Neostarchild Posted February 28, 2020 Posted February 28, 2020 I have a Evga CLC and I've been searching through the forums and googling things. Is the Astek fan Control speed that I check off to make my fans work without the Evga software a range so I can set 50% to 100% fan speed and each fan runs to that percent? Or, is each box a set speed for each fan? If it's a range what determines the temp delta? Thank you. Quote
Fiery Posted March 3, 2020 Posted March 3, 2020 On 2/28/2020 at 9:17 PM, Neostarchild said: I have a Evga CLC and I've been searching through the forums and googling things. Is the Astek fan Control speed that I check off to make my fans work without the Evga software a range so I can set 50% to 100% fan speed and each fan runs to that percent? Or, is each box a set speed for each fan? If it's a range what determines the temp delta? Thank you. The 2 fan speed settings are used by the older Asetek VI protocol only. They refer to the fan speed (fan duty cycle) setting of up to two Asetek VI based devices. As long as you don't experience any issues with the default settings, you don't need to alter those options in the AIDA64 Preferences. Quote
