Ramses Posted February 19, 2012 Posted February 19, 2012 Hi, I got weird temp on the sensor called Motherboard. The more my fans are blowing, the more the temp goes high. With fans no running at all, the MB sensor goes down to around 35°, with all fans in 'normal mode' the temp goes around 75° !!! And when I need more fan blow, when playing games or so, the temps raise up to 85°+ I found nothing explaining that, all other sensor are correct, CPU, cores and hard drives are all in a range ~30-40° RealTemp and Asus Probe show same temps by the way. So I guess the sensor is defect. I'm looking for applying a realistic correction ratio/offset for this temp but I need help if someone has the same problem, help me please Quote
Fiery Posted February 19, 2012 Posted February 19, 2012 That indeed sounds weird. But in case Asus Probe shows the same, then the sensor most likely provides incorrect readings. I'm not sure if it makes sense to correct it, but if you wanna do that, then you can enable Correction in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction. Regards, Fiery Quote
Ramses Posted February 19, 2012 Author Posted February 19, 2012 Yeah you probably right, I'll just stop display this one in the OSD ^^ The MB temp is not the chipset, only a case temp so there is no reason to be worried about it. THX anyway for the support ! Quote
