I am still a aida64 learner. =.=
like,it was about the LCD settings, I planned to used my iPad 6 as a to detecting the computers' working performance
but unfortunately after I done the settings in the "remotesensor" like the picture below,
then I double checked the  Resolution setting again, and use 1080*1920 to check whether it can be shown on my another screen or not,
but it still doesn't work QAQ, things shown in the browser are not in a right order as set before, please help me!!!2.thumb.JPG.e0094e4ed86cfbc298e53a4c485934c5.JPG1910329111_LCD.thumb.JPG.16183fb5c838876ad4b56d9247e1d798.JPG1.thumb.JPG.775b5ff49bdbee9cef41198b1e6ca54f.JPG
On ‎2‎/‎15‎/‎2020 at 3:21 AM, Jim Lin CHNNN said:
You're not supposed to use the actual hardware picture resolution of the tablet, but rather the resolution that is indicated by AIDA64 when you first enable RemoteSensor.  Try to do the following:
1) On the AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD / LCD Items page, select all items on your LCD layout and press the Hide button.
2) On the iPad check the blue box that is displayed in your browser.  It should inform you about the right LCD resolution to use.
3) On the AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD page, modify the resolution to the right value.
4) On the AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD / LCD Items page, select all items on your LCD layout and press the Unhide button.
