jonh Posted August 29, 2020 Posted August 29, 2020 My galaxy note 8 has a light sensor like most of the phones. But my light sensor is making my screen very dark. I want to know if there is a way to disable or block the light sensor at level 5 all the time. Thanks.. Quote
Fiery Posted September 3, 2020 Posted September 3, 2020 On 8/29/2020 at 11:30 PM, jonh said: My galaxy note 8 has a light sensor like most of the phones. But my light sensor is making my screen very dark. I want to know if there is a way to disable or block the light sensor at level 5 all the time. Thanks.. Expand We don't have any technical information on that. Quote
SabrinaF Posted September 22, 2020 Posted September 22, 2020 If you 're interested you can try HBM app in Play store for this purpose (High Brightness Mode) It helps users to keep screen brighten all the time. Not only this app, there are several apps to provide the same feature. Check and pick best one for you Quote
