HP fans not showing (HP Spectre x360 13)
The new HP Spectre x360 13 (Ice Lake model, AW000 series) has 2 fans that do not show up at all in the IDA Sensors section. Can you add support? Please let me know if you need dumps or anything.
Attached an image from a BIOS utility showing that polling this info is possible.
Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
If it's possible, please try to assure that both fans are spinning while you're making those dumps.
