speedym Posted September 28, 2020 Posted September 28, 2020 It seems T_Sensor1 & T_Sensor2 are not showing up in AIDA64. The ASUS EC chip is Nuvoton nct6798D. Tested in version 6.25.5483 Beta. Thanks! Quote
Fiery Posted October 9, 2020 Posted October 9, 2020 On 9/28/2020 at 10:46 AM, speedym said: It seems T_Sensor1 & T_Sensor2 are not showing up in AIDA64. The ASUS EC chip is Nuvoton nct6798D. Tested in version 6.25.5483 Beta. Thanks! Do you have the two EC related options both enabled in AIDA64 / main menu / File / Preferences / Stability? Embedded Controller (EC) supportEmbedded Controller (EC) bank switching If yes, then please post a screen shot of the Computer / Sensor page of AIDA64, showing all thermal readings. Also, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery 1 Quote
speedym Posted October 29, 2020 Author Posted October 29, 2020 Hi Fiery, I have attached requested data. Let me know if there is anything else needed. Thanks, Milan ecdump asus zenith II extreme.txt Quote
Fiery Posted November 18, 2020 Posted November 18, 2020 On 10/29/2020 at 9:27 PM, speedym said: Hi Fiery, I have attached requested data. Let me know if there is anything else needed. Thanks, Milan Thank you! Temperature #1 and Temperature #2 should be the readings that your motherboard labels as T_Sensor1 and T_Sensor2. Quote
