steeviebops Posted May 8, 2020 Posted May 8, 2020 Hi guys, I recently got a new HP ZBook 15 G5 but AIDA64 seems to cause a few issues with it. The SPD page shows blank and if I attempt to open the Sensor page, it sits on Detecting and never stops. At this time, programs start getting unresponsive and I need to reboot the laptop to get it back to normal. I tried to create a full SMBus dump. It took over 6 minutes to generate but didn't return much as you can see in the attached file. smbusdump_full.txtFetching info... Quote
steeviebops Posted May 8, 2020 Author Posted May 8, 2020 Quick update, disabling low level SMBus operations allows me to access the sensors without issue. Quote
Fiery Posted May 9, 2020 Posted May 9, 2020 On 5/8/2020 at 4:54 PM, steeviebops said: Quick update, disabling low level SMBus operations allows me to access the sensors without issue. Expand We will fix the issue by disabling SMBus support for your notebook in the next AIDA64 beta update. Quote
Fiery Posted May 24, 2020 Posted May 24, 2020 On 5/8/2020 at 4:54 PM, steeviebops said: Quick update, disabling low level SMBus operations allows me to access the sensors without issue. Expand The above mentioned fix for AIDA64 is now available for download at: https://www.aida64.com/downloads/latesta64xebeta Quote
