I have NZXT N7 Z490 MOBO
and using i7-10700K
I wamt monitoring VCORE voltage.
but if i set the VCORE,
it is different CPU VCORE voltage in hwinfo64
i set the 1.280 but in aida 64, it is 1.330~1.380 arange vcore.
i cant find any other voltage option.
Can you add for correct vcore volatge?
and using i7-10700K
On 12/6/2020 at 6:39 PM, c_Jay_h said:
attached file. thank you.
now, i set vcore 1.280
and aida64 showing 1.380~1.480~
but hwinfo64 showing 1.280
Thank you!   Maybe what HWiNFO64 measures is the CPU VID instead of the Vcore?  In AIDA64 you can see both readings right next to each other.
