facboy Posted April 14, 2020 Posted April 14, 2020 The SPD section is empty, under Device Description there are no DIMMs listed. I suspect something went wrong when I tried to run Thaiphoon Burner, it raised an error window saying it might conflict with AIDA64, which i tried to close to abort whatever it was doing, but I think it continued anyway. Rebooting etc hasn't made the SPD data reappear, is there a driver or something that has become uninstalled? Quote
Fiery Posted April 14, 2020 Posted April 14, 2020 2 hours ago, facboy said: The SPD section is empty, under Device Description there are no DIMMs listed. I suspect something went wrong when I tried to run Thaiphoon Burner, it raised an error window saying it might conflict with AIDA64, which i tried to close to abort whatever it was doing, but I think it continued anyway. Rebooting etc hasn't made the SPD data reappear, is there a driver or something that has become uninstalled? You can check if AIDA64 has the necessary privileges to load its kernel driver (which is necessary to detect SPD information) if you check whether the CPU multiplier and FSB (BCLK) are properly measured on the Motherboard / CPU page or on the CPUID Panel (main menu / Tools / CPUID Panel). Quote
Fiery Posted April 18, 2020 Posted April 18, 2020 On 4/15/2020 at 1:11 PM, facboy said: yes it can read the CPU multiplier. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
JayK Posted March 24, 2021 Posted March 24, 2021 My SPD is coming up completely blank even though I have 2 x 8gb Sticks of G Skill Trident Z Neo 3600 Samsung B Die Ram in A2 n B2 slots. Here is my full Bus Dump. ------[ Versions ]------ Program Version : AIDA64 Extreme v6.32.5600 BenchDLL Version: 4.5.841.8-x64 Windows Version : Microsoft Windows 10 Home 10.0.18363.1440 (64-bit) GetProductInfo : 0x00000065 ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-022718-Chipset$0AAAA000_BIOS DATE: 01/03/20 14:36:45 VER: 05.0000E Motherboard Model : ASRock X570 Taichi Motherboard Chipset : AMD Bixby X570, AMD K17.7 FCH, AMD K17.7 IMC DMI MB Manufacturer : ASRock DMI MB Product : X570 Taichi DMI MB Version : DMI MB Serial : M80-D3003100002 DMI SYS Manufacturer: To Be Filled By O.E.M. DMI SYS Product : To Be Filled By O.E.M. DMI SYS Version : To Be Filled By O.E.M. DMI SYS Serial : To Be Filled By O.E.M. DMI BIOS Version : P2.80 ------[ 1 SMBus detected ]------ ------[ SMBus #0 ]------ SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI SMBus Port : 0B00 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D11 ]------ 0000 00 FF FF FF FF 00 FF 00 00 FF FF FF FF 00 FF FF ................ 0010 00 FF 00 00 FF FF FF FF 00 FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF 00 FF FF 00 00 FF 00 FF 00 FF ................ 0060 01 01 01 FF 00 FF 00 FF FF FF 00 FF 00 00 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF 00 FF FF 00 FF 00 00 00 00 00 ................ 00B0 FF 01 00 FF FF 00 FF 00 00 00 FF 00 00 FF 01 80 ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 00 FF 00 FF FF ................ ------[ SMBus Device B00-D11 ]------ 0000 60FF 60FF FFFF FFFF 6000 6000 6000 60FF 60FF FFFF 2000 FFFF FFFF 60FF FFFF FFFF 0010 6000 FFFF 6000 6000 6000 6000 6000 6000 2000 20FF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 60FF 6000 6000 60FF 6000 6000 6000 FFFF 6000 6000 FFFF 2000 2000 FFFF 6000 6000 0060 6000 60FF 60FF 60FF FFFF FFFF FFFF FF00 FF00 FF00 20FF 2001 FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF 60FF 6000 FFFF FFFF FFFF FF00 FF00 FF00 FFFF FF00 FF00 20FF 00B0 FFFF FFFF 6000 60FF FFFF 6000 FFFF FFFF FF00 FFFF FFFF FFFF FF00 FF00 2001 2F80 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF FFFF 6000 FFFF 6000 6000 60FF ------[ SMBus Device B00-D12 ]------ 0000 FF FF 00 00 FF FF 00 00 00 FF 00 00 00 80 00 FF ................ 0010 FF 00 FF FF FF 00 FF 00 00 80 FF 01 FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 ................ 0050 FF FF 00 00 FF FF FF 00 FF FF 80 FF 80 81 00 00 ................ 0060 FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF 00 00 00 FF FF FF 00 00 00 FF 00 80 00 FF ................ 00B0 FF FF 00 FF FF 00 00 00 FF 00 FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF 00 00 FF 00 FF 00 00 FF FF FF FF ................ ------[ SMBus Device B00-D12 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FF00 FF00 FF00 FFFF FF00 FF00 2000 2000 2F80 60FF FFFF 0010 FF00 FFFF FFFF FFFF FF00 FFFF FFFF FFFF FFFF FFFF 2001 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF 6000 6000 6000 60FF 6000 FFFF 6000 60FF 6000 FFFF 6000 2001 0060 FFFF FFFF FFFF FFFF FF00 FFFF FF00 FF00 FFFF FFFF FFFF FF00 FF00 2080 FFFF 2F01 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 60FF FFFF FFFF FFFF FF00 FFFF FF00 00B0 FF00 FFFF FFFF FFFF FF01 2F01 6000 60FF 6000 6000 FFFF 6000 FFFF 6000 FFFF 6000 00C0 2001 FFFF 2F01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 60FF FFFF 6000 ------[ SMBus Device B00-D13 ]------ 0000 00 00 FF 00 00 00 FF 00 FF FF 01 81 FF 00 FF 00 ................ 0010 FF 00 FF 00 00 FF 80 01 FF 01 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 00 FF 00 FF 00 FF 00 FF FF 01 FF 00 ................ 0060 FF 00 00 00 00 00 FF 00 FF 00 FF 00 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF 00 FF 00 FF FF FF FF 00 FF FF 00 ................ 00B0 FF FF 01 00 FF FF FF FF 00 FF 00 FF 80 FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF 00 FF FF 00 FF ................ ------[ SMBus Device B00-D13 ]------ 0000 6000 60FF 6000 6000 6000 6000 FFFF 6000 FFFF FFFF 60FF 2001 20FF FFFF FFFF 60FF 0010 FFFF 6000 6000 FFFF 6000 FFFF FFFF 60FF 60FF 2000 20FF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FF00 FF00 FFFF FFFF FF00 FF00 FFFF FFFF FF00 FFFF 0060 FFFF FFFF FF00 FF00 FFFF FF00 FF00 FFFF FFFF FF00 FFFF FFFF FFFF 2000 2001 FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 6000 6000 60FF 6000 6000 6000 6000 00B0 6000 2000 FFFF FFFF FFFF FFFF FF00 FFFF FFFF FFFF FF00 FF00 FF00 FF00 FFFF 2080 00C0 20FF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF 60FF 60FF FFFF 6000 6000 FFFF 60FF FFFF 6000 FFFF FFFF ------[ SMBus Device B00-D14 ]------ 0000 FF FF FF FF 00 00 FF 00 FF FF 00 FF 01 FF 00 00 ................ 0010 FF 00 00 FF 00 FF 00 00 FF FF FF 01 FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF 00 FF FF FF 00 FF FF FF 00 FF FF ................ 0060 81 00 00 FF 00 FF 00 FF 00 FF FF FF FF 00 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 00 00 00 FF FF FF FF FF ................ 00B0 FF FF 81 FF FF 00 FF 00 00 FF FF FF FF FF 01 FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF 00 00 00 FF 00 FF FF ................ ------[ SMBus Device B00-D15 ]------ 0000 FF 00 FF 00 00 00 00 00 FF 00 FF FF FF 81 00 FF ................ 0010 00 00 FF FF 00 FF 80 FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF 00 FF FF 00 FF 00 FF FF 00 00 FF FF 00 FF 00 ................ 0060 FF 00 00 FF 00 FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 00 FF 00 FF 00 00 FF 00 FF 00 FF 81 00 00 00 00 ................ 00B0 FF FF FF FF 00 00 FF FF FF 01 FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D16 ]------ 0000 FF 00 00 FF FF FF 00 FF FF 00 FF FF 00 00 00 00 ................ 0010 00 00 00 00 FF FF FF 00 FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 FF 00 00 FF FF FF 00 00 FF FF 01 FF FF ................ 0060 00 00 00 00 FF 00 00 FF FF FF 80 FF 80 FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF 00 FF FF FF 00 00 00 FF FF FF FF FF ................ 00B0 FF 81 00 FF 00 00 00 00 FF 00 FF 00 FF FF 80 FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 FF FF FF 00 00 ................ ------[ SMBus Device B00-D17 ]------ 0000 FF 00 FF FF FF 00 FF FF 00 00 00 01 FF FF FF 00 ................ 0010 FF FF 00 FF 00 FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF ................ 0050 00 00 00 00 00 FF FF FF 01 FF 00 FF 00 FF 00 FF ................ 0060 FF 00 00 FF 00 00 FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF 00 FF 00 00 FF FF FF 00 FF 01 FF 00 00 FF 00 ................ 00B0 FF FF FF 00 00 00 FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF 00 00 FF 00 00 FF FF 00 00 FF 00 00 01 00 ................ ------[ SMBus Device B00-D17 ]------ 0000 FFFF 60FF 6000 60FF 60FF 60FF 6000 6000 6000 6000 2000 2001 2F01 6000 6000 6000 0010 6000 FFFF 6000 6000 FFFF 60FF FFFF FFFF 2000 2000 FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF 6000 FFFF 60FF 6000 6000 6000 6000 6000 6000 FFFF FFFF 2FFF 0060 FFFF FFFF FF00 FFFF FFFF FF00 FFFF FF00 FF00 FF00 FF00 2080 2001 2001 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF FFFF 6000 6000 6000 6000 6000 60FF FFFF 00B0 2080 FFFF 2001 2FFF 6000 FFFF FFFF 6000 60FF 6000 FFFF 6000 60FF FFFF 6000 FFFF 00C0 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF00 FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D18 ]------ 0000 FF FF FF FF FF FF 00 FF FF FF 00 FF 01 01 FF FF ................ 0010 FF FF 00 00 00 FF FF FF 00 80 FF 01 FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF 00 FF FF 00 FF 00 FF FF 00 FF 00 FF ................ 0060 01 FF FF FF FF 00 00 FF 00 FF FF FF 00 FF 00 01 ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 00 FF FF FF FF 00 00 00 ................ 00B0 00 FF 00 FF FF FF 00 FF 00 00 00 00 00 FF 01 FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF 00 00 00 FF 00 ................ ------[ SMBus Device B00-D18 ]------ 0000 FFFF FFFF FFFF FFFF FF00 FFFF FF00 FFFF FF00 FFFF FF00 FFFF 6000 FFFF 6000 60FF 0010 6000 6000 FFFF 60FF 6000 6000 6000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 60FF FFFF 6000 FFFF 60FF FFFF 6000 60FF 60FF 6000 FFFF 2000 FFFF 2FFF 0060 60FF 60FF 6000 6000 6000 6000 6000 FFFF FF00 FFFF FF00 2000 2000 2F80 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 60FF 6000 6000 6000 6000 FFFF 2FFF FFFF 00B0 6000 FFFF 6000 6000 60FF 6000 6000 FFFF 60FF 6000 2000 2001 FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF 6000 6000 FFFF FFFF 6000 6000 6000 FFFF 6000 6000 FFFF FFFF FFFF ------[ SMBus Device B00-D19 ]------ 0000 FF FF 00 FF 00 00 FF FF 00 FF FF 80 81 00 FF FF ................ 0010 FF FF FF FF FF FF 00 00 FF 00 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 00 00 00 FF FF 00 FF FF 00 00 01 FF ................ 0060 FF 00 FF 00 FF FF 00 00 00 00 FF FF FF 80 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF 00 FF FF 00 FF 00 FF 00 00 00 00 ................ 00B0 FF FF FF FF FF 00 00 FF 00 FF FF 00 FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 FF FF 00 FF 00 ................ ------[ SMBus Device B00-D19 ]------ 0000 60FF 60FF FFFF 6000 6000 60FF 60FF 6000 FFFF 60FF 6000 FFFF FFFF FFFF 60FF FFFF 0010 60FF 60FF FFFF 6000 6000 6000 FFFF FFFF FFFF 2080 20FF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 0050 60FF FFFF 6000 60FF 6000 FFFF 6000 6000 60FF 6000 FFFF 2001 2FFF 6000 6000 60FF 0060 FFFF 60FF 6000 6000 60FF 60FF 60FF 60FF 2000 2000 FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF 6000 6000 60FF 6000 6000 6000 6000 6000 6000 FFFF FFFF FF01 2F80 6000 00B0 6000 FFFF FFFF 6000 60FF 6000 60FF FFFF 60FF 60FF 20FF 2001 2F01 FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 6000 60FF 6000 FFFF FFFF FFFF 6000 6000 ------[ SMBus Device B00-D1A ]------ 0000 00 00 00 00 00 C1 1B 22 00 00 00 00 00 00 00 00 ......."........ 0010 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 ................ 0020 00 80 00 00 FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 01 00 FF 00 00 00 00 00 ................ 0070 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 ................ 00B0 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 ................ 00C0 00 80 00 01 FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF 00 00 00 FF 00 ................ ------[ SMBus Device B00-D1A ]------ 0000 7F00 0000 0000 0000 0000 F7C1 091B 3022 0000 0000 0000 0000 0000 0000 0000 0000 0010 FFFF FFFF FFFF 6000 6000 6000 6000 6000 6000 6000 6000 2000 2001 0000 0000 0000 0020 0000 0000 0000 0000 0000 0000 2080 2000 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 6000 6000 6000 6000 6000 6000 6000 6000 6000 6000 2000 2001 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 2001 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 00B0 6000 6000 6000 6000 6000 6000 6000 6000 2001 2F80 6000 6000 6000 6000 6000 6000 00C0 6000 0000 0001 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 0000 ------[ SMBus Device B00-D1B ]------ 0000 00 00 00 00 00 C1 1B 22 00 00 00 00 00 00 00 00 ......."........ 0010 00 00 00 01 00 00 00 00 00 00 00 FF 00 00 00 80 ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 ................ 0060 00 00 00 01 81 00 00 00 00 00 00 00 00 00 80 00 ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF 00 00 00 00 FF 00 ................ 00B0 FF 00 00 80 00 01 00 00 00 00 00 00 00 00 00 01 ................ 00C0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D1B ]------ 0000 7F00 0000 0000 0000 0000 6000 6000 6022 6000 6000 6000 6000 6000 2080 2001 6000 0010 6000 6000 6000 6000 6000 6000 6000 6000 0000 0001 2F01 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF 6000 6000 6000 6000 6000 6000 6000 FFFF 6000 2080 2000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 2001 2F00 FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF 0000 0000 0000 0000 0000 0000 0000 0000 0000 FFFF 2001 0000 6000 6000 00B0 6000 6000 6000 6000 6000 6000 6000 2001 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 6000 6000 6000 6000 6000 6000 6000 6000 6000 6000 2000 2001 6081 6000 6000 6000 ------[ SMBus Device B00-D1C ]------ 0000 FF FF FF FF FF 00 FF FF 01 FF 81 FF FF 00 00 FF ................ 0010 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 ................ 0050 00 00 FF FF 00 00 00 FF 00 FF FF FF 00 00 00 00 ................ 0060 00 FF FF FF 00 FF 00 00 00 FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF 00 00 00 00 00 FF 00 00 FF FF 01 FF FF FF ................ 00B0 FF 00 FF FF 00 00 00 00 00 80 FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 00 FF FF FF FF FF FF 00 FF FF FF FF FF FF FF 00 ................ ------[ SMBus Device B00-D1C ]------ 0000 60FF FFFF FF00 FF00 FFFF FF00 FF00 FF00 FFFF FFFF FFFF FFFF FF01 FFFF FFFF FFFF 0010 FF00 FF00 FFFF FFFF FFFF FF00 FFFF FF00 FFFF FF00 2000 20FF 2F01 FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF 60FF 6000 60FF FFFF 60FF 6000 6000 FFFF 6000 2000 2001 0060 FFFF FF00 FFFF FFFF FFFF FF00 FFFF FFFF FFFF FFFF FF00 FFFF 2000 FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 FFFF FFFF FFFF FF00 FF00 FF00 00B0 FF00 2080 20FF 2001 2F01 60FF 6000 6000 FFFF 6000 6000 FFFF 60FF 60FF FFFF FFFF 00C0 20FF FFFF 2F01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF00 FFFF ------[ SMBus Device B00-D1D ]------ 0000 00 00 00 FF FF 00 FF 00 00 FF FF FF FF FF 00 00 ................ 0010 FF 00 FF FF FF FF 00 FF FF 01 80 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 00 00 FF 00 FF FF 00 FF FF 00 00 FF ................ 0060 FF 00 FF FF FF 00 FF FF 01 01 FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF 00 00 FF FF FF 00 00 00 FF FF FF FF 01 80 FF ................ 00B0 00 00 00 00 00 FF FF 00 FF FF 00 FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF 00 FF 00 FF FF 00 00 00 00 00 FF 01 ................ ------[ SMBus Device B00-D1E ]------ 0000 00 00 FF 00 FF FF FF 00 FF 00 00 01 01 FF FF 00 ................ 0010 00 00 00 FF 00 FF FF FF 00 FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF 00 FF 00 00 00 00 FF FF FF FF FF FF 01 FF FF ................ 0060 00 FF FF FF FF FF 00 FF FF 00 FF FF FF 01 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 00 FF 00 00 00 FF 00 00 ................ 00B0 80 FF FF FF FF FF FF FF 00 FF FF 00 FF FF FF 00 ................ 00C0 FF 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF 00 00 FF 00 00 ................ ------[ SMBus Device B00-D1F ]------ 0000 FF FF FF 00 FF 00 00 00 FF 00 00 FF FF FF FF FF ................ 0010 00 FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 ................ 0050 FF 00 FF 00 00 00 00 00 FF 00 01 00 00 FF FF 00 ................ 0060 00 00 00 00 FF 00 80 FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF 00 00 00 FF FF 00 FF 01 FF 00 FF 00 FF 00 ................ 00B0 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 00 FF FF FF 00 00 00 FF FF FF 00 00 80 FF FF FF ................ ------[ SMBus Device B00-D1F ]------ 0000 60FF 6000 6000 60FF 6000 6000 60FF 6000 60FF 60FF FFFF FFFF FFFF FFFF 6000 60FF 0010 60FF 6000 60FF 6000 FFFF 6000 60FF 60FF 2000 20FF 2F01 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 6000 6000 FFFF FFFF 6000 60FF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 2FFF 0060 6000 60FF 6000 FFFF 60FF 60FF FFFF FFFF 60FF FFFF 6000 20FF FFFF 2F80 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF 60FF 6000 60FF 60FF 6000 6000 6000 6000 6000 60FF FFFF 00B0 FFFF FFFF 6081 6000 6000 60FF 6000 6000 6000 FFFF 60FF 6000 6000 6000 20FF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 6000 FFFF FF00 FF00 FFFF ------[ SMBus Device B00-D20 ]------ 0000 FF FF FF FF FF FF FF FF FF 00 FF 00 FF FF FF 00 ................ 0010 FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF 00 00 FF FF FF ................ 0050 FF 00 00 FF 00 FF FF FF FF FF 00 FF FF 00 FF 00 ................ 0060 FF FF FF FF FF 01 FF 01 FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 ................ 00A0 00 FF FF 00 FF FF FF FF 00 00 80 FF FF FF FF FF ................ 00B0 FF 00 00 00 00 00 FF FF FF 00 01 FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 00 00 00 00 FF FF FF FF FF 00 FF 00 01 01 00 FF ................ ------[ SMBus Device B00-D20 ]------ 0000 60FF FFFF 60FF 60FF 6000 60FF 6000 6000 60FF FFFF 6000 20FF 2001 FFFF FFFF 6000 0010 FFFF 6000 60FF FFFF 60FF 6000 6000 6000 FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 60FF 6000 FFFF 60FF 6000 FFFF 60FF 6000 FFFF 6000 6000 2000 2001 0060 6081 FFFF 60FF 60FF 6000 60FF 60FF 6000 FFFF 6000 60FF 60FF 2000 20FF 2F01 FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 FFFF FFFF FFFF 2000 20FF 2F80 6000 6000 00B0 6000 6000 60FF 6000 60FF 6000 6000 6000 6000 2000 FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 6000 6000 6000 FFFF FFFF 60FF 6000 2001 ------[ SMBus Device B00-D21 ]------ 0000 FF 00 00 00 FF FF FF FF FF FF 80 00 00 FF 00 FF ................ 0010 00 00 00 FF 00 FF 01 01 FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF 00 00 FF FF FF 00 00 00 00 00 00 00 FF FF FF ................ 0060 00 00 00 00 FF 00 00 00 00 FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF 00 FF FF 00 00 00 FF FF 00 FF 00 FF 01 ................ 00B0 81 00 00 FF 00 FF 00 FF FF FF 00 FF FF 00 FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF 00 ................ ------[ SMBus Device B00-D21 ]------ 0000 6000 FFFF 6000 6000 6000 6000 6000 6000 6000 20FF 2001 6081 6000 FFFF FFFF FFFF 0010 60FF 6000 FFFF FFFF 6000 6000 2080 20FF 20FF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 0050 6000 6000 6000 6000 60FF 20FF 2000 FFFF FFFF FFFF FFFF FFFF FF00 FF00 FF00 FFFF 0060 FFFF FF00 FFFF FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 00A0 6000 6000 60FF 6000 6000 60FF 60FF 6000 FFFF 20FF 2001 FFFF FFFF FFFF FF00 FF00 00B0 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 00F0 FFFF 6000 6000 6000 6000 FFFF 6000 6000 FFFF FFFF FFFF FF01 FF01 2F01 6000 6000 ------[ SMBus Device B00-D22 ]------ 0000 FF 00 00 FF FF 00 00 00 FF 80 00 FF FF FF FF 00 ................ 0010 FF 00 FF FF 00 FF 00 00 FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF 00 FF FF FF FF 00 FF 00 FF 01 FF FF ................ 0060 FF FF 00 00 FF FF FF FF FF FF 00 FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 FF FF 00 FF FF FF 00 01 ................ 00B0 FF FF 00 FF 00 00 00 00 FF FF 00 00 FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF 00 FF 00 00 00 FF FF FF FF ................ ------[ SMBus Device B00-D22 ]------ 0000 FFFF FF00 FFFF FF00 FF00 FF00 FF00 FFFF FFFF FFFF 2F80 60FF FFFF FFFF FFFF 6000 0010 6000 60FF 60FF 6000 60FF 6000 FFFF 2000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 6000 6000 60FF FFFF 6000 6000 60FF 6000 FFFF 6000 FFFF FFFF 2F80 FFFF FF00 FF00 0060 FF00 FF00 FFFF FF00 FF00 FFFF FFFF FF00 FFFF 2000 2F01 FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF 60FF 6000 60FF 6000 FFFF 6000 6000 6000 6000 2080 2000 2F01 00B0 6000 60FF 60FF 6000 FFFF 6000 FFFF 6000 6000 6000 6000 FFFF 20FF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF 6000 6000 6000 6000 6000 FFFF 6000 60FF 60FF 6000 FFFF ------[ SMBus Device B00-D24 ]------ 0000 FF 00 00 FF FF 00 FF 00 00 00 FF 00 00 FF 00 FF ................ 0010 00 00 FF FF 00 00 00 00 00 80 00 01 FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF 00 FF FF FF 00 FF 00 00 01 ................ 0060 FF 00 00 FF 00 00 00 00 00 FF 00 FF FF 01 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF 00 00 00 00 FF 00 00 FF 00 FF ................ 00B0 01 FF 01 FF 00 00 FF 00 00 00 FF FF 00 00 00 01 ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF 00 FF 00 00 FF 01 FF ................ ------[ SMBus Device B00-D25 ]------ 0000 FF FF 00 00 00 00 FF 00 00 00 FF 01 01 FF 00 FF ................ 0010 FF 00 FF FF 00 00 00 FF 00 00 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF 00 00 00 FF FF 00 FF 00 00 00 FF FF ................ 0060 81 FF 00 00 FF 00 00 00 00 00 00 00 FF 00 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 FF FF 00 FF FF 00 FF FF ................ 00B0 00 80 00 FF FF 00 00 FF 00 FF FF FF FF 00 00 FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 00 FF 00 00 00 ................ ------[ SMBus Device B00-D26 ]------ 0000 FF 00 FF FF 00 00 00 FF 00 FF 00 FF 01 01 FF 00 ................ 0010 FF FF FF FF 00 00 00 00 FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 00 FF 00 00 FF FF 00 FF FF 00 00 FF 81 ................ 0060 00 00 FF FF 00 00 FF FF 00 00 FF 01 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF 00 00 00 00 00 FF FF FF 00 00 FF FF 00 ................ 00B0 FF 00 FF 00 00 FF 01 FF 01 FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 00 FF FF 00 00 FF FF FF FF FF 80 01 01 FF FF 00 ................ ------[ SMBus Device B00-D26 ]------ 0000 60FF FFFF 60FF FFFF 60FF 6000 60FF 60FF 60FF 60FF FFFF 2001 20FF 2F01 6000 60FF 0010 6000 6000 FFFF 6000 FFFF 6000 60FF FFFF 60FF 20FF 2001 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 6000 6000 FFFF FFFF 60FF 60FF 6000 6000 6000 6000 6000 20FF 2001 0060 FFFF FFFF FFFF FF00 FFFF FF00 FFFF FFFF FFFF FF00 FF00 FF00 2000 2000 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 60FF 6000 FFFF 6000 FFFF 6000 60FF 00B0 FFFF 20FF 2F80 FFFF FFFF FF00 FF00 FFFF FFFF FF00 FFFF FF00 FF00 FF00 2080 2000 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 FFFF 60FF 6000 FFFF ------[ SMBus Device B00-D27 ]------ 0000 FF FF FF 00 FF 00 FF FF 00 00 00 FF 00 FF FF FF ................ 0010 FF FF FF FF FF 00 FF 00 00 FF 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF ................ 0050 FF FF FF FF FF FF 00 FF FF 00 FF FF FF FF 00 00 ................ 0060 FF 00 FF FF 00 FF 80 01 01 01 FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF 00 00 00 00 FF 00 00 FF 00 00 FF 00 00 FF 00 ................ 00B0 00 FF FF 00 FF 00 FF FF FF FF FF 80 FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF 00 00 FF 00 FF 00 00 00 00 00 00 ................ ------[ SMBus Device B00-D27 ]------ 0000 6000 6000 FFFF 6000 FFFF 6000 6000 FFFF 60FF 60FF 2001 FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF 6000 FFFF 6000 6000 FFFF 6000 6000 6000 FFFF FF00 FFFF FF01 FFFF 6081 6000 0060 6000 6000 FFFF 60FF 60FF 6000 FFFF 6000 60FF 2080 FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FF00 FF00 FF00 FFFF FF00 FFFF FFFF FFFF FF00 FF00 FFFF FFFF FF00 2F01 00B0 6000 60FF FFFF 60FF 60FF FFFF FF00 FF00 FFFF FF00 FF00 2001 2001 2F01 FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF 60FF FFFF FF00 FFFF FF00 FFFF FF00 FF00 FFFF FFFF FFFF ------[ SMBus Device B00-D28 ]------ 0000 00 00 FF FF FF FF 01 01 FF 00 00 00 00 FF FF FF ................ 0010 00 FF FF FF 80 FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF 00 FF FF FF FF FF 00 FF 00 FF 00 00 00 FF 00 ................ 0060 FF 00 FF FF FF FF 00 80 FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 ................ 00A0 FF FF 00 FF 00 00 00 FF FF FF FF 01 FF FF 00 00 ................ 00B0 FF FF 00 FF FF 00 00 00 FF 00 01 FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF 00 00 FF 00 00 FF FF 00 FF FF FF 00 ................ ------[ SMBus Device B00-D28 ]------ 0000 6000 60FF 6000 6000 6000 FFFF 6000 60FF 6000 60FF 2000 2001 2FFF FFFF 6000 60FF 0010 6000 60FF FFFF 60FF 6000 6000 FFFF 6000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 6000 6000 6000 60FF 6000 6000 FFFF 60FF 6000 6000 FFFF 2000 FFFF FFFF 0060 FFFF FF00 FFFF FFFF FFFF FFFF FF00 FFFF FFFF FFFF FF00 20FF 2000 FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF 6000 FFFF 6000 6000 6000 6000 60FF 60FF 6000 60FF 00B0 FFFF 2000 FFFF FFFF FFFF FFFF FF00 FFFF FFFF FF00 FFFF FF00 FFFF FFFF FFFF 2F01 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF 6000 6000 6000 6000 FFFF 60FF 60FF 60FF 6000 60FF 60FF 2080 20FF ------[ SMBus Device B00-D29 ]------ 0000 FF 00 FF FF 00 00 00 FF 00 00 00 FF FF FF 00 00 ................ 0010 FF FF 00 00 00 00 FF 00 FF FF 80 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 FF 00 FF 00 FF FF 00 FF FF 00 FF FF ................ 0060 81 00 FF FF 00 00 00 00 00 FF 00 00 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF 00 FF FF 00 00 00 FF 00 00 FF ................ 00B0 00 FF FF FF 00 FF FF 00 00 00 FF FF 00 FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF 00 FF FF FF 00 00 00 00 FF FF FF ................ ------[ SMBus Device B00-D29 ]------ 0000 6000 6000 6000 FFFF FFFF FFFF FFFF 2080 2001 2001 FFFF FF00 FF00 FFFF FF00 FF00 0010 FF00 FF00 FF00 FF00 FFFF 20FF 20FF 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 60FF 6000 6000 6000 6000 FFFF 6000 6000 FFFF 6000 60FF 2000 2000 2F80 60FF 60FF 0060 60FF 6000 6000 6000 6000 60FF 6000 6000 6000 2000 2001 FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF FFFF 00A0 6000 FFFF 6000 6000 60FF 60FF 6000 60FF FFFF FFFF FFFF FFFF 60FF 6000 6000 FFFF 00B0 60FF 60FF 6000 6000 6000 6000 FFFF FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 6000 60FF 6000 60FF 6000 6000 60FF 6000 60FF 6000 60FF FFFF 20FF FFFF 60FF 6000 ------[ SMBus Device B00-D2A ]------ 0000 00 00 00 00 FF FF 00 00 00 00 FF FF FF FF 00 FF ................ 0010 FF FF FF FF 00 00 FF FF FF FF 00 01 FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 00 00 00 FF 00 00 FF 00 FF FF 00 01 ................ 0060 FF 00 00 FF FF FF 00 00 00 00 FF FF FF 01 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF 00 00 FF 00 00 FF 00 FF ................ 00B0 FF 00 FF 80 81 00 00 00 00 00 00 FF FF 00 00 00 ................ 00C0 01 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF 00 ................ ------[ SMBus Device B00-D2A ]------ 0000 60FF 60FF 6000 6000 6000 FFFF FFFF 60FF 6000 60FF FFFF 20FF 2FFF 6000 6000 FFFF 0010 FFFF 60FF 6000 6000 60FF 60FF FFFF FFFF 2000 2000 2F01 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 0050 6000 6000 60FF FFFF 6000 60FF 60FF 60FF FFFF FFFF 2001 6081 6000 60FF FFFF 6000 0060 6000 FFFF 6000 6000 6000 6000 2000 20FF 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 6000 6000 6000 6000 6000 6000 6000 60FF 60FF 60FF 60FF 2000 2000 FFFF 60FF 60FF 00B0 FFFF 6000 6000 60FF 60FF 6000 FFFF 6000 6000 FFFF FF00 2F01 FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF 60FF 60FF FFFF FFFF 6000 6000 6000 60FF 6000 60FF 60FF 2080 ------[ SMBus Device B00-D2B ]------ 0000 FF 00 FF 00 00 FF FF FF FF FF 01 00 00 00 00 FF ................ 0010 FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 00 00 00 00 FF FF 00 00 FF 00 FF FF 80 81 FF 00 ................ 0060 FF FF 00 FF FF FF FF FF 80 FF 80 FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF 00 FF 00 FF 00 FF FF FF 01 80 FF ................ 00B0 FF FF 00 00 00 00 FF 00 00 FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF 00 00 00 FF 00 FF FF 00 00 FF FF ................ ------[ SMBus Device B00-D2B ]------ 0000 60FF 6000 6000 6000 60FF 6000 6000 FFFF 6000 6000 FFFF 2001 FFFF FFFF 60FF 6000 0010 60FF 60FF 6000 6000 6000 6000 6000 6000 2080 2001 2F80 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 6000 6000 6000 60FF 60FF 6000 6000 6000 60FF 6000 6000 2001 FFFF 0060 FFFF FFFF FF00 FF00 FFFF FF00 FF00 FFFF FFFF FFFF FF00 20FF 20FF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 60FF FFFF 60FF FFFF 6000 60FF 6000 00B0 FFFF 2000 FFFF 6081 FFFF 6000 FFFF FFFF 6000 FFFF 6000 60FF 6000 FFFF 2000 FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 6000 6000 FFFF 60FF 60FF ------[ SMBus Device B00-D2D ]------ 0000 00 00 FF FF 00 00 FF FF 00 FF FF 01 00 00 FF 00 ................ 0010 FF 00 FF FF FF FF 00 FF 00 80 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 FF 00 FF FF FF FF 00 FF FF 00 00 01 FF ................ 0060 00 FF 00 FF FF 00 FF FF FF 00 00 FF 01 FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 FF FF 00 FF 00 FF FF FF ................ 00B0 FF FF FF FF FF 00 FF FF 00 00 FF 00 FF 01 FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF 00 00 FF FF 00 00 00 00 00 FF FF FF FF ................ ------[ SMBus Device B00-D2D ]------ 0000 FFFF FF00 FF00 FFFF FF00 FFFF FF00 FFFF FF00 FFFF FF00 FFFF FF00 2F80 6000 FFFF 0010 6000 6000 FFFF 60FF FFFF FFFF FFFF 60FF 6000 FFFF FF00 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 6000 6000 6000 60FF FFFF 60FF FFFF 6000 60FF 6000 6000 FFFF FF00 2F01 0060 6000 6000 60FF 6000 60FF 6000 60FF 6000 60FF 6000 60FF 20FF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FF00 FFFF FF00 FF00 FFFF FF00 FF00 FF00 FF00 FFFF 00B0 FFFF 2F80 6081 FFFF 60FF 6000 60FF 60FF 6000 60FF 6000 FFFF 6000 2080 2000 2F01 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 60FF 6000 6000 FFFF 6000 FFFF ------[ SMBus Device B00-D2F ]------ 0000 FF FF 00 00 FF 00 FF 00 00 80 FF FF 00 00 FF 00 ................ 0010 00 00 FF 00 FF 00 00 FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 00 FF 00 FF FF 00 FF FF 00 FF FF FF 80 ................ 0060 00 FF FF FF 00 FF FF 00 00 00 FF 80 01 FF 01 FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 00 00 FF 00 FF FF FF FF 00 00 FF FF FF FF 00 00 ................ 00B0 FF FF 00 00 FF FF 00 FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF 00 FF FF FF 00 FF FF FF FF FF 00 FF 00 FF 81 ................ ------[ SMBus Device B00-D2F ]------ 0000 6000 60FF 6000 60FF 6000 60FF 6000 60FF 6000 6000 FFFF FFFF 2F80 FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FF00 FFFF FF00 FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF 60FF 6000 6000 FFFF FFFF 60FF 6000 6000 FFFF 6000 6000 2080 2001 FFFF FFFF 0060 6000 6000 6000 FFFF 60FF 6000 6000 6000 FFFF FFFF 2000 20FF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF 6000 FFFF 6000 60FF 6000 FFFF FFFF FF00 FFFF FF00 FFFF FFFF 00B0 2F01 6000 6000 60FF 60FF 60FF FFFF 6000 60FF 6000 FFFF 6000 FFFF FF01 FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 60FF 6000 6000 6000 6000 6000 ------[ SMBus Device B00-D30 ]------ 0000 FF 00 00 00 00 00 FF 00 FF FF 00 FF 01 FF FF FF ................ 0010 00 FF FF FF 00 00 00 FF FF FF 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF ................ 0050 00 FF 00 FF 00 00 00 00 00 FF FF 81 FF 00 FF FF ................ 0060 00 FF 00 00 FF 00 FF FF 01 FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF 00 FF FF 00 FF FF 00 FF 00 FF FF 01 01 81 FF ................ 00B0 00 00 FF 00 FF 00 FF 00 FF FF 01 FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF 00 FF 00 00 FF FF FF 00 FF 00 FF FF FF ................ ------[ SMBus Device B00-D30 ]------ 0000 60FF 60FF 6000 60FF 60FF 60FF 6000 60FF 6000 60FF 20FF 20FF 2FFF 6000 6000 60FF 0010 6000 60FF 6000 60FF 60FF 60FF 60FF 6000 20FF 2000 2F01 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 60FF 6000 60FF 60FF 60FF 6000 6000 6000 6000 6000 6000 2000 2001 0060 FFFF FF00 FF00 FFFF FFFF FF00 FFFF FF00 FF00 FF00 FFFF FFFF 2000 20FF 2F01 FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 6000 60FF 60FF 6000 60FF 6000 6000 60FF 00B0 2000 20FF FFFF FFFF FFFF FF00 FF00 FF00 FF00 FFFF FF00 FF00 FF00 FFFF 2080 2000 00C0 2F01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 60FF 60FF 60FF 6000 60FF ------[ SMBus Device B00-D31 ]------ 0000 00 00 00 FF FF 00 00 FF 00 00 FF FF FF FF FF FF ................ 0010 FF FF 00 FF FF 00 00 00 FF 80 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 00 00 00 FF 00 00 FF 00 FF 00 FF FF FF 01 FF FF ................ 0060 FF FF 00 00 00 00 FF FF 00 FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF 00 00 00 00 FF 00 FF 00 00 FF FF FF ................ 00B0 00 00 FF 00 FF FF FF FF 00 FF FF 80 01 FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF 00 FF FF FF 00 FF FF FF 00 FF ................ ------[ SMBus Device B00-D31 ]------ 0000 60FF 60FF 6000 6000 6000 60FF 60FF 60FF 6000 60FF 2080 2000 2F80 FFFF FF00 FF00 0010 FF00 FF00 FFFF FF00 FFFF FF00 FFFF FFFF 2080 2001 2FFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 60FF 6000 6000 60FF 6000 60FF 60FF 6000 6000 60FF 6000 FFFF FF00 2FFF 0060 6000 6000 60FF 6000 60FF 60FF 60FF 6000 6000 6000 FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 60FF 6000 60FF 60FF 6000 60FF 60FF 60FF 00B0 2000 20FF 2F80 FFFF FF00 FF00 FF00 FFFF FF00 FF00 FFFF FFFF FFFF FFFF 2000 2001 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF 60FF 60FF 6000 6000 FFFF 6000 60FF 6000 60FF 6000 60FF 60FF 20FF ------[ SMBus Device B00-D33 ]------ 0000 FF 00 00 00 FF FF 00 00 00 00 00 FF 00 80 00 00 ................ 0010 FF FF FF 00 00 00 00 FF FF FF FF 01 FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF 00 FF 00 00 FF 00 FF 00 FF FF FF 01 ................ 0060 FF FF 00 00 FF 00 FF 00 00 FF FF FF 00 FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 00 00 FF FF 00 FF 00 00 ................ 00B0 00 00 FF FF 81 FF FF 00 FF 00 00 00 FF 00 FF FF ................ 00C0 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF 00 FF 00 FF 00 ................ ------[ SMBus Device B00-D34 ]------ 0000 FF 00 FF 00 00 FF 00 00 00 FF FF FF 80 81 00 FF ................ 0010 FF 00 FF 00 00 00 00 00 FF 01 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 FF FF FF 00 00 00 FF 00 00 FF FF 01 ................ 0060 00 FF FF FF 00 00 FF FF 00 FF 00 FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF 00 00 FF FF 00 FF 00 FF FF FF 00 FF FF 00 ................ 00B0 00 00 00 00 00 FF FF 00 00 00 FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF 00 00 00 FF 00 00 00 00 FF 00 00 ................ ------[ SMBus Device B00-D34 ]------ 0000 60FF 6000 60FF 60FF 60FF 6000 60FF 6000 60FF 60FF 2080 2000 FFFF 6081 60FF 60FF 0010 6000 6000 6000 6000 6000 60FF 60FF 6000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 6000 6000 60FF 6000 60FF 60FF 6000 60FF 60FF 60FF 6000 2000 2001 0060 6081 6000 6000 60FF 60FF 60FF 6000 6000 60FF 6000 60FF 6000 2000 2000 2F01 FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 60FF 60FF 60FF 6000 6000 6000 6000 00B0 FFFF FFFF FFFF 2FFF 60FF 6000 6000 6000 6000 60FF 6000 6000 6000 6000 6000 2001 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 60FF 6000 6000 ------[ SMBus Device B00-D35 ]------ 0000 FF FF 00 00 00 00 FF 00 00 00 FF 01 01 01 00 FF ................ 0010 00 FF 00 00 00 FF 00 00 00 00 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 ................ 0050 00 00 FF 00 00 00 FF 00 00 80 00 FF 00 00 FF 00 ................ 0060 FF FF FF 00 00 FF 00 FF FF 01 FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF 00 FF FF FF 00 00 FF FF 00 FF 80 01 80 FF ................ 00B0 00 00 00 FF FF 00 FF FF 00 FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF 00 FF 00 00 FF FF 00 00 FF ................ ------[ SMBus Device B00-D35 ]------ 0000 60FF 60FF 60FF 60FF 6000 60FF 6000 60FF 60FF 6000 60FF 2001 20FF 2F01 60FF 6000 0010 60FF 60FF 60FF 60FF 6000 6000 6000 60FF 2080 2001 FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 6000 6000 60FF 60FF 6000 6000 60FF 6000 60FF 60FF 60FF 2001 FFFF 0060 6000 60FF 6000 6000 60FF 6000 60FF 6000 60FF 60FF 6000 2000 20FF 2F80 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF 6000 6000 60FF 60FF 6000 60FF 60FF 60FF 60FF 60FF FFFF 00B0 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FF00 FFFF FF00 FFFF FF00 FF00 FF00 2001 FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 60FF 60FF 6000 60FF 6000 ------[ SMBus Device B00-D36 ]------ 0000 0C 0C 0C 0C 0C 0C 0C 0C 0C 00 0C 0C 0C 0C 00 00 ................ 0010 0C 00 0C 01 00 00 00 00 0C 0C 00 00 0C 01 0C 0C ................ 0020 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 0030 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 0040 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 0050 0C 0C 0C 0C 0C 0C 0C 00 00 00 0C 00 00 0C 0C 01 ................ 0060 01 00 0C 0C 00 0C 00 0C 00 00 80 0C 0C 0C 0C 0C ................ 0070 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 0080 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 0090 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 00A0 0C 0C 0C 0C 00 0C 0C 0C 0C 00 0C 00 0C 00 00 0C ................ 00B0 00 00 00 0C 00 00 00 0C 0C 01 0C 0C 0C 0C 0C 0C ................ 00C0 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 00D0 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 00E0 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C 0C ................ 00F0 0C 0C 0C 00 0C 0C 00 0C 0C 00 00 00 00 0C 0C 81 ................ ------[ SMBus Device B00-D36 ]------ 0000 FFFF FF0C FF0C FF00 FF00 FF00 FF00 FF00 200C 2000 FF0C FF00 FF0C FF0C FF0C FF00 0010 FF0C FF00 FF00 2000 2001 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 0020 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 0030 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 0040 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 6000 600C 6000 600C 0050 600C 6000 600C 600C 600C FF0C FF0C FF0C 2F01 600C 6000 600C 600C 600C 6000 600C 0060 600C FF0C FF01 2F80 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 0070 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 0080 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 0090 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 600C 6000 6000 600C 00A0 600C 600C 6000 6000 600C 2000 2001 FF0C FF0C FF0C FF0C FF00 FF00 FF0C FF00 FF0C 00B0 2000 200C 2F01 FFFF FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 00C0 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 00D0 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 00E0 FF0C FF0C FF0C FF0C FF0C FF0C FF0C FF0C 6000 600C 6000 600C 600C 6000 6000 6000 00F0 2080 2000 2F01 600C 6000 600C 600C 6000 600C 6000 600C 6000 6000 200C 2F01 FFFF ------[ SMBus Device B00-D37 ]------ 0000 00 FF 00 00 00 FF 00 00 00 FF 00 FF FF 80 FF 00 ................ 0010 00 FF FF 00 00 00 00 00 FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF 00 FF 00 00 00 FF ................ 0060 FF FF 00 00 00 00 FF 00 00 FF 00 00 80 01 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF 00 FF 00 FF FF FF ................ 00B0 00 FF FF 81 00 FF FF FF 00 FF FF 00 FF 00 FF FF ................ 00C0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF 00 FF 00 00 FF ................ ------[ SMBus Device B00-D37 ]------ 0000 60FF 60FF 60FF 60FF 6000 6000 6000 60FF 60FF 6000 60FF 2001 2001 2F01 6000 6000 0010 6000 6000 60FF 60FF 60FF 6000 6000 6000 6000 2000 2001 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 60FF 6000 6000 60FF 6000 6000 6000 6000 6000 60FF 6000 2080 2000 2F01 0060 60FF 6000 60FF 6000 60FF 6000 6000 6000 6000 60FF 6000 20FF 20FF 2F01 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 60FF 6000 6000 6000 60FF 60FF 6000 6000 6000 60FF FFFF FF00 2F80 FFFF FF00 FF00 00B0 FFFF FF00 FF00 FF00 FFFF FF00 FFFF FFFF FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF 6000 6000 60FF 6000 6000 60FF 60FF 6000 60FF 60FF 6000 60FF 20FF 20FF 6000 ------[ SMBus Device B00-D38 ]------ 0000 00 FF FF FF 00 FF 00 FF FF 80 00 01 00 FF FF FF ................ 0010 00 FF 00 FF FF FF FF 00 00 FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 FF FF 00 00 00 00 00 00 00 FF FF 00 ................ 0060 FF FF 00 00 00 FF 00 00 FF FF FF 01 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF 81 00 00 FF 00 00 FF FF FF 00 00 FF ................ 00B0 FF FF FF FF FF FF FF 00 FF FF FF FF 00 FF 01 FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF 00 00 00 FF FF 00 00 ................ ------[ SMBus Device B00-D39 ]------ 0000 FF FF 00 00 FF 00 00 00 25 FF FF 00 FF 81 FF 00 ........%....... 0010 00 07 00 00 00 00 00 FF 00 80 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF ................ 0050 00 FF FF 00 00 FF 00 FF 01 FF FF 00 00 00 00 00 ................ 0060 00 00 FF FF 00 FF 00 80 FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 00 00 00 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ................ 0090 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F ................ 00A0 00 00 02 03 04 05 00 07 00 09 0A 0B 0C 81 0E 0F ................ 00B0 00 11 12 00 14 00 16 00 18 01 FF 1B 1C 1D 1E 1F ................ 00C0 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ................ 00D0 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F ................ 00E0 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ................ 00F0 10 11 00 00 00 00 00 00 18 00 00 00 1C 1D 1E 1F ................ ------[ SMBus Device B00-D39 ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF 6B6B FFFF 6000 60FF 6000 6000 6000 6000 60FF 6000 0010 6000 6003 20FF 20FF FFFF 6081 60FF 6000 60FF 60FF 60FF 6000 60FF 6000 60FF FFFF 0020 FFFF 2FFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 60FF 60FF 60FF 0060 60FF 60FF 6000 6000 FFFF FFFF FFFF 2FFF 6000 6000 60FF 6000 6000 60FF 60FF 6000 0070 6000 60FF 20FF 2000 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 0000 FF00 0000 0003 0004 0005 0006 0007 0008 0009 010A 010B 000C 000D 000E 000F 0090 0010 0011 0012 0013 0014 0015 0016 0017 0018 0019 001A 001B 001C 001D 001E 001F 00A0 0000 0001 0002 0003 0004 0005 0006 0007 0008 0009 000A 000B 000C 600D 600E 6000 00B0 FFFF 6000 6012 6013 6000 6015 6000 6000 2018 2019 2F01 6000 6000 6000 6000 6000 00C0 6000 6001 6002 6003 6000 2001 FFFF 0007 0008 0009 000A 000B 000C 000D 010E 010F 00D0 0010 0011 0012 0013 0014 0015 0016 0017 0018 0019 001A 001B 001C 001D 001E 001F 00E0 0000 0001 0002 0003 0004 0005 0006 0007 0008 0009 000A 000B 000C 000D 000E 000F 00F0 0010 0011 0012 0013 0014 0015 0016 0017 0018 0019 001A 001B 001C 001D 011E 001F ------[ SMBus Device B00-D3A ]------ 0000 00 FF FF 00 00 FF 00 FF EF 00 FF 00 FF FF FF 00 ................ 0010 FF 00 FF FF 00 FF 00 FF 00 00 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 81 FF FF FF FF 00 FF FF 00 00 00 FF 01 ................ 0060 FF 81 00 00 00 FF 00 00 FF FF FF FF FF FF 80 FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 00 00 00 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ................ 0090 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F ................ 00A0 00 01 02 03 04 05 06 07 08 09 0A 0B 00 0D 00 00 ................ 00B0 10 01 80 00 00 15 00 00 FF 00 00 1B 00 00 1E 1F ................ 00C0 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ................ 00D0 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F ................ 00E0 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F ................ 00F0 10 11 12 13 14 15 00 00 00 19 1A 00 1C 00 00 1F ................ ------[ SMBus Device B00-D3A ]------ 0000 FFFF FFFF FFFF FFFF FFFF FFFF BBBB FFFF 6000 6000 6000 6000 6000 6000 6000 6000 0010 60FF 6000 2000 20FF FFFF 6081 6000 6000 60FF FFFF FFFF FFFF FF00 FF00 FFFF FF00 0020 2000 20FF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 6000 6000 0060 60FF 60FF 60FF 6000 60FF FFFF FFFF FF01 2F01 6000 6000 6000 60FF 6000 6000 6000 0070 6000 60FF 60FF 20FF 2000 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 0100 FF00 0000 0003 0004 0005 0006 0007 0008 0009 000A 000B 000C 000D 000E 000F 0090 0110 0011 0012 0013 0014 0015 0016 0017 0018 0019 001A 001B 001C 001D 001E 001F 00A0 0000 0001 0002 0003 0004 0005 0006 0007 0008 0009 000A 000B 000C 000D 6000 6000 00B0 6010 6011 6012 6013 6014 6000 6000 2000 2001 6081 601A 6000 001C 001D 0000 0000 00C0 0000 0000 0000 2003 2000 0105 0006 0007 0008 0009 000A 000B 000C 000D 000E 000F 00D0 0010 0011 0012 0013 0114 0015 0016 0017 0018 0019 001A 001B 001C 001D 001E 001F 00E0 0000 0001 0002 0003 0004 0005 0006 0007 0008 0009 000A 000B 000C 000D 000E 000F 00F0 0010 0011 0012 0013 0014 0015 0016 0017 0018 6019 6000 601B 601C 6000 6000 6000 ------[ SMBus Device B00-D3B ]------ 0000 03 00 00 00 00 00 00 00 00 00 00 11 11 88 88 00 ................ 0010 00 00 00 03 00 00 21 00 00 00 FF 00 00 11 88 03 ......!......... 0020 00 00 00 00 00 FF 80 38 8E 00 00 00 00 00 00 00 .......8........ 0030 00 00 00 68 FF FF FF FF FF FF FF FF FF FF FF FF ...h............ 0040 FF FF FF FF FF 03 00 17 05 FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 00 FF FF FF 00 FF 00 00 FF FF FF 80 FF 00 00 FF ................ 0070 00 FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF 00 00 00 00 FF FF FF 00 FF FF FF 00 FF FF 00 ................ 00C0 00 00 FF FF 00 00 00 FF FF FF 00 FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B00-D3B ]------ 0000 0003 0000 0000 0000 0000 0000 0000 0000 0000 0000 1100 1111 8811 8888 0088 0000 0010 0000 0000 0300 0003 B000 21B0 7020 0270 0002 0000 0000 0000 6000 8811 8888 8800 0020 8800 8800 8800 8800 1100 1111 3855 6081 608E 6000 6000 6000 6000 6000 6000 6000 0030 2000 2000 2F01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF 0003 FF00 0517 FF05 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 60FF 60FF 0070 60FF 6000 6000 60FF 6000 6000 60FF 20FF 20FF FFFF 60FF 60FF 60FF 6000 60FF 60FF 0080 6000 6000 6000 60FF 2000 2000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF 2187 FF21 FFFF FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 6000 60FF 60FF 60FF 00C0 60FF 60FF 6000 2000 20FF FFFF 6081 6000 6000 60FF 60FF 6000 60FF 60FF 60FF 60FF 00D0 2000 2000 2F80 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ SMBus Device B00-D3E ]------ 0000 FF 00 FF FF 00 00 FF FF 00 FF 00 FF FF FF 00 00 ................ 0010 FF FF FF FF FF 00 FF FF 00 00 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 FF 00 00 00 00 FF 00 FF 00 FF FF 00 01 ................ 0060 FF 00 FF FF FF 00 00 00 FF 00 00 FF FF 80 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF 00 00 FF 00 00 FF FF 00 FF ................ 00B0 00 00 00 FF 81 00 00 FF 00 FF 00 FF 00 FF 80 00 ................ 00C0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF 00 ................ ------[ SMBus Device B00-D3F ]------ 0000 FF FF FF FF 00 FF 00 FF FF 00 FF FF 01 FF 00 FF ................ 0010 FF FF 00 00 FF FF 00 FF 80 FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 81 00 ................ 0050 00 00 FF FF 00 00 FF FF FF 00 01 FF 81 FF FF FF ................ 0060 FF 00 00 00 FF FF FF FF 80 FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 00 FF 00 FF 00 FF FF FF 00 00 FF FF 00 FF FF 00 ................ 00B0 00 00 FF FF 00 00 FF FF FF 00 00 01 FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF 00 00 00 00 00 00 00 FF FF 00 FF 00 ................ ------[ SMBus Device B00-D3F ]------ 0000 6000 6000 6000 FFFF 6000 6000 60FF 60FF 2000 2000 2FFF 6000 6000 FFFF 60FF 6000 0010 6000 6000 6000 6000 6000 FFFF FFFF FFFF FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 6000 60FF 6000 6000 6000 6000 6000 6000 FFFF 6000 FFFF FFFF FFFF FFFF FFFF FFFF 0060 FF00 FF00 FFFF FF00 FFFF FF00 FF00 FF00 FFFF FF01 FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF 6000 6000 6000 6000 FFFF 6000 FFFF 60FF FFFF 6000 6000 FFFF FF00 2F01 00B0 60FF 60FF 6000 FFFF 6000 6000 60FF 6000 6000 6000 6000 2000 FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 60FF FFFF 6000 60FF 6000 6000 FFFF 60FF ------[ SMBus Device B00-D40 ]------ 0000 00 00 00 FF FF 00 FF 00 00 00 FF 00 80 FF FF FF ................ 0010 FF 00 FF FF 00 00 00 00 FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 00 00 00 00 FF 00 FF FF FF 00 00 01 81 ................ 0060 FF FF FF 00 FF 00 00 FF FF 00 FF FF 01 FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF 00 00 FF FF FF 00 00 00 00 FF ................ 00B0 FF 00 FF 01 00 00 FF 00 00 FF 00 FF 00 00 FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF 00 00 00 00 FF FF 00 ................ ------[ SMBus Device B00-D40 ]------ 0000 FFFF FFFF FF00 FFFF FFFF FFFF FFFF FFFF FF00 FF00 FFFF 2001 2001 2FFF 6000 6000 0010 6000 6000 6000 6000 6000 6000 6000 FFFF 60FF 2000 FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF 60FF 6000 FFFF 60FF 60FF 6000 6000 60FF 6000 6000 2001 2F80 0060 60FF 6000 60FF 6000 6000 6000 FFFF 60FF 6000 60FF 60FF FFFF FFFF FF01 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF 6000 6000 6000 FFFF 60FF FFFF 6000 6000 60FF 6000 2080 00B0 2000 FFFF FFFF FF00 FFFF FF00 FFFF FF00 FF00 FFFF FFFF FF00 FF00 FFFF 20FF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF 60FF 6000 60FF 6000 6000 FFFF 6000 6000 60FF 6000 FFFF FF00 ------[ SMBus Device B00-D41 ]------ 0000 FF FF 00 FF 00 FF FF FF 01 FF 00 00 00 00 00 00 ................ 0010 00 00 00 80 01 FF 01 FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF 00 FF FF FF FF FF 00 FF FF 00 01 00 00 00 FF ................ 0060 FF FF FF 00 00 FF 00 FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF 00 FF FF FF 00 00 00 FF FF FF 01 FF FF ................ 00B0 00 FF 00 FF FF FF 00 00 00 FF 80 FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF 00 FF 00 00 00 00 FF FF 00 00 01 FF ................ ------[ SMBus Device B00-D41 ]------ 0000 6000 FFFF 60FF FFFF FFFF FFFF FF00 FFFF FFFF FFFF FFFF 2001 2001 FFFF FFFF FFFF 0010 FFFF FFFF FF00 FF00 FFFF FFFF FFFF FFFF FF00 FF00 2001 2F80 FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF 60FF 6000 6000 6000 6000 60FF 6000 6000 6000 6000 FFFF 0060 FFFF 6081 6000 60FF 6000 6000 FFFF 60FF 6000 FFFF 6000 FFFF 60FF 20FF 20FF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF 6081 6000 60FF 6000 6000 60FF 6000 FFFF 6000 6000 FFFF FFFF 20FF 2001 00B0 FFFF FFFF FF00 FFFF FFFF FFFF FF00 FF00 FFFF FFFF FFFF FFFF FFFF FF01 FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 FFFF 6000 6000 60FF 6000 60FF 6000 ------[ SMBus Device B00-D43 ]------ 0000 00 FF 00 00 FF 00 00 80 FF FF FF 00 00 FF FF FF ................ 0010 00 FF FF FF FF 01 01 FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 FF FF 00 FF FF FF 00 80 FF 80 FF FF FF ................ 0060 00 FF 00 FF 00 00 00 FF FF FF 00 FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF 00 FF FF FF 00 FF 00 FF 00 FF 00 01 ................ 00B0 FF FF 00 FF 00 00 FF 00 FF 00 00 FF FF 01 80 FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF 81 FF FF 00 FF 00 00 FF 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FF FF 00 00 00 FF 00 00 FF 00 00 00 FF FF FF FF ................ 0010 FF FF FF 00 00 00 00 00 FF 00 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 ................ 0050 FF 00 00 FF 00 00 FF 00 00 FF FF FF 00 FF FF FF ................ 0060 FF FF 00 FF 00 FF 00 00 FF 80 FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF 00 FF 00 00 FF 00 FF 00 00 00 FF 01 FF FF ................ 00B0 FF 00 00 00 FF 00 FF 00 00 FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF 00 00 00 00 FF FF 00 00 00 00 00 ................ ------[ SMBus Device B00-D44 ]------ 0000 FFFF FFFF FF00 FFFF FF00 FFFF FFFF FF00 FF00 FFFF 2001 FFFF 6081 6000 6000 60FF 0010 6000 60FF 6000 6000 FFFF 6000 6000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 60FF FFFF FFFF 6000 FFFF FF00 FFFF FFFF FFFF FF00 FF00 FFFF FFFF FFFF 0060 6000 FFFF 60FF 6000 FFFF FFFF FFFF FFFF FFFF FFFF FF00 2000 2000 2F80 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF00 FF00 FF00 FF00 FF00 FF00 FF00 FFFF FF00 00B0 20FF 20FF FFFF FFFF FF00 FFFF FFFF FFFF FFFF FF00 FFFF FF00 FFFF FF00 2080 FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF FFFF FFFF 60FF FFFF 6000 60FF ------[ SMBus Device B00-D45 ]------ 0000 00 FF 00 FF 00 00 00 FF 00 FF FF 01 FF 00 FF 00 ................ 0010 FF FF FF FF FF 00 00 FF 00 FF 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF 00 00 00 FF 00 FF FF FF FF FF FF 80 01 80 FF ................ 0060 FF FF 00 00 FF FF 00 00 00 FF 00 01 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF 00 FF FF FF FF FF FF FF 00 00 FF FF 81 ................ 00B0 00 00 00 FF FF 00 00 FF 00 00 FF FF 01 FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF 00 00 FF FF 00 00 FF 00 00 00 ................ ------[ SMBus Device B00-D45 ]------ 0000 60FF FFFF 60FF FFFF 60FF 60FF 6000 6000 60FF 60FF FFFF FF00 FFFF FFFF FFFF FF00 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF00 2080 FFFF 2F80 FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF 60FF 60FF 6000 6000 6000 6000 FFFF FFFF 60FF 60FF 6000 FFFF FFFF 2F01 0060 6000 6000 6000 6000 6000 60FF 6000 FFFF 6000 6000 6000 20FF 20FF 2F80 FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF 6000 60FF 6000 6000 6000 FFFF 6000 60FF 6000 FFFF 00B0 FFFF FFFF 2F01 6000 6000 6000 6000 6000 6000 6000 FFFF 60FF 6000 FFFF 20FF 20FF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF 60FF 6000 60FF 60FF FFFF 60FF 6000 6000 60FF 6000 FFFF FFFF ------[ SMBus Device B00-D47 ]------ 0000 FF FF 00 00 FF FF 00 00 FF 00 FF FF 80 FF 00 00 ................ 0010 00 FF 00 00 00 00 00 00 FF 01 80 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF 00 00 00 FF 00 FF 00 FF 80 00 01 ................ 0060 00 00 FF 00 FF 00 00 00 FF 00 00 FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF 00 FF FF FF FF 00 FF 00 FF 00 ................ 00B0 FF FF FF FF 00 FF FF 00 00 FF 00 FF 00 00 00 01 ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 FF 00 00 00 00 ................ ------[ SMBus Device B00-D47 ]------ 0000 6000 6000 60FF 6000 60FF 6000 6000 6000 60FF 60FF 6000 2001 2001 FFFF 6000 60FF 0010 60FF 60FF 60FF 60FF 60FF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 6000 60FF 6000 6000 60FF 6000 6000 6000 FFFF 60FF 6000 FFFF 2000 0060 2F01 FFFF 60FF FFFF 6000 FFFF 6000 6000 60FF 60FF 6000 FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF 6000 60FF 6000 6000 FFFF FFFF 60FF 6000 60FF FFFF 20FF 2000 FFFF 6000 60FF 00B0 6000 6000 6000 60FF 60FF 60FF 60FF 6000 FFFF FFFF FF00 2F01 FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF 60FF 6000 6000 6000 60FF FFFF 6000 6000 60FF 60FF 6000 2000 ------[ SMBus Device B00-D49 ]------ 0000 FF FF 00 00 00 FF FF 00 FF 00 01 FF 00 FF 00 00 ................ 0010 00 FF FF 00 00 00 FF FF FF 01 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 00 FF 00 FF FF FF FF 00 00 00 01 FF ................ 0060 FF FF 00 FF 00 00 00 00 00 00 FF 80 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF 00 00 00 FF 00 00 00 FF 00 FF FF FF ................ 00B0 80 FF 00 00 00 00 FF FF 00 00 FF 00 00 FF 01 FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF 00 FF 00 00 ................ ------[ SMBus Device B00-D49 ]------ 0000 FFFF 60FF 60FF FFFF 6000 6000 6000 FFFF 6000 60FF 2001 FFFF 6000 60FF FFFF FFFF 0010 60FF 6000 60FF 60FF 6000 60FF FFFF FF01 FF01 2F01 FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 60FF 60FF 0050 6000 FFFF 6000 6000 6000 6000 60FF FFFF 20FF 20FF FFFF 60FF FFFF FFFF 6000 60FF 0060 6000 60FF 60FF 6000 6000 2080 2001 20FF 2F01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 6000 FFFF FFFF 6000 6000 6000 6000 6000 FFFF FFFF 6000 2000 FFFF 2001 FFFF FFFF 00B0 FFFF FF00 FFFF FFFF FF00 FF00 FF00 FF00 FFFF FFFF FFFF 2F01 FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF 6000 6000 6000 60FF 60FF 6000 6000 FFFF 6000 FFFF 6000 20FF ------[ SMBus Device B00-D4A ]------ 0000 FF FF FF 00 FF FF 00 FF FF 00 FF FF FF FF 00 FF ................ 0010 00 FF 00 FF 00 00 00 00 00 00 FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 FF 00 00 FF 00 FF 00 FF FF 00 FF FF 01 ................ 0060 00 00 00 00 FF 00 00 00 FF FF FF 00 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF 00 FF FF FF 00 FF 00 00 ................ 00B0 00 00 FF FF FF 00 FF 00 00 00 00 FF 00 00 FF FF ................ 00C0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF 00 00 00 FF FF 00 ................ ------[ SMBus Device B00-D4A ]------ 0000 FFFF FFFF 60FF 60FF FFFF 6000 6000 6000 6000 FFFF FFFF 2F01 6000 FFFF 6000 6000 0010 FFFF 6000 6000 60FF FFFF 60FF 6000 2000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF 60FF 6000 FFFF FFFF FF00 FFFF FFFF FFFF FF00 FFFF 20FF FFFF FFFF 0060 FF00 FF00 FF00 FF00 FF00 FFFF FF00 FF00 FFFF FF00 FFFF FFFF 20FF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF 60FF FFFF 6000 FFFF 6000 6000 6000 FFFF 60FF 6000 2000 00B0 20FF 6001 6000 60FF 60FF 6000 6000 FFFF 60FF 6000 FFFF FF00 FFFF FF00 20FF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 60FF 6000 60FF 6000 FFFF 60FF 60FF FFFF ------[ SMBus Device B00-D4B ]------ 0000 00 00 00 00 FF 00 FF FF FF FF 01 01 FF 00 00 FF ................ 0010 FF 00 00 00 FF 00 FF FF FF FF 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 FF 00 00 00 00 FF 00 00 00 FF FF 01 FF ................ 0060 FF 00 00 FF 00 00 00 FF 00 00 00 01 FF 01 FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF 00 FF 00 00 FF 00 00 FF 00 FF ................ 00B0 FF FF 00 FF FF FF 00 FF 00 FF 00 FF FF 00 FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF 00 00 00 00 00 FF 00 00 80 FF ................ ------[ SMBus Device B00-D4B ]------ 0000 60FF 60FF 60FF 60FF 60FF FFFF 60FF 6000 6000 60FF 2001 FFFF 6081 FFFF 60FF 60FF 0010 6000 6000 6000 6000 60FF 6000 6000 20FF 2000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF 6000 FFFF 6000 6000 FFFF 60FF 6000 60FF 60FF 6000 FFFF FFFF FF01 FFFF FFFF 0060 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FFFF FF00 FFFF 2000 2001 FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF 6000 6000 60FF FFFF 60FF 6000 6000 6000 6000 60FF 6000 FFFF FFFF 00B0 FFFF 6081 6000 6000 60FF FFFF FFFF 6000 6000 60FF FFFF 6000 6000 FFFF FFFF 2F01 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 6000 6000 FFFF 60FF 6000 6000 60FF FFFF ------[ SMBus Device B00-D4C ]------ 0000 FF 00 00 00 00 FF FF FF FF 00 FF 00 FF FF FF 00 ................ 0010 00 00 00 FF 00 FF 00 00 FF FF 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 FF FF FF FF 00 00 00 00 00 00 00 FF FF ................ 0060 FF 00 FF 00 00 00 FF FF 00 FF 00 01 01 FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 ................ 00A0 00 00 00 FF 00 FF FF 00 00 00 FF FF 80 FF FF FF ................ 00B0 00 00 00 FF 00 FF 00 80 FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF 00 00 FF 00 FF FF FF 00 FF FF FF 00 80 FF ................ ------[ SMBus Device B00-D4D ]------ 0000 FF 00 FF 00 FF 00 FF FF 00 FF FF 01 FF 01 00 00 ................ 0010 00 00 FF FF 00 00 00 00 00 FF 01 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF 00 00 00 FF 00 00 00 00 00 FF 00 FF FF 01 00 ................ 0060 FF FF 00 00 FF 00 00 00 00 FF 00 80 FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF 00 FF FF FF 00 00 FF 00 00 FF FF ................ 00B0 80 FF FF 00 00 00 00 00 FF FF FF 00 FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF 00 FF 00 FF FF 00 FF FF ................ ------[ SMBus Device B00-D4E ]------ 0000 00 00 FF FF FF FF FF 00 FF 00 00 FF 01 FF 00 00 ................ 0010 00 FF 00 FF FF 00 00 00 FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF 00 00 00 FF FF FF FF FF 00 01 FF 00 00 FF ................ 0060 00 FF 00 FF 00 00 FF 00 00 FF 01 FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF 00 FF 00 00 00 FF FF 00 FF FF FF 00 FF ................ 00B0 00 FF 00 00 FF FF 00 00 00 00 FF 00 FF 80 FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF 00 00 00 00 00 FF FF FF FF 00 ................ ------[ SMBus Device B00-D4F ]------ 0000 FF 00 FF FF FF FF 00 FF 00 00 FF FF 00 80 00 00 ................ 0010 00 FF 00 00 00 FF FF 00 FF FF 00 FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF 00 00 FF 00 00 FF FF FF FF 00 00 80 FF ................ 0060 FF 00 FF 00 00 00 FF FF 00 FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF 00 00 00 00 00 00 FF 00 FF FF ................ 00B0 FF 01 FF FF 00 FF 00 00 00 FF 00 00 FF 00 FF FF ................ 00C0 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF 00 ................ *** SMBus Semaphore Disabled = 0 ------[ Chips Found ]------ B00-D45: uPI uP???? B00-D47: uPI uP???? Dump took 26.7 sec Quote
Fiery Posted March 27, 2021 Posted March 27, 2021 On 3/24/2021 at 5:25 PM, JayK said: My SPD is coming up completely blank even though I have 2 x 8gb Sticks of G Skill Trident Z Neo 3600 Samsung B Die Ram in A2 n B2 slots. Here is my full Bus Dump. The SMBus on your motherboard seems to be working improperly. I'm not sure why that is, but until that anomaly is present, you won't be able to see any SPD information reported by AIDA64 or other tools (like CPU-Z) either. Quote
Edmond Posted September 19, 2021 Posted September 19, 2021 On 4/14/2020 at 8:22 PM, Fiery said: You can check if AIDA64 has the necessary privileges to load its kernel driver (which is necessary to detect SPD information) if you check whether the CPU multiplier and FSB (BCLK) are properly measured on the Motherboard / CPU page or on the CPUID Panel (main menu / Tools / CPUID Panel). My SPD also not showing anything, CPUID can read multipliers, bus clock and speed etc. But CPU-z has SPD info Quote
Fiery Posted September 20, 2021 Posted September 20, 2021 17 hours ago, Edmond said: My SPD also not showing anything, CPUID can read multipliers, bus clock and speed etc. But CPU-z has SPD info Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
