 00 FF A2 01 15 1B 2A 23 00 00 17 00 00 00 Bnk6 7F 7F 7F 7F 7F 7F 00 00 04 2C 00 00 00 00 00 00 Reg$20 CPU Core: r = 157, r*0.016 = 2.51 Reg$21 CPU Aux: r = 215, r*0.016 = 3.44 Reg$22 +3.3 V: r = 208, r*0.016 = 3.33 Reg$23 +5 V: r = 206, r*0.016 = 3.30 Reg$24 +12 V: r = 203, r*0.016 = 3.25 Reg$25 -12 V: r = 255, r*0.016 = 4.08 Reg$26 -5 V: r = 162, r*0.016 = 2.59 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ Asus ATK0110 ]------ Motherboard ID: RampageII-GENE ICPU/VCPU/PCPU: 16 / 56 / 57861 CPU Temperature : 36.0 C MB Temperature : 35.0 C NB Temperature : 56.0 C OPT_TEMP1 Temperature: 0.0 C OPT_TEMP2 Temperature: 43.0 C SB Temperature : 52.0 C CHA_FAN1 FAN Speed : 1947 RPM CHA_FAN2 FAN Speed : 1874 RPM CPU FAN Speed : 1087 RPM OPT_FAN1 FAN Speed : 1922 RPM OPT_FAN2 FAN Speed : 1764 RPM 12V Voltage : 12.081 V 3.3V Voltage : 3.296 V 5V Voltage : 4.878 V CPU PLL Voltage : 1.819 V CPU Voltage : 1.250 V DRAM Bus Voltage : 1.647 V ICH PCIE Voltage : 1.501 V ICH Voltage : 1.164 V IOH PCIE Voltage : 1.508 V IOH Voltage : 1.164 V QPI/DRAM Core Voltage: 1.296 V CPU Temperature : 38.5 C MB Temperature : 35.0 C NB Temperature : 56.0 C OPT_TEMP1 Temperature: 0.0 C OPT_TEMP2 Temperature: 43.0 C SB Temperature : 52.0 C CHA_FAN1 FAN Speed : 1952 RPM CHA_FAN2 FAN Speed : 1893 RPM CPU FAN Speed : 1086 RPM OPT_FAN1 FAN Speed : 1926 RPM OPT_FAN2 FAN Speed : 1764 RPM 12V Voltage : 12.081 V 3.3V Voltage : 3.296 V 5V Voltage : 4.878 V CPU PLL Voltage : 1.819 V CPU Voltage : 1.257 V DRAM Bus Voltage : 1.660 V ICH PCIE Voltage : 1.501 V ICH Voltage : 1.164 V IOH PCIE Voltage : 1.508 V IOH Voltage : 1.171 V QPI/DRAM Core Voltage: 1.296 V Quote
Squall Leonhart Posted October 8, 2011 Author Posted October 8, 2011 PCI Dump Quote ------[ AIDA64 v1.85.1632 Beta ]------------[ Microsoft Windows 7 Ultimate 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 65-1501-000001-00101111-032211-TYLERSBURG$A1234000_BIOS DATE: 03/22/11 16:36:18 VER: 08.00.15 Motherboard Model : Asus Rampage II Gene Motherboard Chipset : Intel Tylersburg X58, Intel Nehalem DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : Rampage II GENE DMI MB Version : Rev 2.xx DMI MB Serial : MS1C92BJDZ01491 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 1501 ------[ PCI Devices ]------ B00-D00-F00 [8086-3405] [1043-836B] [CC0600]: Intel X58 Chipset - ESI Port [b-2] B00-D01-F00 [8086-3408] [0000-0000] [CC0604]: Intel Tylersburg Chipset - PCI Express Root Port 1 (x4/x2) [b-2] B00-D03-F00 [8086-340A] [0000-0000] [CC0604]: Intel Tylersburg Chipset - PCI Express Root Port 3 (x16/x8/x4) [b-2] B00-D07-F00 [8086-340E] [0000-0000] [CC0604]: Intel Tylersburg Chipset - PCI Express Root Port 7 (x16/x8/x4) [b-2] B00-D14-F00 [8086-342E] [0000-0000] [CC0800]: Intel Tylersburg Chipset - System Management Registers [b-2] B00-D14-F01 [8086-3422] [0000-0000] [CC0800]: Intel Tylersburg Chipset - Scratchpad/GPIO Registers [b-2] B00-D14-F02 [8086-3423] [0000-0000] [CC0800]: Intel Tylersburg Chipset - IOH Control/Status and RAS Registers [b-2] B00-D14-F03 [8086-3438] [0000-0000] [CC0800]: Intel Tylersburg Chipset - Throttle Registers [b-2] B00-D1A-F00 [8086-3A37] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1A-F01 [8086-3A38] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1A-F02 [8086-3A39] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1A-F07 [8086-3A3C] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB2 Enhanced Host Controller B00-D1B-F00 [8086-3A3E] [1043-82EA] [CC0403]: Intel 82801JB ICH10 - High Definition Audio Controller B00-D1C-F00 [8086-3A40] [0000-0000] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 1 B00-D1C-F02 [8086-3A44] [0000-0000] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 3 B00-D1C-F03 [8086-3A46] [0000-0000] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 4 B00-D1C-F04 [8086-3A48] [0000-0000] [CC0604]: Intel 82801JB ICH10 - PCI Express Root Port 5 B00-D1D-F00 [8086-3A34] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1D-F01 [8086-3A35] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1D-F02 [8086-3A36] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB Universal Host Controller B00-D1D-F07 [8086-3A3A] [1043-82D4] [CC0C03]: Intel 82801JB ICH10 - USB2 Enhanced Host Controller B00-D1E-F00 [8086-244E] [0000-0000] [CC0604]: Intel 82801JB I/O Controller Hub 10 (ICH10) [A-0] B00-D1F-F00 [8086-3A16] [1043-82D4] [CC0601]: Intel 82801JB ICH10R - LPC Bridge B00-D1F-F02 [8086-3A22] [1043-82D4] [CC0106]: Intel 82801JB ICH10 - 6-port SATA AHCI Controller B00-D1F-F03 [8086-3A30] [1043-82D4] [CC0C05]: Intel 82801JB ICH10 - SMBus Controller B02-D00-F00 [10DE-05E6] [3842-1171] [CC0300]: EVGA e-GeForce GTX 275 Video Adapter B05-D00-F00 [1106-3403] [1043-8384] [CC0C00]: VIA OHCI Compliant IEEE 1394 Host Controller B06-D00-F00 [10EC-8168] [1043-82C6] [CC0200]: Realtek RTL8168C/8111C PCI-E Gigabit Ethernet Adapter B08-D00-F00 [1102-0005] [415A-0034] [CC0401]: Auzentech X-Fi Prelude 7.1 Sound Card BFF-D00-F00 [8086-2C41] [8086-8086] [CC0600]: Intel QuickPath Architecture - Generic Non-Core Registers BFF-D00-F01 [8086-2C01] [8086-8086] [CC0600]: Intel QuickPath Architecture - System Address Decoder (SAD) BFF-D02-F00 [8086-2C10] [8086-8086] [CC0600]: Intel QuickPath Interconnect - QPI Link 0 Control BFF-D02-F01 [8086-2C11] [8086-8086] [CC0600]: Intel QuickPath Interconnect - QPI Physical 0 Control BFF-D03-F00 [8086-2C18] [8086-8086] [CC0600]: Intel IMC Registers BFF-D03-F01 [8086-2C19] [8086-8086] [CC0600]: Intel IMC Target Address Decoder BFF-D03-F04 [8086-2C1C] [8086-8086] [CC0600]: Intel IMC Test Registers BFF-D04-F00 [8086-2C20] [8086-8086] [CC0600]: Intel IMC Channel 0 Control Registers BFF-D04-F01 [8086-2C21] [8086-8086] [CC0600]: Intel IMC Channel 0 Address Registers BFF-D04-F02 [8086-2C22] [8086-8086] [CC0600]: Intel IMC Channel 0 Rank Registers BFF-D04-F03 [8086-2C23] [8086-8086] [CC0600]: Intel IMC Channel 0 Thermal Control BFF-D05-F00 [8086-2C28] [8086-8086] [CC0600]: Intel IMC Channel 1 Control Registers BFF-D05-F01 [8086-2C29] [8086-8086] [CC0600]: Intel IMC Channel 1 Address Registers BFF-D05-F02 [8086-2C2A] [8086-8086] [CC0600]: Intel IMC Channel 1 Rank Registers BFF-D05-F03 [8086-2C2B] [8086-8086] [CC0600]: Intel IMC Channel 1 Thermal Control BFF-D06-F00 [8086-2C30] [8086-8086] [CC0600]: Intel IMC Channel 2 Control Registers BFF-D06-F01 [8086-2C31] [8086-8086] [CC0600]: Intel IMC Channel 2 Address Registers BFF-D06-F02 [8086-2C32] [8086-8086] [CC0600]: Intel IMC Channel 2 Rank Registers BFF-D06-F03 [8086-2C33] [8086-8086] [CC0600]: Intel IMC Channel 2 Thermal Control B00 D00 F00: Intel X58 Chipset - ESI Port [b-2] Offset 000: 86 80 05 34 00 04 10 00 12 00 00 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 6B 83 Offset 030: 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 D1 FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 05 90 02 01 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 10 E0 42 00 20 80 00 00 00 00 00 00 41 3C 3B 00 Offset 0A0: 00 00 41 30 00 00 00 00 C0 07 00 01 00 00 00 00 Offset 0B0: 00 00 00 00 3E 00 00 00 09 00 00 00 00 00 00 00 Offset 0C0: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 01 00 03 C8 08 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D01 F00: Intel Tylersburg Chipset - PCI Express Root Port 1 (x4/x2) [b-2] Offset 000: 86 80 08 34 04 05 10 00 12 00 04 06 40 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 00 Offset 020: F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00 Offset 040: 0D 60 00 00 43 10 6B 83 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 05 90 13 01 0C F0 EF FE A2 49 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 10 E0 42 01 21 80 00 00 00 00 00 00 42 3C 3B 00 Offset 0A0: 00 00 01 10 80 0C 10 00 C0 03 08 00 00 00 01 00 Offset 0B0: 00 00 00 00 3E 00 00 00 09 00 00 00 00 00 00 00 Offset 0C0: 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 01 00 03 C8 08 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D03 F00: Intel Tylersburg Chipset - PCI Express Root Port 3 (x16/x8/x4) [b-2] Offset 000: 86 80 0A 34 07 05 10 00 12 00 04 06 40 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 02 02 00 B0 B0 00 20 Offset 020: 00 F0 D0 F3 01 C0 F1 CF 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 1A 00 Offset 040: 0D 60 00 00 43 10 6B 83 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 05 90 13 01 0C F0 EF FE 70 49 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 10 E0 42 01 21 80 00 00 00 00 00 00 02 3D 3B 00 Offset 0A0: 00 00 02 71 80 25 08 00 C0 03 48 01 00 00 01 00 Offset 0B0: 00 00 00 00 3E 00 00 00 09 00 00 00 00 00 00 00 Offset 0C0: 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 01 00 03 C8 08 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D07 F00: Intel Tylersburg Chipset - PCI Express Root Port 7 (x16/x8/x4) [b-2] Offset 000: 86 80 0E 34 04 05 10 00 12 00 04 06 40 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 03 03 00 F0 00 00 00 Offset 020: F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 02 00 Offset 040: 0D 60 00 00 43 10 6B 83 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 05 90 13 01 0C F0 EF FE 92 49 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 10 E0 42 01 21 80 00 00 00 00 00 00 02 3D 3B 00 Offset 0A0: 00 00 01 10 80 0C 18 00 C0 03 08 00 00 00 01 00 Offset 0B0: 00 00 00 00 3E 00 00 00 09 00 00 00 00 00 00 00 Offset 0C0: 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 01 00 03 C8 08 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F00: Intel Tylersburg Chipset - System Management Registers [b-2] Offset 000: 86 80 2E 34 00 00 10 00 12 00 00 08 40 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 10 00 92 00 00 80 00 00 00 00 00 00 00 F4 3B 00 Offset 050: 00 00 00 10 00 00 00 00 C0 07 00 00 00 00 01 00 Offset 060: 00 00 00 00 00 80 00 00 00 00 00 00 00 F4 3B 00 Offset 070: 00 00 00 10 00 00 00 00 C0 07 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 07 00 Offset 090: 00 00 00 00 00 00 00 00 48 10 05 00 34 7C 03 00 Offset 0A0: 00 00 00 00 00 00 00 00 09 00 80 BF 00 00 00 00 Offset 0B0: 00 00 FF FF FF FF 07 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 FF FF FF FF 07 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 BC 00 00 00 BC 01 00 00 00 00 00 00 FC Offset 0E0: FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 74 EF FF 3F 00 00 00 00 C4 7F 00 00 00 00 00 00 B00 D14 F01: Intel Tylersburg Chipset - Scratchpad/GPIO Registers [b-2] Offset 000: 86 80 22 34 00 00 10 00 12 00 00 08 40 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 10 00 92 00 00 80 00 00 00 00 00 00 00 F4 3B 00 Offset 050: 00 00 00 10 00 00 00 00 C0 07 00 00 00 00 01 00 Offset 060: 00 00 00 00 00 80 00 00 00 00 00 00 00 F4 3B 00 Offset 070: 00 00 00 10 00 00 00 00 C0 07 00 00 20 13 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BF Offset 0A0: 00 00 00 00 00 00 11 02 00 00 85 01 00 00 00 00 Offset 0B0: 41 37 0C FF 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 71 1F 00 00 Offset 0D0: 04 00 04 00 00 04 00 00 00 00 00 00 20 13 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BF B00 D14 F02: Intel Tylersburg Chipset - IOH Control/Status and RAS Registers [b-2] Offset 000: 86 80 23 34 00 00 10 00 12 00 00 08 40 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 10 00 92 00 00 80 00 00 00 00 00 00 00 F4 3B 00 Offset 050: 00 00 00 10 00 00 00 00 C0 07 00 00 00 00 01 00 Offset 060: 00 00 00 00 00 80 00 00 00 00 00 00 00 F4 3B 00 Offset 070: 00 00 00 10 00 00 00 00 C0 07 00 00 00 00 00 00 Offset 080: A4 80 A0 02 50 01 AA AA A8 00 00 00 65 15 00 00 Offset 090: 00 00 00 00 24 00 00 00 04 08 00 00 22 05 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 01 00 00 00 00 00 00 00 00 00 00 00 00 42 00 00 Offset 0D0: 00 00 00 00 00 08 08 92 95 00 AA 35 00 00 10 00 Offset 0E0: 40 58 04 00 DF 02 00 00 FF 07 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F03: Intel Tylersburg Chipset - Throttle Registers [b-2] Offset 000: 86 80 38 34 00 00 00 00 12 00 00 08 40 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 0B 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 0B 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 0B 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 DC 00 00 00 A8 00 00 00 00 00 B4 00 C8 00 Offset 0F0: 00 00 00 7F 00 00 00 00 40 0D D3 07 00 00 00 00 B00 D1A F00: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 37 3A 05 00 90 02 00 00 03 0C 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 01 A8 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1A F01: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 38 3A 05 00 90 02 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 81 A8 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 15 02 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1A F02: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 39 3A 05 00 90 02 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 01 AC 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 13 04 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1A F07: Intel 82801JB ICH10 - USB2 Enhanced Host Controller Offset 000: 86 80 3C 3A 06 01 90 02 00 20 03 0C 00 00 00 00 Offset 010: 00 F0 FF DF 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 C2 C9 00 80 00 00 0A 98 A0 20 00 00 00 00 Offset 060: 20 20 FF 01 00 00 00 00 01 00 00 00 00 20 00 C0 Offset 070: 00 00 DF 0F 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 13 00 06 03 00 01 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 86 85 40 00 86 0F 00 00 0A 13 02 20 B00 D1B F00: Intel 82801JB ICH10 - High Definition Audio Controller Offset 000: 86 80 3E 3A 06 01 10 00 00 00 03 04 40 00 00 00 Offset 010: 04 80 FF DF 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 EA 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00 Offset 040: 01 00 00 07 07 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 04 00 01 00 00 00 00 31 00 A3 02 00 00 00 00 Offset 0D0: 61 00 A3 02 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1C F00: Intel 82801JB ICH10 - PCI Express Root Port 1 Offset 000: 86 80 40 3A 06 01 10 00 00 00 04 06 40 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 07 07 00 F0 00 00 20 Offset 020: F0 FF 00 00 F1 DE F1 DE 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 11 01 02 00 Offset 040: 10 80 41 01 00 80 00 00 00 00 10 00 11 2C 11 01 Offset 050: 40 00 01 10 60 05 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 0D A0 00 00 43 10 EA 82 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 11 08 00 00 00 00 Offset 0E0: 00 0F C7 00 06 07 08 00 30 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1C F02: Intel 82801JB ICH10 - PCI Express Root Port 3 Offset 000: 86 80 44 3A 07 01 10 00 00 00 04 06 40 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 06 06 00 D0 D0 00 20 Offset 020: F0 F3 F0 F3 E1 DE E1 DE 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 12 03 02 00 Offset 040: 10 80 41 01 00 80 00 00 00 00 10 00 11 2C 11 03 Offset 050: 40 00 11 30 60 05 00 00 00 00 48 01 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 0D A0 00 00 43 10 EA 82 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 11 08 00 00 00 00 Offset 0E0: 00 0F C7 00 06 07 08 00 30 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1C F03: Intel 82801JB ICH10 - PCI Express Root Port 4 Offset 000: 86 80 46 3A 07 01 10 00 00 00 04 06 40 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 05 05 00 C0 C0 00 20 Offset 020: E0 F3 E0 F3 F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 13 04 02 00 Offset 040: 10 80 41 01 00 80 00 00 00 00 11 00 11 2C 11 04 Offset 050: 40 00 11 30 60 05 00 00 00 00 48 01 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 0D A0 00 00 43 10 EA 82 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 11 08 00 00 00 00 Offset 0E0: 00 0F C7 00 06 07 08 00 30 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1C F04: Intel 82801JB ICH10 - PCI Express Root Port 5 Offset 000: 86 80 48 3A 06 01 10 00 00 00 04 06 40 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 04 04 00 F0 00 00 20 Offset 020: F0 FF 00 00 D1 DE D1 DE 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 11 01 02 00 Offset 040: 10 80 41 01 00 80 00 00 00 00 10 00 11 2C 11 05 Offset 050: 50 00 11 10 60 05 00 00 00 00 48 01 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 0D A0 00 00 43 10 EA 82 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 11 08 00 00 00 00 Offset 0E0: 00 0F C7 00 06 07 08 00 30 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1D F00: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 34 3A 05 00 90 02 00 00 03 0C 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 81 A0 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1D F01: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 35 3A 05 00 90 02 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 01 A4 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1D F02: Intel 82801JB ICH10 - USB Universal Host Controller Offset 000: 86 80 36 3A 05 00 90 02 00 00 03 0C 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 81 A4 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 20 00 00 00 00 00 00 00 00 01 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1D F07: Intel 82801JB ICH10 - USB2 Enhanced Host Controller Offset 000: 86 80 3A 3A 06 01 90 02 00 20 03 0C 00 00 00 00 Offset 010: 00 E0 FF DF 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00 Offset 060: 20 20 FF 01 00 00 00 00 01 00 00 00 00 20 00 C0 Offset 070: 00 00 DF 0F 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 86 85 40 00 86 0F 00 00 0A 13 02 20 B00 D1E F00: Intel 82801JB I/O Controller Hub 10 (ICH10) [A-0] Offset 000: 86 80 4E 24 07 01 10 00 90 01 04 06 00 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 08 08 20 E0 E0 80 22 Offset 020: 00 F4 D0 FB F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 02 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00 Offset 050: 0D 00 00 00 43 10 D4 82 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1F F00: Intel 82801JB ICH10R - LPC Bridge Offset 000: 86 80 16 3A 07 00 10 02 00 00 01 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 01 08 00 00 80 00 00 00 01 05 00 00 10 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 8F 85 8B 8A D0 00 00 00 8E 83 87 84 FF F0 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 0F 14 95 02 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: E4 06 00 00 39 00 00 00 13 1C 0A 24 00 03 00 40 Offset 0B0: 00 00 F0 00 00 00 00 00 04 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 33 22 11 00 67 45 00 00 C0 F0 00 00 00 00 00 00 Offset 0E0: 09 00 0C 10 01 00 C4 02 64 02 00 00 00 00 00 00 Offset 0F0: 01 C0 D1 FE 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1F F02: Intel 82801JB ICH10 - 6-port SATA AHCI Controller Offset 000: 86 80 22 3A 07 00 B0 02 00 01 06 01 00 00 00 00 Offset 010: 01 9C 00 00 81 98 00 00 01 98 00 00 81 94 00 00 Offset 020: 01 94 00 00 00 C0 FF DF 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 80 00 00 00 00 00 00 00 14 02 00 00 Offset 040: 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 70 08 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 60 00 3F BF 93 01 00 00 00 00 01 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 12 B0 10 00 48 00 00 00 Offset 0B0: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B00 D1F F03: Intel 82801JB ICH10 - SMBus Controller Offset 000: 86 80 30 3A 03 01 80 02 00 00 05 0C 00 00 00 00 Offset 010: 04 D0 FF DF 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 01 04 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 0B 03 00 00 Offset 040: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 B02 D00 F00: EVGA e-GeForce GTX 275 Video Adapter Offset 000: DE 10 E6 05 07 01 10 00 A1 00 00 03 40 00 00 00 Offset 010: 00 00 00 F2 0C 00 00 C0 00 00 00 00 04 00 00 F0 Offset 020: 00 00 00 00 01 BC 00 00 00 00 00 00 42 38 71 11 Offset 030: 00 00 00 00 60 00 00 00 00 00 00 00 18 01 00 00 Offset 040: 42 38 71 11 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00 Offset 060: 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 10 00 02 00 E0 84 2C 01 Offset 080: 10 29 00 00 02 2D 00 00 08 00 02 01 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B05 D00 F00: VIA OHCI Compliant IEEE 1394 Host Controller Offset 000: 06 11 03 34 07 01 10 00 00 10 00 0C 40 00 00 00 Offset 010: 04 F0 EF F3 00 00 00 00 01 C8 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 84 83 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 80 03 E4 00 00 00 00 00 00 00 00 00 1E 00 00 Offset 060: 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 98 80 01 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 10 00 01 00 00 80 28 00 Offset 0A0: 00 20 19 00 11 4C 07 00 00 00 11 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B06 D00 F00: Realtek RTL8168C/8111C PCI-E Gigabit Ethernet Adapter Offset 000: EC 10 68 81 00 05 10 00 02 00 00 02 40 00 00 00 Offset 010: 01 D8 00 00 00 00 00 00 04 F0 FF F3 00 00 00 00 Offset 020: 0C 00 EF DE 00 00 00 00 00 00 00 00 43 10 C6 82 Offset 030: 00 00 FC F3 40 00 00 00 00 00 00 00 0B 01 00 00 Offset 040: 01 50 C3 FF 08 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 10 B0 01 02 C1 8C 28 00 10 20 19 00 11 3C 07 00 Offset 080: 00 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 11 D0 01 00 04 00 00 00 04 08 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B06 D00 F00: [VPD] Realtek RTL8168C/8111C PCI-E Gigabit Ethernet Adapter Offset 000: 29 81 EC 10 68 81 43 10 C6 82 04 01 0C 62 00 24 )...h.C......b.$ Offset 010: 8C 58 FC FA 05 0F C3 FF 00 02 C1 8C 80 02 00 00 .X.............. Offset 020: 11 3C 07 00 10 20 76 00 63 01 01 FF 00 27 AA 03 .<... v.c....'.. Offset 030: 02 20 2D 57 80 02 00 20 10 00 21 00 10 00 21 30 . -W... ..!...!0 Offset 040: 00 00 80 61 42 55 80 00 20 00 E0 00 68 4C 00 00 ...aBU.. ...hL.. Offset 050: 01 00 00 00 9E 72 B5 00 00 00 00 00 00 00 00 00 .....r.......... Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 080: 29 81 EC 10 68 81 43 10 C6 82 04 01 0C 62 00 24 )...h.C......b.$ Offset 090: 8C 58 FC FA 05 0F C3 FF 00 02 C1 8C 80 02 00 00 .X.............. Offset 0A0: 11 3C 07 00 10 20 76 00 63 01 01 FF 00 27 AA 03 .<... v.c....'.. Offset 0B0: 02 20 2D 57 80 02 00 20 10 00 21 00 10 00 21 30 . -W... ..!...!0 Offset 0C0: 00 00 80 61 42 55 80 00 42 55 80 00 20 00 E0 00 ...aBU..BU.. ... Offset 0D0: 01 00 00 00 9E 72 B5 00 00 00 00 00 00 00 00 00 .....r.......... Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ B08 D00 F00: Auzentech X-Fi Prelude 7.1 Sound Card Offset 000: 02 11 05 00 07 00 10 02 00 00 01 04 00 40 00 00 Offset 010: 01 EC 00 00 04 00 C0 FB 00 00 00 00 04 00 00 F4 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 5A 41 34 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 10 01 04 05 Offset 040: 01 50 22 06 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 83 00 00 Offset 0D0: 00 80 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 57 00 00 00 00 00 FF FF FF FF 00 00 80 80 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D00 F00: Intel QuickPath Architecture - Generic Non-Core Registers Offset 000: 86 80 41 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 20 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 20 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 01 04 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 10 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D00 F01: Intel QuickPath Architecture - System Address Decoder (SAD) Offset 000: 86 80 01 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 10 11 11 00 00 33 11 00 00 00 00 00 00 12 00 00 Offset 050: 01 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 20 F0 07 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: C3 0B 00 00 C0 0F 00 00 C3 1B 00 00 C0 1B 00 00 Offset 090: C0 1B 00 00 C0 1B 00 00 C0 1B 00 00 C0 1B 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 11 11 11 11 00 00 00 00 11 11 11 11 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D02 F00: Intel QuickPath Interconnect - QPI Link 0 Control Offset 000: 86 80 10 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 01 8F 08 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 10 86 00 00 00 00 55 45 06 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 72 FD 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 7F 00 86 02 00 00 00 00 00 B3 00 00 00 00 Offset 0D0: 01 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D02 F01: Intel QuickPath Interconnect - QPI Physical 0 Control Offset 000: 86 80 11 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 09 00 FF F0 01 00 80 0B 00 00 10 00 73 02 00 00 Offset 050: 12 01 0C 7E 12 00 00 00 01 00 00 00 01 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 51 C3 10 A0 A0 40 00 Offset 070: 00 00 00 00 FF FF 0F 80 00 00 00 00 FF FF 0F 00 Offset 080: 03 0F 0F 07 00 00 00 00 01 00 00 00 01 00 0F 0F Offset 090: 82 00 00 00 02 02 01 00 08 08 88 08 02 05 00 00 Offset 0A0: 00 80 01 00 08 28 32 00 84 00 00 06 02 00 00 00 Offset 0B0: 77 15 AE 4D 00 00 00 00 00 00 00 00 01 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 11 04 00 00 00 00 00 00 00 00 03 00 08 00 Offset 0E0: 00 00 02 00 00 00 40 00 00 00 82 24 00 00 00 00 Offset 0F0: 00 00 00 00 42 01 00 00 00 00 00 00 00 00 00 00 BFF D03 F00: Intel IMC Registers Offset 000: 86 80 18 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 40 07 00 00 08 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 89 44 02 00 94 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 0E 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D03 F01: Intel IMC Target Address Decoder Offset 000: 86 80 19 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: C5 0B 00 00 C0 0F 00 00 C5 1B 00 00 C0 1B 00 00 Offset 090: C0 1B 00 00 C0 1B 00 00 C0 1B 00 00 C0 1B 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 10 02 10 02 00 00 00 00 10 02 10 02 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D03 F04: Intel IMC Test Registers Offset 000: 86 80 1C 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 09 00 FF F0 01 00 80 0B 03 10 10 04 E7 00 01 03 Offset 050: 08 00 00 1E 08 00 00 00 15 00 00 00 01 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 0E 00 00 00 00 00 00 00 Offset 0B0: EF CD AB 89 00 00 00 00 00 00 00 00 01 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 Offset 0D0: 0F 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 09 0A 00 00 00 00 00 00 BFF D04 F00: Intel IMC Channel 0 Control Registers Offset 000: 86 80 20 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 32 74 3F 06 40 01 00 00 Offset 060: B0 1C 90 00 00 00 00 00 01 00 00 00 00 00 00 00 Offset 070: 48 1D 06 08 18 00 00 00 00 00 00 00 03 00 00 00 Offset 080: D8 BB 43 1B 98 B5 00 00 88 11 31 00 58 F8 C5 02 Offset 090: 1C 03 B0 32 90 1A 40 60 F0 3D 01 00 50 50 E3 03 Offset 0A0: 00 00 00 00 00 00 01 01 04 04 01 01 01 02 05 09 Offset 0B0: 05 06 05 09 18 FF AF 0D E0 11 00 00 60 18 00 00 Offset 0C0: 10 04 08 00 04 01 02 00 10 08 07 00 00 08 00 00 Offset 0D0: 0F 0F 00 00 38 00 00 00 03 20 00 00 00 00 00 00 Offset 0E0: 10 04 00 00 00 01 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D04 F01: Intel IMC Channel 0 Address Registers Offset 000: 86 80 21 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 A8 02 00 00 00 10 00 00 Offset 050: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 08 00 00 00 00 00 C0 FF 08 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D04 F02: Intel IMC Channel 0 Rank Registers Offset 000: 86 80 22 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 Offset 050: 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D04 F03: Intel IMC Channel 0 Thermal Control Offset 000: 86 80 23 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 01 FF 04 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: FF FF FF FF 00 40 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D05 F00: Intel IMC Channel 1 Control Registers Offset 000: 86 80 28 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 32 74 3F 06 40 01 00 00 Offset 060: B0 1C 90 00 00 00 00 00 01 00 00 00 00 00 00 00 Offset 070: 48 1D 06 08 18 00 00 00 00 00 00 00 03 00 00 00 Offset 080: D8 BB 43 1B 98 B5 00 00 88 11 31 00 58 F8 C5 02 Offset 090: 1C 03 B0 32 90 1A 40 60 F0 3D 01 00 50 50 E4 03 Offset 0A0: 00 00 00 00 00 00 01 01 04 04 01 01 01 02 05 09 Offset 0B0: 05 06 05 09 18 FF AF 0D E0 11 00 00 60 18 00 00 Offset 0C0: 10 04 08 00 04 01 02 00 10 08 07 00 00 08 00 00 Offset 0D0: 0F 0F 00 00 39 00 00 00 03 20 00 00 00 00 00 00 Offset 0E0: 10 04 00 00 00 01 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D05 F01: Intel IMC Channel 1 Address Registers Offset 000: 86 80 29 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 A8 02 00 00 00 10 00 00 Offset 050: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 08 00 00 00 00 00 C0 FF 08 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D05 F02: Intel IMC Channel 1 Rank Registers Offset 000: 86 80 2A 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 Offset 050: 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D05 F03: Intel IMC Channel 1 Thermal Control Offset 000: 86 80 2B 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 01 FF 04 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: FF FF FF FF 00 40 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D06 F00: Intel IMC Channel 2 Control Registers Offset 000: 86 80 30 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 32 74 3F 06 40 01 00 00 Offset 060: B0 1C 90 00 00 00 00 00 01 00 00 00 00 00 00 00 Offset 070: 48 1D 06 08 18 00 00 00 00 00 00 00 03 00 00 00 Offset 080: D8 BB 43 1B 98 B5 00 00 88 11 31 00 58 F8 C5 02 Offset 090: 1C 03 B0 32 90 1A 40 60 F0 3D 01 00 50 50 E4 03 Offset 0A0: 00 00 00 00 00 00 01 01 04 04 01 01 01 02 05 09 Offset 0B0: 05 06 05 09 18 FF AF 0D E0 11 00 00 60 18 00 00 Offset 0C0: 10 04 08 00 04 01 02 00 10 08 07 00 00 08 00 00 Offset 0D0: 0F 0F 00 00 3A 00 00 00 03 20 00 00 00 00 00 00 Offset 0E0: 10 04 00 00 00 01 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D06 F01: Intel IMC Channel 2 Address Registers Offset 000: 86 80 31 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 A8 02 00 00 00 10 00 00 Offset 050: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 08 00 00 00 00 00 C0 FF 08 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D06 F02: Intel IMC Channel 2 Rank Registers Offset 000: 86 80 32 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 Offset 050: 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BFF D06 F03: Intel IMC Channel 2 Thermal Control Offset 000: 86 80 33 2C 06 00 00 00 05 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 86 80 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 01 FF 04 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: FF FF FF FF 00 40 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ SMBus Ctrl / C @ B00 D1F F03 ]------ Offset 000: 86 80 30 3A 03 01 80 02 00 00 05 0C 00 00 00 00 ..0:............ Offset 010: 04 D0 FF DF 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 020: 01 04 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 ............C... Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 0B 03 00 00 ................ Offset 040: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 060: 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00 ................ Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 080: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 ................ ------[ SMBus Ctrl / NC @ B00 D1F F03 ]------ Offset 000: 86 80 30 3A 03 01 80 02 00 00 05 0C 00 00 00 00 ..0:............ Offset 010: 04 D0 FF DF 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 020: 01 04 00 00 00 00 00 00 00 00 00 00 43 10 D4 82 ............C... Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 0B 03 00 00 ................ Offset 040: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 060: 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00 ................ Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 080: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Offset 0F0: 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00 ................ ------[ SMBus I/O Regs @ 0400 ]------ Offset 000: 00 00 08 97 81 00 DB 01 00 44 00 00 02 02 07 07 .........D...... Quote
Squall Leonhart Posted October 8, 2011 Author Posted October 8, 2011 Note: I know 49 is out but 47 is on there because deleted 49 and couldn't be bothered redownloading it to get the dumps The issue occurs from build 1639 to 1649 Quote
Fiery Posted October 8, 2011 Posted October 8, 2011 It looks like AIDA64 is unable to use its kernel driver. We've completely revamped the kernel driver in Build 1635. It means the current kernel driver cannot be loaded by an old AIDA64 version, and vice versa. Maybe while performing the upgrade you didn't overwrite the old KERNELD.* files with the new ones? Or maybe some other issue occured during the upgrade process. Please try to completely remove any AIDA64 installations you may have on your system, and restart your computer. You can keep your AIDA64.INI files of course, to keep your Preferences settings. Then manually download beta 1649, extract it into an empty folder, enter your license, and check if it works now. Let me know how it goes Quote
Squall Leonhart Posted October 8, 2011 Author Posted October 8, 2011 I tried that and it still didn't work, instead, i removed the kernel driver from the NPNP group in device manager and restarted aida some how it was referencing the old driver, even though it was no where to be seen on the system. Quote
Fiery Posted October 8, 2011 Posted October 8, 2011 Sounds a bit weird, but I'm glad you managed to resolve it. Quote
