Lamptron HM070 LCD, need help to display stats
urobulus
Hello!
So I was lucky enough to find and buy a Lamptron HM070 7'' LCD and it is indicated that this one was specifically created to work hand in hand with Aida64, has a couple of customs screens already created for the showing of the stats, etc...
But I look in the option of the Lamptron itself and there is no option or mode to handshake with Aida64, and in Aida64 I can't seem to find the screen listed in the LCD Screen section...
Can someone help and point me where I should go or do to make it work?
All the Lamptron does right now is act as a second screen showing my desktop since it's connected in HDMI... :(
On 10/29/2020 at 8:24 PM, urobulus said:
Hello!
AFAIK those displays are supposed to be connected via HDMI and act as a secondary screen under Windows.  You can use the SensorPanel module of AIDA64 to build and display layouts on either your primary or secondary screen, depending on where you move the SensorPanel window.
