Dav' Posted April 9, 2020 Posted April 9, 2020 It's been some time I'm using a Netatmo weather station and its additionnal indoor modules to monitor my computer room. With incoming summer temperatures I looked for a way to get netatmo values into AIDA64 to calculate ambiant/computer deltas, useful to monitor cooling efficiency and prevent failures. Si I found netatmo has an API ( https://dev.netatmo.com/ ) to get this values but it's way beyond my abilities. Do you think you could add at least netatmo temperature monitoring in AIDA64 ? Thank you very much ! Quote
Fiery Posted April 24, 2020 Posted April 24, 2020 On 4/9/2020 at 6:30 PM, Dav' said: It's been some time I'm using a Netatmo weather station and its additionnal indoor modules to monitor my computer room. With incoming summer temperatures I looked for a way to get netatmo values into AIDA64 to calculate ambiant/computer deltas, useful to monitor cooling efficiency and prevent failures. Si I found netatmo has an API ( https://dev.netatmo.com/ ) to get this values but it's way beyond my abilities. Do you think you could add at least netatmo temperature monitoring in AIDA64 ? Thank you very much ! It's a good idea, but it also seems quite complicated, and in the current situation I'd rather not promise anything about complex development tasks Quote
Dav' Posted June 3, 2020 Author Posted June 3, 2020 Damn... Maybe this could help ? https://ifttt.com/netatmo Thanks ! Quote
