Omari Posted May 8, 2020 Posted May 8, 2020 Hi, the prevent sensor panel from being minimized is not working. It only works if we select to "keep the sensor panel on top other windows" option. Aida64 Engineer version Quote
Fiery Posted May 14, 2020 Posted May 14, 2020 On 5/8/2020 at 8:45 PM, Omari said: Hi, the prevent sensor panel from being minimized is not working. It only works if we select to "keep the sensor panel on top other windows" option. Aida64 Engineer version Yes, you need to use both options in the same time. Quote
Omari Posted May 19, 2020 Author Posted May 19, 2020 Can this be fixed or adjusted? So that it stays on the desktop. (Similar to Rainmeter, which has an option to set any widget displayed on the desktop) ...................................................... Also Aida quits when the PC goes into Hybrid Sleep mode and you have to restart the program everytime. Can this be fixed in the next update? Thanks for the responses, I know its a difficult time globally Quote
