ghot Posted August 3, 2020 Posted August 3, 2020 I have no power supply voltages on either the Statistics tab or the OSD configure page. I'm not saying the voltages are zero, I'm saying they don't even exist. AIDA64 Extreme 6.25.5400 My CURRENT system... Windows 10 Home (2004) x64 [10.0.19041.423] AMD Ryzen 7 3700X (00-100000071BOX)ASUS Pro WS X570-ACE (2103 BIOS) EVGA 08G-P4-2171-KR Geforce RTX 2070 8GB 256-bit GDDR6 G.Skill Trident Z 16 GB (2 x 8 GB) DDR4-3200 (F4-3200C14D-16GTZKW) COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 CPU Cooler (push/pull) Samsung 860 EVO 500GB (MZ-76E500) WD 2TB Caviar Black FZEX - SATA III WD 2TB Caviar Black FZEX - SATA III LG GH22LS30 CD/DVD Burner PC Power & Cooling Silencer 750W Quad EPS12V DELL Ultrasharp U3011, 30" monitor Klipsch Pro Media 2.1 THX Speakers (Black) Ducky DK9008 Shine II Blue LED Backlit Mechanical Keyboard (Cherry MX Black) Logitech Optical M-100 COOLER MASTER ATCS 840 Full Tower Case 3x230mm, 1x120mm, Optional: 3x Scythe S-Flex SFF21G 120mm (installed) On older versions of AIDA64 Extreme, and this older system, they DID exist and worked fine. Windows 7 Home Premium x64 SP1 AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor ASUS SABERTOOTH 990FX R2.0 AM3+ SATA 6Gb/s USB 3.0 ATX Motherboard ( 2901 BIOS) PC Power & Cooling Silencer 750W Quad EPS12V Thanks in advance for any assistance. Quote
Fiery Posted August 3, 2020 Posted August 3, 2020 12 minutes ago, ghot said: I have no power supply voltages on either the Statistics tab or the OSD configure page. I'm not saying the voltages are zero, I'm saying they don't even exist. AIDA64 Extreme 6.25.5400 My CURRENT system... Windows 10 Home (2004) x64 [10.0.19041.423] AMD Ryzen 7 3700X (00-100000071BOX)ASUS Pro WS X570-ACE (2103 BIOS) EVGA 08G-P4-2171-KR Geforce RTX 2070 8GB 256-bit GDDR6 G.Skill Trident Z 16 GB (2 x 8 GB) DDR4-3200 (F4-3200C14D-16GTZKW) COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 CPU Cooler (push/pull) Samsung 860 EVO 500GB (MZ-76E500) WD 2TB Caviar Black FZEX - SATA III WD 2TB Caviar Black FZEX - SATA III LG GH22LS30 CD/DVD Burner PC Power & Cooling Silencer 750W Quad EPS12V DELL Ultrasharp U3011, 30" monitor Klipsch Pro Media 2.1 THX Speakers (Black) Ducky DK9008 Shine II Blue LED Backlit Mechanical Keyboard (Cherry MX Black) Logitech Optical M-100 COOLER MASTER ATCS 840 Full Tower Case 3x230mm, 1x120mm, Optional: 3x Scythe S-Flex SFF21G 120mm (installed) On older versions of AIDA64 Extreme, and this older system, they DID exist and worked fine. Windows 7 Home Premium x64 SP1 AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Eight-Core Desktop Processor ASUS SABERTOOTH 990FX R2.0 AM3+ SATA 6Gb/s USB 3.0 ATX Motherboard ( 2901 BIOS) PC Power & Cooling Silencer 750W Quad EPS12V Thanks in advance for any assistance. Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. 1 Quote
ghot Posted August 3, 2020 Author Posted August 3, 2020 26 minutes ago, Fiery said: Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. That link is to a portable zip version of the Beta? How do I use that to... "Upgrade"? Quote
Fiery Posted August 3, 2020 Posted August 3, 2020 6 minutes ago, ghot said: That link is to a portable zip version of the Beta? How do I use that to... "Upgrade"? Beta builds only have portable ZIP package versions. You can just close AIDA64, download the ZIP package, and extract it to the existing installation folder of AIDA64. Let it overwrite any existing files. It will retain your settings and license as well. 1 Quote
ghot Posted August 3, 2020 Author Posted August 3, 2020 13 minutes ago, Fiery said: Beta builds only have portable ZIP package versions. You can just close AIDA64, download the ZIP package, and extract it to the existing installation folder of AIDA64. Let it overwrite any existing files. It will retain your settings and license as well. Ok, I'm probably doing something wrong. VERY new to Windows 10. Tried extracting to C:\Program Files (x86)\FinalWire\AIDA64 Extreme folder. Tried to extract to the FinalWire folder... same message. Extracted to a "New" folder on Desktop, then copy/pasted/replaced into the C:\Program Files (x86)\FinalWire\AIDA64 Extreme folder. Rebooted comp, but no change. Still no power supply voltages. Same as pic in post #1. Quote
Fiery Posted August 3, 2020 Posted August 3, 2020 5 minutes ago, ghot said: Ok, I'm probably doing something wrong. VERY new to Windows 10. Tried extracting to C:\Program Files (x86)\FinalWire\AIDA64 Extreme folder. Tried to extract to the FinalWire folder... same message. Extracted to a "New" folder on Desktop, then copy/pasted/replaced into the C:\Program Files (x86)\FinalWire\AIDA64 Extreme folder. Rebooted comp, but no change. Still no power supply voltages. Same as pic in post #1. Try to move the whole AIDA64 folder to e.g. C:\AIDA64 1 Quote
ghot Posted August 3, 2020 Author Posted August 3, 2020 14 minutes ago, Fiery said: Try to move the whole AIDA64 folder to e.g. C:\AIDA64 Ok, moved the AIDA64 Extreme folder to C:\ ...ran a new shortcut from aida64.exe Rebooted comp just to be sure? Still no power supply voltages. Also, might as well mention, that there is no entry in the OSD config for the CPU Optional cooling fan. The CPU cooling fan is there. This is a NOT normal motherboard. Asus calls it a workstation board. This is a VERY old (but high quality) power supply. Probably 10-13 years old. I'm also not sure if it makes a difference, But I installed Windows 10 Home without a System or a Recovery partition.The System partition is incorporated into the C;\ drive proper. Quote
Fiery Posted August 3, 2020 Posted August 3, 2020 2 minutes ago, ghot said: Ok, moved the AIDA64 Extreme folder to C:\ ...ran a new shortcut from aida64.exe Rebooted comp just to be sure? Still no power supply voltages. Also, might as well mention, that there is no entry in the OSD config for the CPU Optional cooling fan. The CPU cooling fan is there. This is a NOT normal motherboard. Asus calls it a workstation board. I'm also not sure if it makes a difference, But I installed Windows 10 Home without a System or a Recovery partition.The System partition is incorporated into the C;\ drive proper. If it still doesn't work as you'd expect, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Use the latest AIDA64 beta build of course Thanks, Fiery 1 Quote
ghot Posted August 3, 2020 Author Posted August 3, 2020 3 minutes ago, Fiery said: If it still doesn't work as you'd expect, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Use the latest AIDA64 beta build of course Thanks, Fiery ------[ Versions ]------ Program Version : AIDA64 Extreme v6.25.5458 Beta BenchDLL Version: 4.5.825.8-x64 Windows Version : Microsoft Windows 10 Home 10.0.19041.423 (64-bit) GetProductInfo : 0x00000065 ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-122418-Chipset$0AAAA000_BIOS DATE: 06/19/20 16:55:22 VER: 05.00011 Motherboard Model : Asus Pro WS X570-ACE Motherboard Chipset : AMD Bixby X570, AMD K17.7 FCH, AMD K17.7 IMC DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : Pro WS X570-ACE DMI MB Version : Rev X.0x DMI MB Serial : 191162314200500 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 2103 ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h ( 0000h / 0000h) ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h) ITE SuperIO Device ID = 0000h ( 0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 2Eh Winbond SuperIO HWMonitor Port/60 = 0290h (0290h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0A00h (0A00h / 0000h) Winbond SuperIO Device ID = D42Bh (D42Bh / 0000h) Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1 Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------ 0000 03 99 03 FF 00 FF FF FF FF FF FF FF FF FF FF FF 0010 03 99 03 99 03 99 03 FF 40 FF FF FF FF FF FF FF 0020 FF FF FF FF FF FF FF 17 03 FF FF DA 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 50 4B FF FF FF FF FF 0040 03 00 40 FF FF 00 3F FF 2D FF FF 10 08 55 00 A3 0050 15 FF FF FF FF FF FF FF C1 FF FF FF FF 01 00 01 0060 AA AF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF 0070 00 0A 00 1A 00 1A 00 1A 00 1A 00 15 80 15 80 FF 0080 FF FF FF FF FF 05 05 05 00 00 00 00 00 00 00 00 0090 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4 00A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 03 00 00B0 00 00 00 00 00 00 21 00 04 10 00 34 28 FF 04 00 00C0 FF FF FF FF FF FF FF FF FF 11 0C 05 FF FF FF FF 00D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD 00E0 55 80 00 00 00 FF FF FF FF FF 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 FF 1C 40 1F 1B 5E FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------ 0000 1C 00 40 00 00 01 01 3C 00 99 FF 99 00 FF FF FF 0010 FF 19 23 2D 37 FF FF 8C AA C8 E6 32 00 01 01 00 0020 FF 1E 46 46 4B FF FF 99 FF FF FF FF FF FF FF FF 0030 FF 00 FF FF 00 7D 01 FF 02 FF FF FF FF FF FF 00 0040 FF FF FF FF FF 00 00 FF FF FF FF FF FF FF 00 FF 0050 1C 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF 00 00 00 99 FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------ 0000 1C 32 40 00 00 01 01 3C 00 FF 00 FF 00 FF FF FF 0010 FF 28 32 3C 46 FF FF 8C AA C8 E6 3C 00 02 02 00 0020 FF 00 64 64 64 FF FF FF FF FF FF FF FF FF FF FF 0030 FF 00 FF FF 00 64 01 FF 02 01 00 00 00 00 00 00 0040 FF FF FF FF FF 00 00 FF FF FF FF FF FF FF 00 FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF 00 00 00 FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------ 0000 1C 00 40 00 00 01 01 3C 00 99 FF 99 00 FF FF FF 0010 FF 19 23 2D 37 FF FF 8C AA C8 E6 3C 00 03 03 00 0020 FF 1E 46 46 4B FF FF 99 FF FF FF FF FF FF FF FF 0030 FF 00 FF FF 00 7D 01 FF 02 FF FF FF FF FF FF 00 0040 FF FF FF FF FF 00 00 FF FF FF FF FF FF FF 00 FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF 00 00 00 99 FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------ 0000 00 00 00 00 00 00 00 00 00 25 40 36 80 FF FF FF 0010 FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF 0020 FF FF FF 96 64 96 64 E1 96 00 FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF 26 02 10 FF 00 FF FF FF FF 00 00 00 00 00 FF 0050 03 FB FF FF 00 00 00 FF FF 0E 91 33 09 04 FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 D5 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 B9 7D D5 D4 D8 4A 87 D5 CB 71 02 08 80 A9 71 84 0090 17 1C 15 7F 74 1F 32 21 C0 1A 1A 1A 1A 15 10 15 00A0 1A 17 FF FF FF FF 99 FF 99 99 00 00 00 00 00 00 00B0 FF 1F 17 0C FF 1F FF 1F FF 1F FF 1F 00 00 FF 00 00C0 00 00 07 0C 00 00 00 00 00 00 00 00 FF 1F 00 00 00D0 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF 00E0 99 FF 99 99 99 FF FF FF FF FF FF FF FF FF FF FF 00F0 25 40 36 80 1A 36 FD 00 50 00 51 00 00 00 00 FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------ 0000 FF FF 00 FF FF FF 00 FF EF FF FF FF FF 00 00 FF 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF 0050 D5 CB 80 FF 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF 0070 00 00 00 00 00 FF 01 FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------ 0000 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF 0010 00 00 00 00 00 00 00 FF 1F FF FF FF FF FF FF FF 0020 FF 01 02 00 00 FF FF FF FF FF FF FF FF FF FF 1F 0030 FF 1F 17 0D FF 1F FF 1F FF 1F FF 1F FF 1F FF 1F 0040 FF 1F FF 1F 02 02 02 02 02 02 FF 1F FF 1F 00 02 0050 7F 7F 7F 7F 00 00 00 00 07 0A 00 00 00 00 00 00 0060 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 15 80 7F 80 74 00 1F 80 32 80 1C 80 FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------ 0000 FF 85 02 10 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 F8 80 F8 80 F8 80 0F 0020 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 0E 0A 00 00 00 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0027 0150 0250 007D 007E 0490 0491 0492 0493 0494 0495 062B 062C 062D 071C 0720 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 117 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 T: 23 28 255 21 128 23 28 21 127 116 31 255 255 255 128 0 0020 0021 0022 0023 0024 0025 0026 0480 0481 0482 0483 0484 0485 0486 0487 0488 0489 048A 048B 048C 048D 048E 048F V: FF FF FF FF FF FF FF B7 7D D5 D4 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.10000 V ] V: FF FF FF FF FF FF FF B7 7D D5 D4 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.10000 V ] V: FF FF FF FF FF FF FF B7 7D D5 D4 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.00000 V ] V: FF FF FF FF FF FF FF B7 7D D5 D4 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.00000 V ] V: FF FF FF FF FF FF FF B7 7D D5 D4 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.00000 V ] V: FF FF FF FF FF FF FF 89 7D D4 D4 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.00000 V ] V: FF FF FF FF FF FF FF 89 7D D4 D3 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.00000 V ] V: FF FF FF FF FF FF FF 89 7D D4 D3 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.10000 V ] V: FF FF FF FF FF FF FF 85 7D D5 D4 D8 4A 87 D4 CB 71 02 08 80 A8 71 84 [ VID = 1.00000 V ] V: FF FF FF FF FF FF FF 85 7D D5 D4 D8 4A 88 D5 CB 71 02 08 80 A8 71 84 [ VID = 1.00000 V ] ------[ K15.6/K15.7/K16.6/K17/K17.1/K17.3/K17.5/K17.6/K17.7/K18/K21 PM2 at 0CD0 ]------ 0000 05 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0050 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF 0060 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 0090 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 00 FF 00 00 FF 00 00 FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 02 00F0 19 0A 02 05 C8 20 80 00 04 06 00 00 08 08 00 02 ------[ K15.6/K15.7/K16.6/K17/K17.1/K17.3/K17.5/K17.6/K17.7/K18/K21 PM at 0CD6 ]------ 0000 77 0B 07 E3 02 04 01 00 14 05 1C 02 06 21 43 55 0010 74 00 50 01 16 00 20 00 42 86 64 A8 40 00 3C 00 0020 20 01 9C 01 A0 00 E0 00 55 00 10 00 80 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 08 01 00 0040 FF FF FF 00 00 00 00 88 21 2B 35 59 00 00 3F 49 0050 00 00 3E 3F 90 00 00 14 01 FF 55 44 00 06 00 00 0060 00 08 04 08 08 08 10 08 20 08 B2 00 FF FF BA 00 0070 01 0B 00 00 17 01 06 19 FF FF 00 00 FF FF E0 80 0080 00 00 26 00 00 00 00 00 00 00 00 00 9E 00 80 00 0090 02 05 02 0B 01 00 10 00 00 10 00 01 00 00 00 00 00A0 00 00 00 00 00 00 00 00 F8 CE FF 00 00 00 00 00 00B0 00 20 84 02 00 00 80 05 88 00 28 00 02 00 52 C0 00C0 00 08 08 00 28 02 00 00 0C 40 28 00 DB B6 6D DB 00D0 00 F4 00 BF 00 00 00 00 00 00 11 00 00 00 00 00 00E0 D8 0C 00 00 00 00 01 00 04 00 00 01 15 14 08 7F 00F0 9C 73 00 00 00 00 00 00 3F 00 F0 FE 00 00 00 00 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : Quote
Fiery Posted August 3, 2020 Posted August 3, 2020 2 hours ago, ghot said: ------[ Versions ]------ [...] Thank you for the data! Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. 1 Quote
ghot Posted August 3, 2020 Author Posted August 3, 2020 1 hour ago, Fiery said: Thank you for the data! Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Ok... we mostly succeeded. I have the 12v, the 5v and the ... 1.8V?, I also got the CPU Opt cooling fan as well. Now still no PSU voltages on the Statistics tab, BUT I can choose: those three voltages to show on the graph, on the Voltages tab. 12v, 5v, and 1.8v? Being as how my computer does function well, I will assume that the 1.8v is NOT my PSU's 3v. New ISA Sensor Dump, in case you need it. isasensordump.txt Current OSD (at least the things that might be important at the moment) Quote
Fiery Posted August 3, 2020 Posted August 3, 2020 1 hour ago, ghot said: Ok... we mostly succeeded. I have the 12v, the 5v and the ... 1.8V?, I also got the CPU Opt cooling fan as well. Now still no PSU voltages on the Statistics tab, BUT I can choose: those three voltages to show on the graph, on the Voltages tab. 12v, 5v, and 1.8v? Being as how my computer does function well, I will assume that the 1.8v is NOT my PSU's 3v. New ISA Sensor Dump, in case you need it. Current OSD (at least the things that might be important at the moment) Thank you for your feedback! Can you see a +3.3V voltage measurement in the UEFI Setup (BIOS Setup) ? 1 Quote
ghot Posted August 3, 2020 Author Posted August 3, 2020 9 minutes ago, Fiery said: Thank you for your feedback! Can you see a +3.3V voltage measurement in the UEFI Setup (BIOS Setup) ? Yes, it's in the BIOS. Like I said this is a weird motherboard. First time I bought a board NOT meant for overclocking or serious gaming, etc. I will go into the BIOS and double check, but I'm pretty sure I did that when I didn't see the voltages in AIDA64... brb Quote
ghot Posted August 3, 2020 Author Posted August 3, 2020 1 hour ago, Fiery said: Thank you for your feedback! Can you see a +3.3V voltage measurement in the UEFI Setup (BIOS Setup) ? Yeah... 3.3v, 5v, and 12v. on the Monitor tab in the BIOS. ...and thank YOU for your excellent continuing work. You ARE amazing. ^^ /edit I been up for far too long. Don't kill yourself or anything on this issue. I will check back in 6-8 hours, after some much needed rest. You do good work. ^^ Quote
Fiery Posted August 5, 2020 Posted August 5, 2020 On 8/3/2020 at 4:57 PM, ghot said: Yeah... 3.3v, 5v, and 12v. on the Monitor tab in the BIOS. ...and thank YOU for your excellent continuing work. You ARE amazing. ^^ /edit I been up for far too long. Don't kill yourself or anything on this issue. I will check back in 6-8 hours, after some much needed rest. You do good work. ^^ Thank you! We'll add the +3.3V voltage reading in the next AIDA64 beta update. I'll post a message into this topic once the new beta is available for download. 1 Quote
ghot Posted August 5, 2020 Author Posted August 5, 2020 On 8/5/2020 at 7:56 AM, Fiery said: Thank you! We'll add the +3.3V voltage reading in the next AIDA64 beta update. I'll post a message into this topic once the new beta is available for download. See the post below, instead. Quote
ghot Posted August 5, 2020 Author Posted August 5, 2020 Ok AIDA64 625.5400 (no beta). Motherboard temp agrees. For the "CPU" temp, AIDA64 shows the average, and it doesn't change. Stays fixed at 26-27C In HWInfo I SEE the 12v, 5v, and possibly the 3v? (3VSB could be something else... not sure) Now I'm gonna re-install the 5462 Beta, and compare again... brb. Ok, now the 5462 Beta is installed. Notice the CPU and CPU Package temps. AIDA64 is NOW showing how the CPU temp fluctuates as well as the CPU package temp. And here is a pic of the Stability test on the 625.5400 and also on the 5462 Beta... For the plain CPU temp... can I assume the results in the bottom pic (5462 Beta) are the accurate ones?? Above, when I mentioned the 5462 Beta was "unstable" this is what I meant. I didn't see any "other" indications. I just can't figure out why the plain CPU temp is that much different between... 625.5400 and 625.5462 I did notice though, the HWInfo64 agrees more with the 625.5462 Beta version than with the 625.5400 version. Current ISA Sensor dump... isasensordump.txt Quote
Fiery Posted August 13, 2020 Posted August 13, 2020 On 8/5/2020 at 9:57 PM, ghot said: Ok AIDA64 625.5400 (no beta). Motherboard temp agrees. For the "CPU" temp, AIDA64 shows the average, and it doesn't change. Stays fixed at 26-27C In HWInfo I SEE the 12v, 5v, and possibly the 3v? (3VSB could be something else... not sure) Now I'm gonna re-install the 5462 Beta, and compare again... brb. Ok, now the 5462 Beta is installed. Notice the CPU and CPU Package temps. AIDA64 is NOW showing how the CPU temp fluctuates as well as the CPU package temp. And here is a pic of the Stability test on the 625.5400 and also on the 5462 Beta... For the plain CPU temp... can I assume the results in the bottom pic (5462 Beta) are the accurate ones?? Above, when I mentioned the 5462 Beta was "unstable" this is what I meant. I didn't see any "other" indications. I just can't figure out why the plain CPU temp is that much different between... 625.5400 and 625.5462 I did notice though, the HWInfo64 agrees more with the 625.5462 Beta version than with the 625.5400 version. Current ISA Sensor dump... I'm certain the new CPU temperature reflects the right measurement for the CPU temperature. Here's a fix for the voltages: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works 1 Quote
ghot Posted August 13, 2020 Author Posted August 13, 2020 9 hours ago, Fiery said: I'm certain the new CPU temperature reflects the right measurement for the CPU temperature. Here's a fix for the voltages: https://www.aida64.com/downloads/latesta64xebeta Let me know how it works I've not only gained the 3.3v, but the 3.3v Standby as well. Kudos to an excellent job, my friend. So now I seem to have everything I should. I've gained... CPU Package, CPU_Opt, GPU2, 3.3V, 3.3v standby, 5v and 12v. Still don't see the power supply voltages on the Statistics tab of the Stability Test, and can find no way to add them. I can add them to both the Voltages tab and the Unified tab, though. Thanks so much for your tireless work on keeping this excellent program up to date. Just saw a news item the other day. Nvidia is planning an event, September 1st. https://www.nvidia.com/en-us/geforce/special-event/ Ofc, this will probably cause you all sorts of heartache, but we're all behind you, we know you can do it. Thanks again. I don't know if this is helpful after the fix, but here is the latest current ISA sensor dump. isasensordump.txt All hail Fiery !! Quote
Fiery Posted August 14, 2020 Posted August 14, 2020 11 hours ago, ghot said: I've not only gained the 3.3v, but the 3.3v Standby as well. Kudos to an excellent job, my friend. So now I seem to have everything I should. I've gained... CPU Package, CPU_Opt, GPU2, 3.3V, 3.3v standby, 5v and 12v. Still don't see the power supply voltages on the Statistics tab of the Stability Test, and can find no way to add them. I can add them to both the Voltages tab and the Unified tab, though. Thanks so much for your tireless work on keeping this excellent program up to date. Just saw a news item the other day. Nvidia is planning an event, September 1st. https://www.nvidia.com/en-us/geforce/special-event/ Ofc, this will probably cause you all sorts of heartache, but we're all behind you, we know you can do it. Thanks again. I don't know if this is helpful after the fix, but here is the latest current ISA sensor dump. All hail Fiery !! Thank you for your feedback and kind words! Yes, we're already working on supporting the upcoming RTX 3000 Series "Ampere" GPUs As for the Statistics tab, the readings that you have on the Voltages tab should also appear on the Statistics tab. If that's not the case, then please send me a screenshot of both the Voltages and Statistics tab. Maximize the System Stability Test window before making the screenshots please. 1 Quote
ghot Posted August 14, 2020 Author Posted August 14, 2020 6 hours ago, Fiery said: Thank you for your feedback and kind words! Yes, we're already working on supporting the upcoming RTX 3000 Series "Ampere" GPUs As for the Statistics tab, the readings that you have on the Voltages tab should also appear on the Statistics tab. If that's not the case, then please send me a screenshot of both the Voltages and Statistics tab. Maximize the System Stability Test window before making the screenshots please. Ah, I get it. I have to enable the graphing of the power supply voltages, ON the Voltage tab... THEN they show up on the Statistics tab. The ONLY voltages that show up on the Statistics tab, are the ones that have been "turned on" on the Voltages tab. After enabling everything on the Voltage tab, it then showed up on the Statistics tab... Not sure what browser you're using, but left click once, then left click again... on the picture below, to see it full size. Quote
Fiery Posted August 21, 2020 Posted August 21, 2020 On 8/14/2020 at 5:09 PM, ghot said: Ah, I get it. I have to enable the graphing of the power supply voltages, ON the Voltage tab... THEN they show up on the Statistics tab. The ONLY voltages that show up on the Statistics tab, are the ones that have been "turned on" on the Voltages tab. After enabling everything on the Voltage tab, it then showed up on the Statistics tab... Yes, that's how it works. 1 Quote
ghot Posted August 22, 2020 Author Posted August 22, 2020 22 hours ago, Fiery said: Yes, that's how it works. Only other question I have is about some other temps. Namely... Temperature #2, and PCH Diode. They seem steady at the temps shown below. (Idle) All the other temps vary somewhat, but Temp #2 and PCH Diode, stay at 41C and 53C. What do these temps refer to? Quote
Fiery Posted August 22, 2020 Posted August 22, 2020 7 hours ago, ghot said: Only other question I have is about some other temps. Namely... Temperature #2, and PCH Diode. They seem steady at the temps shown below. (Idle) All the other temps vary somewhat, but Temp #2 and PCH Diode, stay at 41C and 53C. What do these temps refer to? Temperature #2 is odd, since you're supposed to have Temperature #1 (which is also called T_Sensor1) on your motherboard. PCH Diode is the internal temperature of the chipset (PCH), measured by the PCH's own thermal sensing logic. 1 Quote
ghot Posted August 22, 2020 Author Posted August 22, 2020 2 hours ago, Fiery said: Temperature #2 is odd, since you're supposed to have Temperature #1 (which is also called T_Sensor1) on your motherboard. PCH Diode is the internal temperature of the chipset (PCH), measured by the PCH's own thermal sensing logic. The only three temps I have that I don't normally show on my OSD are... VRM, PCH Diode, and Temperature #2. This is looking at the OSD config list. I see the exact same temps on the Stability Test > Preferences > Temperatures tab as well... Quote
