High CPU usage after a while (Gigabyte X570 Aorus Master + RTX 3090)
Hello,
Today I bought AIDA64 and I ran into some issues. Few issues related to my GPU RTX 3090 are already reported on the other thread (Missing CPU Fan status and GPU Clock not always showing up). The main issue that is a deal breaker for me is high CPU usage after a while.
So the problem appears after ~30min of running AIDA64. AIDA64 starts to utilize one core of my Ryzen 3900XT CPU to a 100%. I use SensorPanel to monitor my HW. SensorPanel starts refreshing with 2-3s interval, instead of 1000ms which is set in settings. When I open AIDA64 it lags a lot, I barely can use it. Windows task manager reports that AIDA64 is utilizing 100% first core (thread) of my CPU.
I use the latest version available, which I have downloaded today.
What info I should provide so this issue could be solved?
EDIT: If I quit AIDA64 and start it again, issue is gone for the next 30mins and then starts again
On 10/31/2020 at 3:16 PM, adomas said:
Hello,
Please try to disable GPU monitoring by unchecking the option called GPU sensor support in AIDA64 / main menu / File / Preferences / Stability.  You will lose the readings for your RTX 3090, but it'd be crucial to narrow this down to something related to your motherboard sensors or the video card.
BTW, please also let us know the motherboard model and Windows 10 build you're using.
Thank you in advance!
Thanks for reply! I was already considering a refund. If this can be fixed in some way in near future, I will not ask for a refund. I really like AIDA64, but this CPU core utilization is killing my performance.
My motherboard is: Gigabyte X570 Aorus Master (with latest BIOS versioned F31e)
My Windows build is: 19042.610
I will report my findings a bit later. I noticed that it's not fixed amount of time for CPU core utilization to get so high. It usually starts it seems after playing any game for 10-20min, so might be GPU related.
One more thing that I should mention, I use RTSS to monitor my FPS and draw a graph on SensorPanel. RTSS version is latest stable 7.2.3, before I had 7.3.0 beta, and it was same problem.
I will post here as soon as I have more finding.
Thanks!
With GPU sensor support disabled, I still get GPU utilization metrics and GPU Clock sometimes shows up. The problem with CPU one core utilization is still there. I assume it can be related to my motherboard then? How I should proceed to narrow this?
Thanks!
Thanks!
Can you please try to remove (or hide) the RTSS item from your SensorPanel?
BTW, when you experience the high CPU usage, can you see the memory footprint of AIDA64 to become high as well?
  • 2 years later...
Hello,
Back in 2020 when I reported this, I did not manage to solve it and I got a refund for AIDA64. Now almost 3 years later, I have again bought AIDA64 in hopes that this issue is no longer happening. I still have exactly same hardware as 3 years ago and I still get this issue that I have described in this post.
I tried the latest stable version 6.92.6600 as well as latest beta version 6.92.6603.
In comparison beta version performs better. With stable version CPU Core 0 stays on 80-90% load and causes CPU to boost, while with beta version CPU Core 0 stays on 50-55% and anyway causes CPU to boost.
But this time I figure out that this is caused by "Area Graphs", as if I remove all of them, CPU Core 0 is no longer having high utilization, and is around 2-3%! So it seems that this heavy load is caused by "Area Graphs". Probably some optimizations were made recently to this feature, but so far it's still not acceptable to have 50-55% core load all the time.
Is there plans to fix this in near future? As I see difference between stable and beta, I assume team is working on this.
