Hello! So I recently bought new parts (brand new computers from A to Z) and installed Aida64 Extreme (latest version). Everything is working fine aside from the  CPU temp that always displays 28 degrees. All the other sensors are working perfectly but not the CPU, it never moves either when idle or under load.
I checked in the BiOS and it's reporting fine there with the temp constantly changing.
Any idea what could be the problem here?
CPU is a 10700k and the motherboard is Z490G.
Thanks!
Thanks!
Let me know if it helps.
On 10/24/2020 at 9:35 PM, urobulus said:
Like I said in the very first sentence it is the latest version.
Yes, but latest version could either be the latest stable version (v6.25.5400) or the latest beta build.
