AIDA64 Discussion Forum
CaneMan
Core Voltage not showing (ASRock X570 Extreme4 + Ryzen 7 3800X)
New to AMD so apologies if this has been asked before. I have noticed that the Core Voltage in CPUID does not show the correct volts. Is this a bug or an AMD anomaly.?
Share this post
Link to post
Are you sure the Vcore is correct in CPU-Z and incorrect in AIDA64?  Try to compare the value measured by AIDA64 against ASRock's own monitoring software.
Share this post
Link to post
Shows the same as BIOS. I also notice the Voltage does not change in System Stability Test and CPUID,when running Stress CPU
Share this post
Link to post
On 5/12/2020 at 11:39 AM, CaneMan said:
Hi Fiery,
Nothing new about this?
We will fix the issue in the next AIDA64 beta update.  I will post a message into this topic once the new beta build is available for download.
Share this post
Link to post
On ‎5‎/‎12‎/‎2020 at 11:39 AM, CaneMan said:
Hi Fiery,
Let me know how it works.
Share this post
Link to post
Updated, rebooted still the same.
Please post a screenshot or copy-paste of the Computer / Sensor page of AIDA64.  Make sure to have all voltages shown on the screenshot (if it's a screenshot).
Share this post
Link to post
On 5/26/2020 at 10:37 PM, CaneMan said:
Here you go.
Thank you!  We will fix the issue in the next AIDA64 beta update.  I will post a message into this topic once the new beta build is available for download.  (sorry to repeat myself here ;) )
Share this post
Link to post
The mentioned new AIDA64 beta update is now available for download at:
Share this post
Link to post
Loading...
