Stability test not opening up (blank proccess window open)
As title state when opening stability test on Aida 64, the additional window does not popup. Instead there is a blank window viewable in taskbar with the name 'stability test'. I have used the stability test without any problem before. So im worried is this due to my operating system or perhaps some malware?
It looks like it's more an issue about the enumeration of sensor devices in AIDA64.  When you go to the Computer / Sensor page of AIDA64, does it work properly?
