We've implemented that on the Storage / Windows Storage page in the following new AIDA64 beta release:
http://www.aida64.co...61g6r3qtbpklzip
However, the new feature will only work under Windows 2000, XP and 2003. We haven't yet found a way to detect the same properties under Vista and Win7. We'll work more on it after the next AIDA64 stable release.
  • 3 weeks later...
  • 7 years later...
Something strange with AIDA64's support of this.
It seems aida64 lacks the active udma field on some drives declaring them to be running in MWDMA 0 or 2,
meanwhile HDD Scan and HD Tune both agree that the current active mode is UDMA6 for those drives,  and buffered read tests come back as expected.
1) What kind of HDDs do you have where you can experience this issue?
2) What sort of SATA controller are they connected to?
3) What operating system do you have installed?
4) What motherboard do you have?
  • 2 months later...
On ‎5‎/‎1‎/‎2019 at 4:12 PM, Squall Leonhart said:
Interestingly enough, the fields are now visible, seems that this information is not presented by hotplugged drives?
I don't know... It depends on the information reported in the ATA ID block..
