Cpstar Posted August 18, 2020 Posted August 18, 2020 Testing 3970x TR auros trx40 pro Wi-Fi corsair 8x32gb with xMP enabled Zotac GeForce gtx 1660 kraken x73 I ran the SST and it immediately crashed. The CPU temp line just shot right up and it locked up the system immediately. I didn’t keep track of what subtests were checked. What is the best way to proceed to figure out what my issue is? Ty Quote
Fiery Posted August 21, 2020 Posted August 21, 2020 On 8/19/2020 at 1:27 AM, Cpstar said: Testing 3970x TR auros trx40 pro Wi-Fi corsair 8x32gb with xMP enabled Zotac GeForce gtx 1660 kraken x73 I ran the SST and it immediately crashed. The CPU temp line just shot right up and it locked up the system immediately. I didn’t keep track of what subtests were checked. What is the best way to proceed to figure out what my issue is? Ty Check what happens if you only enable the CPU subtest of the AIDA64 System Stability Test, and then what happens when you only enable the FPU subtest. The first one (CPU) will put less thermal stress on your system than the second one (FPU). Watch how the CPU temperature reacts to each of the tests. In case it crashes much quicker with the FPU subtest, then my conclusion would be that it is an overheating issue. Quote
